mob-i-l
Contact: Website Facebook Google+ Twitter YouTube
Direct antenna for TV HAT for different channels
Fri Mar 01, 2019 4:21 pm
I have a TV µHAT and live close to at least two different TV broadcast towers (Jägersro, Malmö, Sweden & Copenhagen, Denmark) that are about 45 degrees apart here. I try to change the direction of the antenna and use this oneliner in Raspian Stretch to find the best direction for each TV transmitter:
while true; do femon -c 1 -H | sed '1d;s/.*signal  //;s/ |.*//' | xargs toilet -f bigascii12.tlf -F gay ; done
I would need a better method that could select a channel and measure its strength for TV uHAT, because the TV transmitters have different channels and if I measure the total signal I get signals from both broadcast towers at the same time.
I don't have another TV receiver for Denmark (MPEG-4, DVB-T & MPEG-4, DVB-T2 & DVB-T2 Lite).
Do you know how to measure the signal strength of a channel or a MUX using TVHeadend or the command line?
https://en.wikipedia.org/wiki/Digital_t ... in_Denmark
https://en.wikipedia.org/wiki/Digital_t ... _in_Sweden
Have Pi0&1A&1B&1B+&2B&3B&4B w/ Raspbian. Started w/ BASIC on ABC80&ZX81 then Forth, Z80… https://scratch.mit.edu/users/mobluse/ https://github.com/mobluse/ https://twitter.com/mobluse/ https://YouTube.com/MOBiL4u/
