MJ5
[Help] ADC @ 12.8KHz
Mon Dec 19, 2016 10:44 am
Hi there, I am just looking for an ADC I could work at 12.8KHz, is there anyone use that frequency or knows any ADC working at that frequency?
I would like 2 channels or even 4, and 12 bits of resolution.
It will be used for working with both Wevelet and Fast Fourier Transforms.
Thank you guys!
joan
Re: [Help] ADC @ 12.8KHz
Mon Dec 19, 2016 11:52 am
viewtopic.php?p=514141 may be useful.
PeterO
Mon Dec 19, 2016 11:54 am
At that sampling rate and resolution you are more in the territory of audio codecs than plain ADCs. Look for either a USB or I2S device with line level (not microphone) inputs.
PeterO
joan
Mon Dec 19, 2016 12:05 pm
You can get results. I used three cheap mics and did 10 bit sampling at 25ksps. This was an attempt to locate a sound source.
MJ5
Mon Dec 19, 2016 12:14 pm
Ok thanks, I will take a look at it. It is going to be used to measure the Electric Power consumed and at that freq it nails the transitory effects.
PeterO
Mon Dec 19, 2016 12:39 pm
MJ5 wrote:at that freq it nails the transitory effects.
What does that mean ?
PeterO
