bayou020
[solved] Huawei ME909s-821 recognized in ubuntu but not on raspberry
Tue Dec 12, 2017 1:22 pm
Hello guys,
I have bought Huawei ME909s-821 LTE modem but i have one problem to bind it to the network using raspberry.
to connect trough the network i need to execute the command udhcpc via a script to bind the interface shown of the modem in the command ifconfig to start a connection shortly.
In ubuntu when i link the modem via usb when i put ifconfig i got the result
-XPS-15-9550:~$ ifconfig
enp0s20f0u2c2 Link encap:Ethernet  HWaddr 02:1e:10:1f:00:00
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
which enp0s20f0u2c2 is the inteface of huawei modem
then i will type the following command to get the ip address
XPS-15-9550:~$ sudo udhcpc -i enp0s20f0u2c2 -q
udhcpc (v1.22.1) started
Sending discover...
Sending select for 10.21.24.38...
Lease of 10.21.24.38 obtained, lease time 518400
but when i connect it to the raspberry i dont get any interface related to the modem via ifconfig just the usb ports
[email protected]:~ $ lsusb
Bus 001 Device 005: ID 1c4f:0002 SiGma Micro Keyboard TRACER Gamma Ivory
Bus 001 Device 007: ID 12d1:15c1 Huawei Technologies Co., Ltd.
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
[email protected]:~ $ ls /dev/ttyUSB
ttyUSB0  ttyUSB1  ttyUSB2  ttyUSB3  ttyUSB4
but when i arrive to ifconfig here is the result
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.27.17  netmask 255.255.255.0  broadcast 192.168.27.255
        inet6 fe80::fcde:2bb1:abe6:942  prefixlen 64  scopeid 0x20<link>
        ether b8:27:eb:5f:7b:2f  txqueuelen 1000  (Ethernet)
        RX packets 62276  bytes 83929543 (80.0 MiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 33004  bytes 2726973 (2.6 MiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1  (Local Loopback)
        RX packets 9  bytes 440 (440.0 B)
        TX packets 9  bytes 440 (440.0 B)
when i typed dmesg | grep usb i got the interesting result
[   44.976718] usb 1-1.2: Product: HUAWEI Mobile V7R11
[   44.976726] usb 1-1.2: Manufacturer: Huawei Technologies Co., Ltd.
[   44.976734] usb 1-1.2: SerialNumber: 0123456789ABCDEF
[   44.983242] cdc_ether 1-1.2:2.0 usb0: register 'cdc_ether' at usb-3f980000.usb-1.2, CDC Ethernet Device, 02:1e:10:1f:00:00
[   45.000152] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB0
[   45.001840] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB1
[   45.003438] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB2
[   45.004839] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB3
[   45.006250] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB4
[   45.275504] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[   45.276397] cdc_ether 1-1.2:2.0 usb0: kevent 12 may have been dropped
[   45.794218] usb 1-1.2: usbfs: interface 0 claimed by cdc_ether while 'usb_modeswitch' sets config #3
i dont know why it shows usb0 link is not ready and kvent 12 may have been dropped.
can any one help me out to mount the interface into the raspberry :D
thanks
bayou020
Re: Huawei ME909s-821 recognized in ubuntu but not on raspberry
Sun Dec 17, 2017 2:59 am
the problem was solved by deleting usb-modeswitch and usb-modeswitch-data :D
swadhin
Re: [solved] Huawei ME909s-821 recognized in ubuntu but not on raspberry
Thu Nov 15, 2018 2:08 pm
Modem:- Huawei ME909s-921
Even if modeswitch not running why this device idProduct is changing on reboot.
Is it modem issue or usb driver issue?
Please suggest.
[    4.562992] usb 1-1.3: new high-speed USB device number 5 using ehci-pci
[    4.660456] usb 1-1.3: New USB device found, idVendor=12d1, idProduct=1568
[    4.665373] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    4.674794] usb 1-1.3: Product: HUAWEI Mobile V7R11
[    4.674796] usb 1-1.3: Manufacturer: Huawei Technologies Co., Ltd.
[    4.362550] usb 1-1.3: new high-speed USB device number 4 using ehci-pci
[    4.461386] usb 1-1.3: New USB device found, idVendor=12d1, idProduct=15c1
[    4.466143] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    4.475529] usb 1-1.3: Product: HUAWEI Mobile V7R11
[    4.480384] usb 1-1.3: Manufacturer: Huawei Technologies Co., Ltd.
[    4.485328] usb 1-1.3: SerialNumber: 0123456789ABCDEF
Thank You
