lekston
Re: Anyone familiar with the Waveshare GSM/Bluetooth Hat?
Wed Jul 31, 2019 9:06 am
I purchased the GSM/GPRS/GPS hat for my PI3B+ and a low cost SIM from french local provider. I had some difficulties to establish a serial communication. The working configuration is (from my laptop at this stage)
- set the jumper to A (USB <=> serial)
- check usb connection using dmesg | grep USB
- chmod 777 /dev/ttyUSB0 (i don't know if it realy requiered but now it works)
- putty serial /dev/ttyUSB0
I don't know why minicom seem not working but for my tests on PI, I would need it (I connect to my PI throu ssh) and putty requires a X server.
Now I have a big issue : few seconds after entering my pin using AT +CPIN=<my pin here> hat shuts down (yet hat telling me that call and sms are ready) .
Does anybody encountered the same issue?
kapture
Fri Aug 02, 2019 11:01 pm
This video helped me a lot to get this device working and has an example python code to send sms.
https://youtu.be/n8LYZr_5Jms?t=335
lekston
Thu Aug 08, 2019 12:40 pm
Thank you for this interesting link.
Actually, it seems the USB <=> UART connection delivers not enough power during GSM startup phase (just after entering the PIN code) and very often, it simply shuts the hat down. Hopefully UART works perfectly. Nota: don't forget to enable serial communication and disable the "serial login" in the rasp-config.
sourabhjain01
Sat Nov 23, 2019 6:39 am
SMPP providing the service of sending and receiving SMS in a short period of time. By connecting to this service we can bring our business to the top of the market. SMPP service is a worldwide service by engaging this service is one of the best profit ideas for everyone. For more details visit our site-http://smpp.in
Paulchartres
Tue Dec 03, 2019 9:42 am
Sim 868 connexion à internet
Matériel utilisé :
-carte Raspberry pi 3B+ - module SIM868
Procédure à suivre :
Le module doit être branché suivant la procédure. 1- Mettre à jour le système : sudo apt-get update && sudo apt-get upgrade puis sudo reboot. 2- Sudo nano /boot/config.txt tout en bas écrire : « enable_uart=1 »
3- Sudo apt-get install ppp
4- Sudo -i cd /etc/ppp/peers/ wget https://raw.githubusercontent.com/adafr ... aster/fona - nano fona écrire « orange » après le « -T» à la place des « **** » et « /dev/serial0 » en dessous de « 115200 »
5- Sortir de sudo -i : puis taper Sudo raspi-config une fenêtre s’ouvrira, sélectionné : -interfacing option puis -serial puis -non puis -oui puis -ok sauvegarder et redémarrer, brancher le modem pendant le redémarrage.
6- Sudo ifconfig eth0 down Sudo ifconfig wlan0 down
7- Allumer le modem
8- Sudo pon fona
9- Tester le ping : ping google.com
10- Ifconfig (vérification de pp0) https://www.digikey.com/en/maker/projec ... c5c1dc2ff0
fonctionne avec une carte sim de chez orange
Wyniek
Fri Jan 24, 2020 6:47 am
Arnoldjp57 wrote:
Sun May 13, 2018 4:21 pm
Hi
I am busy with a project using a Raspberry PI and have successfully done a proof of concept where I monitor input from the GPIO pins and send the info to a website using a https post request from where I send SMS's, monitor response etc etc
..... Basically, PI 3B python3/sqlite3/request and I2C for the 16X2 LCD display. Working very well using a wifi connection
So .... My challenge
I am trying to get this working on the PI zero 1.3 with raspian lite (uname -a 4.14.34+)
All the python related stuff is up and running
Installed a Waveshare GSM/GPRS/GNSS hat piggy backed onto the GPIO pins of the PI for the internet connection (Future GPS and Bluetooth as well)
Working SIM is installed in the hat and I have the 2 jumpers in the B position (PI-SIM868) (I have the net LED flashing every 3 seconds)
Installed minicom and can connect to /dev/ttyAMA0 and it responds to ATcommands ...
I have 3 basic issues to resolve and hope for any guidance from this forum
1. How do I configure and activate the GPRS connection for internet access?
2. How do I access other GPIO pins for my other inputs/outputs with the HAT in place?
3. How do I power up the hat automatically when the PI powers up?
I am based in Johannesburg (South Africa)
Regards
Arnold
Hi Arnold,
Did you ever get this to work ? I’m having issues to connect to my device. Any help will be much appreciated.
Also a fellow South African... now living in Texas.
Please help. I’m about to give up with this HAT.
Wynand
