milkybar_ton
Model A ethernet?
Fri Sep 23, 2016 7:21 pm
I was wandering if it would be possible to add ethernet to the original Model A pi?
Had a look around the web and i can't find anything.
Someone has reverse engineered a model B by removing stuff but nothing the other way around
cheers
Milky
Laurens-wuyts
Re: Model A ethernet?
Fri Sep 23, 2016 7:29 pm
You can use a USB to ethernet adapter.
As the Ethernet/USB hub IC isn't populated on the RPi A, you can't just solder on the Ethernet port.
If you rely wanted, you could solder the Ethernet IC on, but I don't think it's worth the effort/price. :)
Laurens
Sat Sep 24, 2016 11:57 am
Three options:
1. USB ethernet
2. USB WiFi
3. SPI ENC28J60 ethernet
All three are well documented on here.
This is a doctor free zone.
Sat Sep 24, 2016 8:43 pm
DougieLawson wrote:Three options:
1. USB ethernet
2. USB WiFi
4. USB Gadget mode networking
(will only work on the PI A, CM and Zero models)
Sat Sep 24, 2016 8:58 pm
I'm not sure that works on an A+ due to the wiring of the full size USB-A socket.
Sat Sep 24, 2016 9:13 pm
DougieLawson wrote:I'm not sure that works on an A+ due to the wiring of the full size USB-A socket.
Why not? Ok, so the OTG ID signal is set to "Host" mode only, but loading the gadget mode driver will override that. That data lines are direct with no hub chip in the way.
You would need a custom USB cable to make it work though.
plugwash
Sat Sep 24, 2016 10:25 pm
milkybar_ton wrote:Hi,
Sure, the schematics label the A-specific and B-specific parts. So you should be able to remove the A-specific parts (a couple of zero ohm resistors IIRC) and fit the B-Specific parts (USB hub with ethernet chip, ethernet magjack and various support components).
Probablly easier to just buy a model B though.
milkybar_ton
Thu Sep 29, 2016 3:21 pm
It was soldering on an ethernet socket i was thinking about but i now realize it's a bit more complicated than that.
Thanks for the replies
milky
