Sarah2001
Stepper Motor HAT
Tue Apr 17, 2018 6:38 pm
I am creating a drawing machine using two stepper motors which change the length of the string which holds the pen (often called a polargraph drawing machine). I am running into problems with the stepper hat and library supplied by AdaFruit (https://www.adafruit.com/product/2348) such as not being able to run two at the same time and locking them properly. I think this is because it is a general purpose board and not specifically designed for stepper motors so is driving it more like a DC motor.
Any suggestions on anything better I can buy to control my stepper motors with?
-Sarah
asandford
Re: Stepper Motor HAT
Tue Apr 17, 2018 10:35 pm
-Sarah
You might get a better response contacting Adafruit directly, or posting on their forum.
Etienne
Fri May 25, 2018 3:49 pm
you can manage to do a polagraph using only Raspebby Pi :
[*]see on the forum viewtopic.php?p=1131215#p1131215,
[*]also some more detail in french here : http://www.labfab.fr/portfolio-item/dra ... nimaliste/
I manage to synch up the two stepper using my own python code that interpolates between two points to draw a line.
