JohnCrow
Software
Fri Oct 19, 2012 11:55 am
Hi Gert
The user guide says the test programs will also be available in Python.
Any idea when these will be ready?
John
1 in 10 people understand binary, the other one doesn't
Gert van Loo
Re: Software
Fri Oct 19, 2012 1:04 pm
No,
I have not had time also because I first have to learn Python.
I think this is a good place where the Raspberry-Pi community could give a helping hand.
JohnCrow
Re: Software
Fri Oct 19, 2012 5:23 pm
Hopefully I will get my board assembled over the weekend.
Like you Ive been learning Python over the last couple of months, although my C is very rusty, Ill see if I can rewrite some of your programs in Python and post them here if you have no objections.
texy
Re: Software
Mon Oct 22, 2012 4:43 pm
I,ll get you started. Wiringpi for python is my chosen method.
#!/usr/bin/env python
# -*- coding: utf-8 -*-
# Gertboard LED checker
# v1.00
# 22/10/12
import time
import wiringpi
ON = 1
OFF = 0
#gpio's :
LED1  = 6  # gpio pin 25
LED2  = 5  # gpio pin 24
LED3  = 4  # gpio pin 23
LED4  = 3  # gpio pin 22
LED5  = 2  # gpio pin 21
LED6  = 1  # gpio pin 18
LED7  = 0  # gpio pin 17
LED8  = 14  # gpio pin 11
LED9  = 12  # gpio pin 10
LED10  = 13  # gpio pin 9
LED11  = 10  # gpio pin 8
LED12  = 11  # gpio pin 7
def setup():
  # Set pin directions, ON = Output.
  wiringpi.wiringPiSetup()
  for pin in [LED1, LED2, LED3, LED4, LED5, LED6, LED7, LED8, LED9, LED10, LED11, LED12]:
    wiringpi.pinMode(pin, ON)
def main():
  print 'Gertboard LED tester'
  setup()
    wiringpi.digitalWrite(pin, ON)
    time.sleep(0.2)
    wiringpi.digitalWrite(pin, OFF)
    time.sleep(0.2)
    time.sleep(0.3)
    time.sleep(0.1)
if __name__ == '__main__':
  main()
Note the gertboard needs wiring as per the manual for checking the LED's.
Texy
wallarug
Re: Software
Mon Oct 29, 2012 9:11 am
I might be able to help in this area in a few weeks. I am very busy now.
