How to sense a 5v input with GPIO
Posted: Tue Nov 13, 2012 10:43 pm
by Pijus_magnificus
Hi there
Only a fast question. I would like to sense a 5v input with my pi using the GPIO. I know that I need to limit the current and drop down the volts to 3.3v. And my question is:
Is enought with a simple resistive divisor like this one (see test1.png)
Or I need to put some additional resistor-zener to protect GPIO (see test2.png)
Any tip would be will be welcome,
many thanks
Re: How to sense a 5v input with GPIO
Posted: Tue Nov 13, 2012 11:11 pm
by mahjongg
Yes, this would work fine, and R3 isn't needed!
I myself, would use 2K2 and 3K3 resistors for an exact 2:3 ratio, for a three-fifth attenuation, that is a conversion from 5.0 to 3.0 volt, but that is simply a question of taste.
This attenuation would be even suitable for high speed signals (like a high UART baudrate) as the input capacitance of a GPIO is very low.
In fact all, that is needed to safely connect a 5V signal into a (3V3) GPIO is some kind of current limiter to avoid putting massive amounts of current through the GPIO's inherent diode to 3V3 to the 3,3V power supply. Just putting an 1K resistor in series would also do that!
Posted: Wed Nov 14, 2012 12:51 am
by Metatronin
So any 5v signal to the GPIO's need just a 1k resistor...is level shifting overkill(like in attached pic)?
Posted: Wed Nov 14, 2012 2:26 pm
by Pijus_magnificus
Many thanks for the answers,
Its only a unidirectional input signal. A simple movement sensor.
5v --> movement detected
0V --> No movement detected
I think I will keep the first circuit, that I hope is safe enough
Thanks for the answers again
Posted: Wed Nov 14, 2012 4:51 pm
by Burngate
Pijus_magnificus wrote: I think I will keep the first circuit, that I hope is safe enough
As a general rule, a voltage divider such as you have drawn appears as a source of voltage V0 in series with a resistance R0 such that:
V0=V*R1/(R1+R2)
and
R0=(R1*R2)/(R1+R2)
So in your case V0=~3v and R0=~6kΩ
That means you're safe
Posted: Wed Nov 14, 2012 5:11 pm
by mahjongg
Metatronin wrote:So any 5v signal to the GPIO's need just a 1k resistor...is level shifting overkill(like in attached pic)?
Yes level shifting is generally overkill!
Also the left picture doesn't accomplish any level shifting, as its output to the Arduino is still 3V3 (actually its even a little bit less, as the base diode drop of the transistor is subtracted, so output will be 3.3- ca 0.5 = 2.8 Volt).
Generally no level shifting from 3V3 to most 5V devices is necessary, as the minimum voltage that is acceptable as high is often just 2.0 Volt.
adding an 1K series resistor before the GPIO isn't technically level shifting, it just prevents large currents entering the 3V3 supply through the GPIO's protection diodes. In that sense it prevents damaging the PI, but a much better solution would be a simple resistor divider, with a 2K2, and a 3K3 resistor.
Posted: Wed Nov 14, 2012 7:42 pm
by Metatronin
Thanks, very helpful info. Is there anytime level shifting would be preferred over the resistor divider?
Posted: Thu Nov 15, 2012 12:19 am
by mahjongg
There might be some situations where you want the GPIO to act as a bidirectional port, but actually the voltage divider as described would work in that situation too.
In "receiver mode" the voltage would be divided as described, and in transmitter mode the PI would simply push 3V3 on top of the bottom resistor of the resistor divider, and if the load after the "top resistor" isn't too great the paired device would still see 3V3.
The trouble begins when you have a bidirectional bust with many slave devices, some of which attempting to put 5V levels on the bus, and others 3V3 levels, the 3V3 levels would also be divided to a level below the "minimum high" that the PI will accept.
But as you can see this is quite an "exotic situation", but can happen sometimes, some people who use multiple I2C devices connected to the PI want "high" levels appropriate to each slave device, and there a simple level converter, consisting of two FETs, and four pullups (to different VCC levels) are used.
see http://ics.nxp.com/support/documents/in ... n97055.pdf
Posted: Thu Jan 31, 2013 9:23 am
by eehmke
The circuit posted by Metatronin is no level shifter, as the transistor works as emitter follower (common collector). If input from PI is 3.3V, output will never exceed 2.8V. The transistor needs to work in common emitter mode to get a 5V output. In this case the signal is inverted, so you may need two transistors.
Posted: Mon Mar 04, 2013 2:15 pm
by thof
Hi all,
I have a question in line with this one. I want to use a 5V PIR sensor on a GPIO pin... so the output of the PIR is a 5V pulse.
I tried connecting a 10k resistor in line with the output and connect this to the GPIO. This works, but I feel it is not the safest way to deliver this input to the Raspberry.
From this topic I tried applying a 2k2 and 3k3 voltage divider, but now the Raspberry does not see the input.
Thinking the output might be too low I also tried a 10k and 20k voltage divider, but no luck either.
Any thought how I can safely use the 5v input?
Thanks!
edit: this is the sensor circuit I'm talking about, maybe it helps to understand how to connect it: http://www.produktinfo.conrad.com/daten ... 12V_FG.pdf
Posted: Tue Mar 05, 2013 12:14 am
by sej7278
so if i have a 16x2 lcd being driven from the 5v output gpio pin, i can't have a switch feed that same 5v as an input back into a gpio pin (with 10k pull down resistor, 1k series protection)?
ok, i've modified my circuit to this now, so instead of the 10k pull down i've got a 330/470 ohm divider, does this look right - it does seem to detect high when the button is pressed and its not blown up yet!? the +volts comes via the push-switch
#!/usr/bin/env python
from time import sleep
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BOARD)
GPIO.setup(7, GPIO.IN)
while 1:
    print GPIO.input(7)
    if GPIO.input(7):
        print "BUTTON PRESSED"
    sleep(0.2)
Posted: Mon Feb 09, 2015 11:16 pm
by bradix14
thof wrote:Hi all,
Thanks!
Thof, did you ever resolve this? I've got the same issue. When I run my DS18B20 temp sensor through the voltage divider, I get no input to the Pi...
Posted: Tue Feb 10, 2015 12:07 am
by mahjongg
measure with a volt meter what the swing is on the GPIO pin, there is nothing particular difficult going on here, no need also to re-open an ancient thread.
as long as
a zero signal is lower than 0.8V, and
a one signal is between 2.4 and 3.3V
the GPIO as input should work fine.
The DS18B20 is a 1-wire device, so it needs a complex (I2C like) interface, especially as the 2-wire device also needs to be powered from the single wire interface it can get pretty complex, not something you can solve with a simple resistor divider, and completely different from the case in the previous post.
Posted: Wed May 20, 2015 7:01 pm
by Neitsabes
I would like to connecte arduino MEGA to my raspberry using SPI interface. Could i use the kind of diviser discribe above ?
And if yes, on wich pin i have to connect it : MISO, CC and CLK is enough or i have to put it on MOSI too ?
The master will be the raspberry and slave arduino.
Thanks for your answer,
Thank you
Posted: Wed May 20, 2015 7:16 pm
by mikronauts
If Pi is SPI master, Mega is SPI slave:
only MISO needs the divider
I do this all the time in order to run SPI slaves at 5V connecting to the Pi - for one sample with schematic see:
http://www.mikronauts.com/raspberry-pi/ ... and-howto/
Theoretically just a current limiting resistor would be OK, but I feel safer with a voltage divider with a Pi.
With the Parallax Propeller microcontroller, I generally just use a 2k2 or 2k4 in-line current limiting resistor to interface to 5v I/O.
Neitsabes wrote:I would like to connecte arduino MEGA to my raspberry using SPI interface. Could i use the kind of diviser discribe above ?
Thank you
Posted: Sat Mar 12, 2016 9:59 pm
by Marre
Just bought a PIR and saw this post. Seems like no need to limit the voltage as the "standard" raspberry PIR specs. read ".... Output: Digital pulse high (3V) when triggered (motion detected) digital low when idle (no motion detected)." Input is 5-12V. Should be fine with just current limiting resistor. I will however measure the output before wiring it to a GPIO pin.
Posted: Tue Jun 26, 2018 1:40 am
by gtoal
I have a very similar problem but the issue I want to check with you is how much current is dissipated across the resistors - I have a system that is powered by the 5V bus of a Vectrex computer. Attached to the Vectrex is a smart cartridge (ARM powered but not pi-related) which is powered by the Vectrex's 5V bus. I have a Pi that is externally powered by a wall-wart but it has access to the 5V line that powers the smart cartridge from the Vectrex's edge connector (and its GND pin) - so when the vectrex powers up (and the 5V line is asserted) I want my Pi to start up a particular program that feeds data to the smart cartridge. However I do *not* want to sink any significant amount of power by doing so, because the smart cartridge really needs it.
So what value of resistor in any of the circuits suggested above would let me test for the 5V line being powered, without shorting so much current between 5V and GND that it risked underpowering the smart cartridge? Is the leakage down in the single digit mA range? I'm fairly sure that drawing 20 - 30 mA would be problematic.
Posted: Tue Jun 26, 2018 10:54 am
by pcmanbob
You can calculate the current flowing through the resistors by simply using ohm's law were current = voltage / resistance , I =V/R
https://en.wikipedia.org/wiki/Ohm%27s_law
so if you were to use a 1K & 2K resistor your total resistance would be 3K
so 5/3000 = 0.00167A or 1.67mA
if you want to draw less than that just change the resistance values to 10K and 20K which will be 30K in total
so 5/30000 = 0.000167A or 0.167mA which less than 1mA
Posted: Thu Jun 28, 2018 10:01 pm
by gtoal
Groan! The embarrassment of realising that E=IR was the only factor involved :-/
