aaron22
PoE HAT Fan alternate uses
Fri Sep 28, 2018 3:30 pm
I'd like to use the fan power connector to control LED lights instead. I've found this code in the USB issue thread to have the fan on all the time
echo 40 | sudo tee /sys/class/hwmon/hwmon0/def_pwm1
Would that tiny connector supply enough power to operate a couple 5mm LED lights? I can't find anywhere how much power comes out of there.
ShiftPlusOne
Re: PoE HAT Fan alternate uses
Fri Sep 28, 2018 4:11 pm
It's a 5V line switched by this MOSFET:
https://www.diodes.com/assets/Datasheets/ds31783.pdf
It's not really meant for driving LEDs, but if you keep current draw well under around half an amp, it should be okay.
aaron22
Fri Sep 28, 2018 4:31 pm
Thank you so much. I'm using 1.5V 30mA 100mW LED bulbs so I'll be more than OK to run a few of them.
