DJI Phantom 1 Battery for Pi
Posted: Thu Jan 26, 2017 3:19 am
by dyerama
I am wanting to utilize my DJI Phantom Batteries to power my Pi 3 with 7" touchscreen monitor. Here is the battery I have:
http://www.dronefly.com/collections/pha ... y-2550-mah
Mine are actually 2400mAh, I have 4 of them and I don't use the drone very often, so wanted to see if using this:
https://www.amazon.com/dp/B01MEESLZ6/re ... INBM&psc=1
...would work to power the Pi and touchscreen so I can have a completely portable solution for my Pi.
The battery output is 11.1 volts.
Re: DJI Phantom 1 Battery for Pi
Posted: Thu Jan 26, 2017 4:53 am
by mikronauts
you need a dc-dc step down converter with 5v 3a output (2.5a maybe ok too)
dyerama wrote:I am wanting to utilize my DJI Phantom Batteries to power my Pi 3 with 7" touchscreen monitor. Here is the battery I have:
Posted: Thu Jan 26, 2017 5:11 am
by dyerama
Thank you, that is what the amazon item does.
Posted: Thu Jan 26, 2017 5:16 am
by mikronauts
yes ... i forgot to check the link
you could also likely use a car usb charger, if rated at 2.5a+
dyerama wrote:Thank you, that is what the amazon item does.
Posted: Thu Jan 26, 2017 6:22 am
by dyerama
I'm sure I can find something about this, but while I'm here, is there a way I can monitor the life of the battery?
Posted: Wed Feb 08, 2017 2:50 am
by dyerama
I have not found a solution for a battery monitor, if anyone has a suggestion, it would be appreciated.
Also, is it possible to plug the touchscreen in using the available power port to avoid the low voltage lightening warnings?
Posted: Wed Feb 08, 2017 8:48 am
by aBUGSworstnightmare
It you see a low voltage warning your DC/DC is too weak.
Maybe the wrong forum for asking how to monitor DJI battery :?
