HermannSW
LCD, keyboard and Wifi make Raspberry laptop
Sat Jul 28, 2018 10:43 pm
Whether connected to Wifi at vacation house, or to free German high speed train (free) Wifi, wireless Pi (with built in Wifi or dongle) makes a Raspberry laptop with (big enough, I use 1024x600 7") LCD and (wireless touch) keyboard:
If you ever drive on German high speed train ICE, you get (free wall power and) free Wifi by adding these lines to /etc/wpa_supplicant/wpa_supplicant.conf:
network={
        ssid="WIFIonICE"
        key_mgmt=NONE
⇨https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://gitlab.freedesktop.org/HermannSW/gst-template
https://github.com/Hermann-SW/fork-raspiraw
https://twitter.com/HermannSW
HermannSW
Re: LCD, keyboard and Wifi make Raspberry laptop
Sun Jul 21, 2019 7:42 am
Last year I bought 7" Waveshare 1024x600 DPI display for use during 3 week vacation in Denmark.
The display worked well, inclusive on train ride direction vacation.
I did not use the display for a year now, and it is time to make the PIs work with it again, for upcoming 3 week vacation.
Reason is that the Pi ZeroW I used on last year vacation died, and among the 7 working Pi Zero[W]s I own only one has male headers.
The Pi 3B+ that was in Denmark last year has severe SD card issues and needs to be reflashed.
So in order to see whether display still works I appended this to Raspberry 2B+ (that had never seen the 7" display) /boot/config.txt and rebooted:
[email protected]:~ $ tail -8 /boot/config.txt
dtoverlay=dpi24
enable_dpi_lcd=1
display_default_lcd=1
dpi_group=2
dpi_mode=87
dpi_output_format=0x6f005
hdmi_cvt 1024 600 60 6 0 0 0
Worked like a charm.
Next to enable are Pi Zero, Pi 3B and Pi 3A+ (will use Dremel to cut hole for display cable into the case, as I did for camera cable):
P.S:
I would have to Dremel away too much from case cover for RGB LCD hat to get cover closed ‒ will use case without cover during upcoming vacation:
https://www.raspberrypi.org/forums/view ... 3#p1504743
