GPS error
Posted: Fri Apr 21, 2017 12:37 pm
by Martyparty
I have tried using cat /dev/serial0, cgps -s and gpsmon /dev/serial0, and it all worked last time I tried, but today when
Trying to run gpsmon /dev/serial0
I get this message
gpsmon: ERROR: device open failed:Permission denied - retrying read only
gpsmon: ERROR: read-only device open failed: Permission denied
gpsmon: activation of device /dev/serial0 failed, errno=13 (Permission denied)
Does anyone know what's the reason for this? Is it possible that my battery on my GPS neo 6M is flat?
Re: GPS error
Posted: Fri Apr 21, 2017 1:33 pm
by bensimmo
What does gpsmon on its own say?
Re: GPS error
Posted: Fri Apr 21, 2017 1:36 pm
by Martyparty
bensimmo wrote:What does gpsmon on its own say?
tcp://localhost:2947 JSON slave driver>
(115) {"class":"VERSION","release":"3.11","rev":"3.11-3","proto_major":3,"proto_
minor":9,"remote":"tcp://localhost:2947"}
(227) {"class":"DEVICES","devices":[{"class":"DEVICE","path":"tcp://localhost:29
47#/dev/serial0","activated":"2017-04-21T12:55:58.293Z","native":0,"bps":115200,
"parity":"N","stopbits":1,"cycle":1.00}],"remote":"tcp://localhost:2947"}
(154) {"class":"WATCH","enable":true,"json":false,"nmea":false,"raw":2,"scaled":
false,"timing":false,"split24":false,"pps":true,"remote":"tcp://localhost:2947"}
Re: GPS error
Posted: Fri Apr 21, 2017 1:57 pm
by bensimmo
cd /dev
ls
Can you see ttyAMA0 or serial0
Which Pi are you.
I just hooked mine up to test for you.
I had to disable serial in Raspberry config and reboot, them enable again and reboot.
ttyAMA0 then reappeared in the list (Pi2 here) for some reason it had vanished.
I then cd /dev to check it was there and then
sudo cat ttyAMA0
Is generating the GPS style code.
(Edit or serial0 works now too just tested)
Though neither gpsmon or sudo gpsmon are getting past what you display, but i do have no lock. It did used to go the the screen, just with no lock.
That at least shows the GPS is seeing something.
Re: GPS error
Posted: Fri Apr 21, 2017 2:07 pm
by Martyparty
bensimmo wrote:cd /dev
ls
Which Pi are you.
sudo cat ttyAMA0
What do you mean by cd/dev?
I have a raspberry pi 2 model B. I have serial0, which I have used the whole time.
I started with the code
sudo nano /boot/cmdline.txt
and removed console=serial0,115200
But now I tried using this again, and I can see that it has appeared again, so I will delete it once more, and see if it works
Re: GPS error
Posted: Fri Apr 21, 2017 2:10 pm
by bensimmo
Basic file navigation
cd (change directory)
/dev (the directory)
I'm checking you can see the data stream off the GPS.
Mine currently sat waiting for a lock then I'll try gpsmon and cgps again.
Re: GPS error
Posted: Fri Apr 21, 2017 2:13 pm
by bensimmo
Try
sudo gpsmon /dev/serial0 9600
Just noticed it not defaulting to 9600 on you text for gpsmon
Re: GPS error
Posted: Fri Apr 21, 2017 2:14 pm
by Martyparty
bensimmo wrote:Basic file navigation
My serial is disabled.
I still don't get anything. What do you mean by lock?
Re: GPS error
Posted: Fri Apr 21, 2017 2:15 pm
by bensimmo
Martyparty wrote:bensimmo wrote:Basic file navigation
GPS satellites lock.
But read just above again.
Re: GPS error
Posted: Fri Apr 21, 2017 2:17 pm
by Martyparty
bensimmo wrote:Try
Now it's working for a few seconds. I get a table with information. Why does it suddenly stop?
Re: GPS error
Posted: Fri Apr 21, 2017 2:18 pm
by Martyparty
Martyparty wrote:bensimmo wrote:Try
I get the message "read error from device"
Re: GPS error
Posted: Fri Apr 21, 2017 2:24 pm
by bensimmo
That's happening to mine and i have a fix(lock).
What does
sudo cat /dev/serial0 give?
It should be the GPS data stream, do you have a lock (aka fix) and any position data?
Some update along the way has messed it up (mines up-to-date as of today).
I never had to use sudo before if i remember correctly and it never failed with that error.
I think gpsmon also detected it as a ublox as trigger it drive (you can force it with. gpsmon (blah blah) -t u-blox )if you want)
Re: GPS error
Posted: Fri Apr 21, 2017 2:25 pm
by Martyparty
When trying to run sudo cat /dev/serial0 I get a long list with NMEA unknown msg*58, which I also got earlier, but solved by using
stty -a -F /dev/serial0
stty -F /dev/serial0 9800
stty -F /dev/Serial0 -echo
to turn off echoing, but no I only get permission denied. How can I solve this?
Re: GPS error
Posted: Fri Apr 21, 2017 2:28 pm
by Martyparty
bensimmo wrote:That's happening to mine and i have a fix(lock).
What does
Earlier today when I got a table from this code cgps -s, but I got NO FIX (0 sec) and n/a
Re: GPS error
Posted: Fri Apr 21, 2017 2:53 pm
by bensimmo
Nmea unknown is fine and expected.
BUT i just found out my problem.
I turned on/off serial in the PIXEL raspian settings, it faulty and shouldn't be used.
sudo raspi-config
works.
It allows you to set console to off and device to on
Pixels version doesn't, it either all on or all off?
Anyway.
Check
The file. /boot/config.txt
Has
enable_uart=1
(Not =0) as pixel settings sets
You already have the console removed from you details above
Reboot, wait for a bit and just gpsmon should work with nothing else.
That'll teach me not to check the files they should be setting and trusting it....
Re: GPS error
Posted: Fri Apr 21, 2017 2:59 pm
by Martyparty
bensimmo wrote:Nmea unknown is fine and expected.
sudo raspi-config
works.
Anyway.
Check
Has
enable_uart=1
Yes its been set to enable_uart=1 the whole time. But what should I do if I have changed it in raspi-config, the P6 serial Enable/disable shell and kernal messages. What should it be set to?
Re: GPS error
Posted: Fri Apr 21, 2017 3:06 pm
by Martyparty
It works now! Thank you so much!!
Do you know any simple way to get the information into a coordinate system? And how can I get the positions without being logged on the Raspberry, but see it online on a computer?
Re: GPS error
Posted: Fri Apr 21, 2017 3:31 pm
by bensimmo
Martyparty wrote:It works now! Thank you so much!!
Ah you collect the data from /dev/serial0
Strip it and take the bits you need. (Do note and check the coordinate system in use)
And then do whatever you want with it.
In python the module pynmea2 (you'll probably need to install it) can do a lot of it for you and then just a few lines of code is needed.
Then read the file or send it somewhere else.
I do believe gpsd if setup can be use to remotely connect directly to it's stream from another computer, I've not done or tried it.
Something in my to-do but since we've not used GPS here for sometime and nobody seems to need it yet, I've not bothered.
Re: GPS error
Posted: Fri Apr 21, 2017 3:34 pm
by Martyparty
bensimmo wrote:Martyparty wrote:It works now! Thank you so much!!
Ah, I understand. But is it necessary with a python script?
I still don't get cgps -s to work though, any explanations for this?
Re: GPS error
Posted: Fri Apr 21, 2017 3:42 pm
by bensimmo
Martyparty wrote:bensimmo wrote:Martyparty wrote:It works now! Thank you so much!!
Cgps needs gpsd setup and running if i remember rightly.
Use python only if that's what you want to use, you have a stream of data coming into /dev/serial0 interface or read it and do with it in many different ways.
That's probably another topic, if you need advice start something new up as a project and see what people can come up with.
It's more than likely been done and just needs tweaking for a 2017 Raspian setup.
Re: GPS error
Posted: Tue May 09, 2017 9:36 am
by profeciak
And how exactly You made it works? I still cannot make it run
