aBUGSworstnightmare
Re: LVDS add-on for Raspberry models with 40pin GPIO
Sun Dec 01, 2019 4:32 pm
bird2000 wrote:
Sun Dec 01, 2019 12:19 pm
Thx, than the explanations and the way offered by Peter are correct and MichaRs comments targets to a other context. But the main questions about the new PCB you haven't answered - ETA and location?
ETA= When it's done
aBUGSworstnightmare
Thu Dec 26, 2019 2:51 pm
As a little Christmas present I want to show you what I've been working on: the LVDS4PI EVO --> an evolution step of the LVDS4PI.
The EVO has a simpler board layout, simpler DC/DC circuitry and a more advanced LVDS transmitter, now supporting JEIDA and VESA from a single board and with dual-channel LVDS output!
top view of the LVDS4PI EVO, connected to an RPi4 (mounted in an armor case)
LVDS4PI EVO driving a SVGA TFT during testing
LTolledo
Sun Dec 29, 2019 12:56 am
looks neat! up to what resolution does it support?
I've got a screen from my now defunct Vaio (15" 2K screen) and been looking for LVDS for that.....
Some people be like:
aBUGSworstnightmare
Sun Dec 29, 2019 7:15 am
max resolution supported by the LVDS transmitter is QXGA = 2048×1536pixels.
I've only tested up to FHD (1920x1080) so far.
aBUGSworstnightmare
Sat Jan 04, 2020 8:12 am
Google Nexus 7 Gen1 display
... and yes! It can drive the Nexus 7 Gen1 display too
Raquena
Thu Feb 20, 2020 12:11 pm
Hello guys,
I've found a quite interesting IC for dual LVDS interface.
It seems to have the same functionality as the DS90, at lower cost and smaller footprint.
The problem: The footprint is so small that isn't suitable for regular cheapo PCB manufacturers...
https://datasheet.lcsc.com/szlcsc/1912 ... 410488.pdf
What do you think about it ?
Raquena
Re: LVDS add-on for Raspberry (SINGLE CLOCK, DUAL CLOCK?))
Thu Feb 20, 2020 12:19 pm
Hello again,
I just forgot to ask something else...
There are some screens using two clock differential pairs, some other only use one.
As far as I understood, the ones with two differential pairs are older, and the newer ones are using only one.
To keep backwards compatibility, the DS90C387 has both of them available.
If you only use one of them, the second one is left unconnected, right? (have read somewhere at the datasheet)
When using only one clock differential pair, does require a different DS90C387 pin configuration ???
is that what the DUAL pin is for ???
Sorry for the questions that may be trivial for some.
Thanks!
aBUGSworstnightmare
Fri Feb 21, 2020 5:40 am
Hello guys,
BGA package ... Easy to solder in a reflow oven
aBUGSworstnightmare
Fri Feb 21, 2020 5:44 am
Hello again,
Thanks!
Nothing is older or newer! This is dual channel LVDS were odd and even channels have their own clock.
What the pin is used for should be stated in the spec.
Sounds like you do not understand how the LVDS transmitters are working.
18.5in FHD (1920x1080pixel) dual-channel LVDS interface driven by LVDS4PI EVO
close-up of the connector
Example above is using an 18.5in Full-HD display module. (spec is here https://www.sharpsde.com/products/displ ... roductview) .
You usually need dual-channel if your displays resolution is bigger than WXGA (1366x768pixels).
