Page 2 of 2
Re: I2C I/O PORT EXPANDER QUESTION
Posted: Fri Mar 08, 2019 9:35 am
by tlfong01
tlfong01 wrote:
Fri Mar 08, 2019 4:56 am
How much time would you spend on your I2C I/O PORT Expander Project
Your project of using Rpi to drive 260 devices using an IO expander is a very complex project, for sure not for the faint of heart newbies.
I already have 5 years hobbyist experience in Arudino and another 5 hobbyists years experience in Rpi. I still need 6 months to learn the basic knowledge and skills to do a complex project like yours.
If you are also a hobbyist like me, you might need as much time. Of course it also depends on you basic electronics knowledge, and if you have a home lab with necessary tools.
You might like to visit the following websites to know more.
Electronics Tutorials
https://www.electronics-tutorials.ws/
Free Electronics Text Book
https://www.allaboutcircuits.com/textbook/
Setting Up a Home Lab
https://www.allaboutcircuits.com/textbo ... -home-lab/
The 555 Timer
https://www.allaboutcircuits.com/textbo ... -8/555-ic/
Teardown Tools - Element14 Workbench Wednesday
https://www.youtube.com/watch?time_cont ... 4oVzS4afQ4
Upgrade Your Solder Station (for professionals only) - Element14 Workbench Wednesday
https://www.youtube.com/watch?time_cont ... R0S80xMIuk
Posted: Fri Mar 08, 2019 12:56 pm
by tlfong01
tlfong01 wrote:
Fri Mar 08, 2019 8:59 am
NE555 > ULN2803 > Songle 5V Relay > DC12V Motor Tested OK
NE555 > ULN2803 > Songle 5V Relay > DC12V Motor Schematic
Posted: Fri Mar 08, 2019 10:04 pm
by Brandon92
mikronauts wrote: You are welcome.
With a bit more software, your project can be immensely simplified.
Just use a string of ws2812 style led's (same as used on neopixels)
I think this is indeed the easiest way to make this project.
The other option would be to multiplexe all the 260 LEDs. As explained in this link. You save a lot of outputs. If you make a matrix of 16*17 you can control 272 leds. But this requires more software to make it work. In this case you only need 33 output pins. But this will also depends on the lay out the product that you are making, if this is useful for you
Posted: Sat Mar 09, 2019 3:06 am
by tlfong01
westwol wrote:
Mon Mar 04, 2019 11:59 pm
1. output must be 5 V...
2. LED as an example but could be RELAY or ACTUATOR ...
Logic Level Converter and Optoisolator
For [1], I would suggest you to use a logical level converter, such as TSX010n, to shift up Rpi GPIO signals from 3V3 to 5V0. This way you also protect Rpi, because TSX010n would be fried first (I have been frying so many chips that now I am very alert to plastic burning smell, and can pull the power plug kung fu lighting fast enough to save the next to fry Rpi!)
For [2] If your project would later entertain relays and actuators, I would suggest you to use an optical isolator now, such as EL817C, which can also be used as a logical level converter.
TSX0104, MCP23017, and EL817C
viewtopic.php?]f=37&t=77158&p=1344493&h ... C#p1344493
EL817C Design Notes
viewtopic.php?f=32&t=219744&p=1349622&h ... C#p1349577
Kung Fu Fighting Fast To Save The Next To Fry Rpi
viewtopic.php?f=32&t=219744&p=1358524&h ... g#p1358524
Posted: Sat Mar 09, 2019 4:00 am
by tlfong01
EL817C Current Limiting Resistor Calculation Notes
My lazy hobbyist quick and dirty calculation is summarized below.
The current limiting resistor value of 1k should be OK.
Update 2019mar11hkt1523
I used an adjustable voltage regulator as a signal source to verify that EL817C is off when signal is larger than 4V, and on when signal is smaller than 1V.
To make it also Rpi 3V logical compatible, I changed the resistor 1k to 6k2 and found that the high trigger off voltage decreases to about 2.6V, and on still less than 1V.
1. EL817C
Ic = 2.5mA at If = 5mA (CTR = 50%, (EL817C CTR = min 200%))
Vce(sat) = max 0.2V at If = 5mA
2. TSX010n
TSX010n High = 4V min
If = 5mA = 4V/R
R = 4V/5mA = 4k/5 ~=5k/5 = 1k
3. ULN2803A
ULN2803 Rin = 2k7
h(FE) = 350mA / 500uA ~= (350 * 1000) / 500 ~= 1,000
Ii = 2.5mA, Ic = 2.5mA * 1000 = 2.5A, if no current limiting resistor!
EverBright EL817C Datasheet
http://www.everlight.com/file/ProductFile/EL817.pdf
Sharp PC817 (PC817XNNSZ0F) DataSheet
http://www.sharp-world.com/products/dev ... nnsz_e.pdf
EL817C and EL354 Specification Summary
ULN2803A Datasheet
http://www.ti.com/lit/ds/symlink/uln2803a.pdf
Posted: Sat Mar 09, 2019 8:09 am
by tlfong01
EL817C Assembly and Testing Notes
Posted: Sat Mar 09, 2019 11:12 am
by tlfong01
EL817C youtube
https://youtu.be/EC-zXCJIfp4 (youtube)
Posted: Sat Mar 09, 2019 6:18 pm
by Burngate
westwol wrote:
Sat Mar 02, 2019 9:01 pm
I'm working on a project where a Raspberry PI must have up to 260 outputs.
westwol wrote:
Sun Mar 03, 2019 11:53 pm
I must be able to output 5 V on each of the 230 GPIO ports (just one port at a time will be outputting the voltage)
I used a LED as an example but could be a RELAY, or anything that with the logic to enable something such as an ACTUATOR.
westwol wrote:
Tue Mar 05, 2019 5:11 am
I should able to control 260 ports that must output 5V (HIGH) when active not necessarily a LED, it could be a wire to a relay that activates something. (Just one output will be enabled at a time, so I don't worry about overloading the chip)
From these I'm getting the impression you need to tell us more about what you want to drive.
For example, 260 LEDs would take less current and be more tolerant of voltage than 260 relays, and be easier to drive.
If I were to consider only LEDs, I would turn to my right and look at a 32 x 16 LED panel from AdaFruit, with 512 LEDs ready-wired and ready to go.
For relays, I'd be looking round my old workplace - they had row upon row of uniselectors, gathering dust but ready to go.
Posted: Sun Mar 10, 2019 12:56 am
by mikronauts
The OP does not want to provide details, when I asked he said led's, when I proposed a simple solution for led's he said it was not led's.
In my experience, when a poster is not willing to give details, they want to get free design work for their commercial project.
Posted: Sun Mar 10, 2019 1:53 am
by tlfong01
Free Design Work For Commercial Project
Yes, free ideas for unicorn startups.
Or he is just like my girl friend, doesn't know what she really wants, or changes her mind as frequently as changing her designer bags. I bring her fake LV bags but she pushes them away, and says she will cut me, ... :( So I beg her pardon everyday, ... :mrgreen:
Lynn Anderson - I Beg Your Pardon (BBC Top Of The Pops) - 17,249,101 views
https://www.youtube.com/watch?v=2-eclUz-RYI
Bon Qui Qui - I will cut you - 64,211 views
https://www.youtube.com/watch?v=sS2q6xIDRUc
Posted: Sun Mar 10, 2019 7:09 am
by tlfong01
tlfong01 wrote:
Wed Mar 06, 2019 7:40 am
(2) Rpi GPIO is only 3V logic. You might need to consider using logical level shifter to convert the signals to 5V.
Rpi 3V GPIO Compatible Opto Isolator/Level Converter and Power MOSFET Switch
Actually you don't need all things 5V TTL compatible. For example the EL817C optoisolater current limiting resistance value of 1k is designed to be 5V TTL compatible. You can change it to 6k, so that it is <1V on and >2.5V off, in other words, both Rpi 3V3 and TTL 5V compatible.
And if you worry that electromagnetic relays too bulky to squeeze into your small case, you can instead use power MOSFET, such as IRL540N, which can handle big currents and also has very small size SMD versions. They are also Rpi 3V GPIO compatible.
You don't need to worry that SMD devices are too small to handle. You can use feed through versions for your prototyping, and when ready for startup mass production, you can ask the cheap, open hardware, hobbyist friendly, purple PCB guy OshPark to do the SMD assembly for you.
OshPark PCB Services
https://oshpark.com/
Posted: Sun Mar 10, 2019 12:28 pm
by tlfong01
Duplicated post by mistake. My apologies.
Posted: Mon Mar 11, 2019 7:15 am
by tlfong01
the EL817C optoisolater current limiting resistance value of 1k is designed to be 5V TTL compatible. You can change it to 6k, so that it is < 1V on and > 2.5V off, in other words, now both Rpi 3V3 and TTL 5V compatible.
Getting around Rpi 3V GPIO signal not high enough to switch off EL817C opto isolator
Actually this get around of changing EL817C (total) current limiting resistor (and LED) value from 1k to 6k to make 5V Logic also 3V3 compatible is a general trick that applies to opto or direct, high trigger or low trigger relay, or power MOSFET or BJT as a sinking source driver.
An example is the following SainSmart opto low trig relay. The original in1 is Arduino compatible but NOT Rpi compatible. By adding an external 4k7 to in1, the other end of 4k7 in2 is now Rpi compatible. Of course 4k7 is not a magic number, you need to use Ohm's law and do a bit of trial and errors to find an appropriate value.
