Kuman Temp18B20 (SOLVED)
Posted: Fri Oct 28, 2016 5:38 pm
by PiInYourEye
When I type LS to get a list of devices I only get a return answer of the following
w1_bus_master1
Some times I get a few numbers showing but they always change value.
I did connect a wrong resistor (labelled wrong from the supplier) and ended up
connecting a 47ohm resistor between the power and negative or in some fashion (can't remember now)
as to where the sensor was getting really hot. Maybe it's damaged?
Any advice?
Re: Kuman Temp18B20 (SOLVED)
Posted: Mon Oct 31, 2016 4:53 am
by PiInYourEye
Had it wired wrong on the bread board. I didn't know the bread board was split into two separate connection boards (2IN1)
