martin5504
5V FAN to 3.3V pin
Thu Sep 13, 2018 4:35 pm
Hi guys,
I have this fan for my Pi https://www.aliexpress.com/item/New-Ras ... 69888.html
But is litle more louder then I can endure, can I connect this fan to 3.3v pin? Is this healthy for RPI? Could this help with silence of fan?
Thanks for help.
pcmanbob
Re: 5V FAN to 3.3V pin
Thu Sep 13, 2018 5:08 pm
I would advise against connecting the fan to the 3.3v pin on the pi gpio.
You could end up damaging your pi if the fan should put any noise or reverse voltages on to the pin, which it might do on pi shutdown.
If you want to reduce its speed permanently just add a resistor in series with the fan when connecting it to the pi.
Or use a transistor and a gpio pin to apply pwm speed control to the fan for variable speed control.
Remember we want information.......................no information no help
The use of crystal balls & mind reading is not supported
martin5504
Thu Sep 13, 2018 6:31 pm
Okay cool thanks,
so only with transistor I can control speed too right?
https://hackernoon.com/how-to-control-a ... 13b6e7f92c
So this tutorial is for transistor and a gpio pin to apply pwm speed control ?
Brandon92
Thu Sep 13, 2018 6:52 pm
No really, you need also add a base resistor for the transistor. And add a fly back diode across your fan, for protection.
pcmanbob
Thu Sep 13, 2018 6:58 pm
As Brandon92 has already said you need more components than just a transistor.
this is the sort of circuit you need to control a 5v fan using a gpio pin.
martin5504
Thu Sep 13, 2018 7:02 pm
Understood, but for only shutting and turning on the fan is enough only the transistor right?
Brandon92
Thu Sep 13, 2018 7:06 pm
No, that is not correct. You need this ^ schematic for turning on and off your fan.
pcmanbob
Thu Sep 13, 2018 7:09 pm
no to control the fan or even to just turn it on or off you need the extra components.
if you just want the fan to run at a constant speed you could just use this circuit, the fan will be on as long as the pi is powered.
the value of R ? will have to be found by experimentation, but 22Ω might be a good starting value going lower for higher speed or higher for a lower speed.
