Which resources (GPIO's) does the new TV use?
Or to put it another way, which GPIOs are still available for other applications?
Regards
Erich
Re: Which resources does the TV HAT use?
As I understand it, it uses the SPI port and the HAT ID I2C connection and that's all.
Would be good if someone who knew what pins were used would raise a pull request on https://pinout.xyz/
Electronic and Computer Engineer
Pi Interests: Home Automation, IOT, Python and Tkinter
- Raspberry Pi Engineer & Forum Moderator
- Location: ZZ9 Plural Z Alpha, aka just outside Cambridge.
https://github.com/raspberrypi/linux/bl ... verlay.dts
So SPI0 with CE0.
Being a HAT it will have an ID EEPROM to trigger the loading of this overlay.
fragment@0 {
target = <&spi0>;
__overlay__ {
/* needed to avoid dtc warning */
#address-cells = <1>;
#size-cells = <0>;
status = "okay";
spidev@0 {
status = "disabled";
cxd2880@0 {
compatible = "sony,cxd2880";
reg = <0>; /* CE0 */
spi-max-frequency = <50000000>;
status = "okay";
I wanted to combine my pi tv hat with a Hifiberry AMP2, all stacked together with an adafruit extra tall header (ada1979) on a raspberry pi 4. The sound works but the /dev/dvb/ device is not there (worked without the sound board)
The Hifiberry AMP2 uses (https://www.hifiberry.com/docs/hardware ... ry-boards/):
GPIO 2-3: I2C
GPIO 4: Mute
GPIO 18-21: PWM0 and second SPI
I do not understand, why this does not work together, if the TV Hat only uses the first SPI. Would be nice to find information about these boards on https://pinout.xyz/boards#
GPIO 2-3: I2C
GPIO 4: Mute
- DougieLawson
- Location: A small cave in deepest darkest Basingstoke, UK
- Contact: Website Twitter
It uses I2C0 (GPIO0 SDA/GPIO1 SCL) and SPI0.0 (GPIO10 MOSI/GPIO9 MISO/GPIO11 CLK/GPIO8 CE).
