mister_wavey
Q: Gertboard powered away from pi
Wed Oct 03, 2012 7:53 am
Hi, if I wanted to use the the Gertboard like a standalone Arduino, disconnected from the pi, what would be the recommended way to power it?
Gert van Loo
Re: Q: Gertboard powered away from pi
Wed Oct 03, 2012 12:57 pm
It has a 3v3 regulator which is fed from the Raspberry-Pi 5V.
The output of that goes to a jumper and from there to the rest of the board.
You have two options:
- Connect 5V** before the 3V3 regulator.
- Connect your own 3V3 power to the jumper on the board
I found the board uses very little current but then I have not tried to drive all outputs at the same time yet.
** I have not tested this but you could also connect a higher voltage.
The regulator gets warmer and depending on how much current you take out and how high a voltage
you put in you may have to add a heat sink. Beware that some 3V3 regulators have a max input voltage of 7V.
I do NOT know what 3V3 regulator is used. Especially as there are now Tandy kits (and hopefully soon)
Farnell kits which are unlikely to have the same parts.
Tandy
Wed Oct 03, 2012 1:21 pm
The 3.3V Regulator supplied in the Tandy kit is an LM3940 specifically designed for 5V to 3.3V conversion with a low drop out Voltage of 0.5V and high current rating of 1A. This means that you can run the board from as little as 3 AA dry cells (3x1.5V=4.5V) or 4 rechargable cells (4x1.2V=4.8V) if you want. However the absoloute maximum rating for the input Voltage of this regulator is 7.5V so wouldn't suggest running it at much more than 6V to avoid needing a heatsink.
Tandy - The home of electronics - www.tandyonline.co.uk
mister_wavey
Wed Oct 03, 2012 2:07 pm
Thanks guys!
