danjperron
Re: NRF24L01 RF Transceiver
Sat Feb 17, 2018 4:14 am
Ok I was able to check your code and compare to my code.
I read my notes and I found out that I had that problem.
You need to set the SPI clock to 8Mhz!
insert the spi clock speed at line 374 in lib_nrf24.py
def begin(self, csn_pin, ce_pin=0):   # csn & ce are RF24 terminology. csn = SPI's CE!
        # Initialize SPI bus..
        # ce_pin is for the rx=listen or tx=trigger pin on RF24 (they call that ce !!!)
        # CE optional (at least in some circumstances, eg fixed PTX PRX roles, no powerdown)
        # CE seems to hold itself as (sufficiently) HIGH, but tie HIGH is safer!
        self.spidev.open(0, csn_pin)
        self.spidev.max_speed_hz=8000000
        self.ce_pin = ce_pin
After that your python code should work!
_lev_
Tue Feb 20, 2018 8:36 am
It works !
I owe You one !
Just from curiosity what are the differences between Your and his library?
danjperron
Tue Feb 20, 2018 12:17 pm
My python library is the same but I did struggle with it 2 years ago.
I don't remember if I found the solution on the net or it was by trial on error.
kevinsuharto
Thu May 07, 2020 6:29 pm
Hello Sir
i want to ask,did you have any Library that support for MQTT-SN Client or MQTT-SN Gateway?
