PoE Port Expansion
Posted: Fri Dec 07, 2018 5:58 pm
by Kitchy
I have the PoE HAT and wondered if it can be expanded to 2 or 3 ports. I would like to use my Raspberry to handle 2 or 3 IP phones and am not sure how to use the one port given.
Re: PoE Port Expansion
Posted: Fri Dec 07, 2018 6:39 pm
by Brandon92
You need a network switch with PoE. They are designed to solve this sort of problem.
Posted: Fri Dec 07, 2018 6:40 pm
by rpdom
I don't think I understand you.
The PoE HAT powers the Pi over the Ethernet cable from a PoE capable network Switch, or a non-PoE Switch used in conjunction with a PoE injector.
If the IP phones require PoE themselves, they would also get that from the PoE capable Switch - nothing to do with the Pi.
The Pi will still be able to communicate with the phones over the network, just not provide power to them.
Posted: Fri Dec 07, 2018 8:01 pm
by Kitchy
Thanks everyone. Much appreciated.
So I guess the only reason I got the HAT was just to have an Ethernet port to begin with. Obviously it is needed to connect with my VOIP provider anyway. Evidently I was reading into the situation something that didn't apply.
Thanks again.
Posted: Fri Dec 07, 2018 9:23 pm
by hippy
Kitchy wrote: ↑Fri Dec 07, 2018 8:01 pm
The Official Raspberry Pi PoE HAT doesn't provide an ethernet port. The ethernet port is on the Pi board itself. The PoE HAT merely allows PoE power to be injected into that port and used to power the Pi board.
Perhaps you are talking about some other HAT ?
Posted: Fri Dec 07, 2018 10:19 pm
by Kitchy
Sorry, my mistake. You are quite correct. Thanks.
Posted: Sat Dec 08, 2018 7:48 am
by fruitoftheloom
Kitchy wrote: ↑Fri Dec 07, 2018 10:19 pm
http://www.makerspace-uk.co.uk/raspberry-pi-poe-hat/
Posted: Sat Dec 08, 2018 8:49 pm
by Kitchy
Excellent article. Thank you very much.
