coffeeman
Long-range WIFI dongle reccomendation
Mon Sep 17, 2012 1:40 pm
Can anyone reccomend a log-range WIFI dongle from the raspberry pi?
Thanx
f32mark
Re: Long-range WIFI dongle reccomendation
Mon Sep 17, 2012 2:01 pm
I've read about people increasing wifi ranges on a USB dongle by simply adding a home made antenna. here is a good place to start: http://en.wikipedia.org/wiki/Long-range_Wi-Fi
cave
Tue Sep 18, 2012 12:20 pm
There are some cheap (4$) USB Wifi Dongles out on eBay Ralink rt2800usb RT5370 chipped.
for 6$ there is also a version available with a RP-SMA Connector, where you can add your bigger antenna...
http://cavebeat.blogspot.co.at
Grumpy Mike
Tue Sep 18, 2012 4:55 pm
f32mark wrote:I've read about people increasing wifi ranges on a USB dongle by simply adding a home made antenna.
While this will work, in many cases it makes the equipment illegal, as it is not the system that was tested and received type approval. In the UK this is the case anyway.
malakai
Tue Sep 18, 2012 5:52 pm
Just curious what do you define long range
while a small usb adapter won't have much range
http://ogemraywireless.en.made-in-china ... Price.html
Something like this with a 2dBi I think would go twice as far.
http://ogemraywireless.en.made-in-china ... 3S4T-.html
An ultimate would be a cantenna which is strictly directional just need the right connector on a usb card. But I guess is illegal in UK :(
http://www.cantenna.com/
If cabling is an option CAT5 can go pretty far so this is possible get the adapter closer to the signal. Not sure the antenna but larger device so more surface.
http://www.iogear.com/product/preview.php?p=GWU627
http://www.raspians.com - always looking for content feel free to ask to have it posted. Or sign up and message me to become a contributor to the site. Raspians is not affiliated with the Raspberry Pi Foundation. (RPi's + You = Raspians)
Brewgod23
Wed Oct 31, 2012 5:50 pm
If I buy "Ralink rt2800usb RT5370" wifi adapter I will not have to use the Occidentalis v0.2 (Adafruit Raspberry Pi Educational Linux Distro) to be able to use a Wifi adapter? I believe this Distro is for Wifi adapters with RTL8192cu chip-set.
Thanks for the help.
ferjeezy
Wed Nov 07, 2012 2:21 am
I have that same dongle and it works perfectly fine in the Raspbian image.
Brewgod23
Wed Nov 07, 2012 2:35 am
ferjeezy,
which gong do you have? Did you have to do anything special to make it work? Or did it straight out of the box, plug and play?
Grauhut
Sat Nov 10, 2012 9:51 am
coffeeman wrote:Can anyone reccomend a log-range WIFI dongle from the raspberry pi?
Alfa Awus036H or NH
http://www.alfa.com.tw/in/front/bin/ptd ... Category=0
