Raspberry Pi TV Hat DVB-T2 Gateway (Tvheadend with FFmpeg and realtime hardware video stream transcoding)
Posted: Tue Nov 20, 2018 4:23 pm
by belos
This is a very-very short installation manual that gives 100% working result.
Hardware: Raspberry Pi 3 Model B and Raspberry Pi TV Hat.
1. Install Raspbian Jessie (not Raspbian Stretch!) and update the system.
2. Install Tvheadend v4.3 (unstable) as described here:
https://tvheadend.org/projects/tvheaden ... tories#fn3
3. Configure Tvheadend, and test viewing your air TV channels using default MPEG-TS Pass-through "pass" stream profile.
4. Download and compile OpenMAX-enabled FFmpeg:
https://www.reddit.com/r/raspberry_pi/c ... ith_ffmpeg
4. Run the following command and make sure you can see the test picture. This means that hardware acceleration works properly:
"gst-launch-1.0 -v videotestsrc ! omxh264enc ! h264parce ! omx264dec ! glimagesink"
5. Create new streaming profile in Tvheadend web interface (Configuration->Stream->Stream Profiles) using "MPEG-TS Spawn/ built-in" type with the command line:
"ffmpeg -i - -f mpegts -c:a copy -c:v h264_omx -b:v 368k pipe:1"
This will generate the stream with the bitrate about 500-600 kbit/s instead of several Mbit/s using GPU hardware transcoding.
During the transcoding CPU usage will not be higher than 40-60% comparing to 150% in case if you are using any other software transcoding. CPU temperature will not raise above 60-65°C.
Most probably this configuration will work on any Raspberry Pi (even on RPi Zero), of course, depending on the input signal complexity.
I also have Kodi on my RPi Zero connected to TV that is used as a client system for the described installation.
Hope this info will help someone. I´m open for any comments and questions.
Re: Raspberry Pi TV Hat DVB-T2 Gateway (Tvheadend with FFmpeg and realtime hardware video stream transcoding)
Posted: Tue Nov 20, 2018 6:23 pm
by fruitoftheloom
Raspbian Jessie is no longer supported and any user not aware will try this on the 3B+ / 3A+......
Posted: Wed Nov 21, 2018 8:35 am
by belos
Thanks, that´s right. But sometimes we have to use old, but proved solutions to achieve the desired result.
Posted: Wed Nov 21, 2018 9:36 am
by gkreidl
My rtranscode V4 package offers a complete transcoding solution which works with different backends on both Jessie and Stretch. Transcoding on Jessie is more efficient though because the gst-omx module has implemented hardware scaling, which is missing in the Stretch version.
viewtopic.php?f=38&t=123876
Posted: Wed Nov 21, 2018 12:47 pm
by fanoush
Just wondering what type of trancoding (resolution? codec types?) is this targeted for? Can this transcode HEVC/h265 to h264 in realtime on pi3b+? Or does it trancode mpeg-2 to h264? Can it do mpeg-2 in realtime without paid HW codec?
