KY-022 and FAN connection to Pi
Posted: Fri Aug 17, 2018 8:35 am
by martin5504
Hi guys,
I need litle help from you, Id like to use a case with Fan and KY-022 at the same time, is possible to connect the two devices to Pins?
Thanks for help.
https://www.youtube.com/watch?v=ymFO0oFyXA4&t=393s
https://i.ebayimg.com/images/g/z6YAAOSw ... -l1600.jpg
Re: KY-022 and FAN connection to Pi
Posted: Fri Aug 17, 2018 5:30 pm
by Burngate
I don't like wading through videos, but looking at https://tkkrlab.nl/wiki/Arduino_KY-022_ ... ver_module the answer would appear to Yes.
The fan has a two-way connector that fits on pins 4 & 6
To connect the infra-red sensor, use any ground pin you like (there are seven others besides pin 6) and pin 1 for the 3v3.
If you're going to use GPIO 18 as that page suggests, then that's pin 12
