Jencen_Dragoo
Gertboard Jumper leads
Sat Nov 03, 2012 12:46 pm
Hey all
Does anyone know what plugs are used for the jumper leads?
I'm wanting to make up some more/longer ones and a few multipole ones for the programming interface for the ATmega but I can't figure out the Farnell website to find which ones I need.
Found the header strip but not the single pole connectors.
Also can't figure out if they come with the crimp connectors or if they are bare housings.
Am I just being dense or is the Farnell website /THAT/ hard to search? o.O
Grumpy Mike
Re: Gertboard Jumper leads
Sun Nov 04, 2012 3:26 pm
Farnell is only easy to search if you know what you are looking for.
I think this is what you might need:-
Crimp Socket
Order Code:
1111153
http://uk.farnell.com/te-connectivity-a ... dp/1111153
However that does not include the crimping tool. The one they have is very expensive you should be able to get a simple one for £15 or so.
JohnCrow
Sun Nov 04, 2012 4:27 pm
Hi
I bought some f-f jumpers from proto-pic in the UK
Part No. PPPRT-08430 these are 6 inch
Part No. PPPRT-09389 these are 12 inch
http:// proto-pic.co.uk
Look very similar quality to the ones supplied by farnell with the kit.
Think they are from Sparkfun in the States
1 in 10 people understand binary, the other one doesn't
tonygo2
Tue Nov 06, 2012 11:22 am
These look just right. Looks a great site with loads of interesting goodies and MUCH easier to navigate the RS or Element 14. Thanks for the link. There is no minimum order amount - great.
jsharper
Tue Nov 06, 2012 9:20 pm
Also, if you aren't in a hurry for delivery, check ebay...
Jencen_Dragoo
Thu Nov 08, 2012 6:32 pm
Cool
Thanks for the Proto Pic one ^__^
I can see where I'll be going quite a bit o.o
Many thanks
JohnCrow
Thu Nov 08, 2012 7:51 pm
I use them quite regularly.
They have some stock I've not found anywhere else apart from on US websites.
Also one thing I really like, they use small plastic boxes for shipping. They are great for component storage. (Well if you order something large you get a larger plasic box :) )
Shipping is normally next day (I usually order in the evening and get a conformation my order has shipped the following afternoon)
