E_user
Is SD card dead?
Sat Aug 18, 2012 10:34 am
I tried Arch, OpenELEC and XBian by dd bs=1M if=*.img of=/dev/mmcblk0 and then I tried Raspbian, but it (Raspian) doesn't works.
So I did dd bs=1M if=/dev/zero of=/dev/mmcblk0 and tried to make new partition table by gparted, but it doesn't work.
It's going to new SD card? :D
Thank you
DexOS
Re: Is SD card dead?
Sat Aug 18, 2012 2:22 pm
E_user wrote:Hi,
Thank you
A very simple way to test it, format it fat32 if that works, get DexBasic zip from here: http://www.dex-os.com/DexBasic/DexBasic.htm
In the zip you will find a folder called boot, add the files in that folder (not the folder, just the files) to to the sd card, plus any of the kernel.img files from the tut folders.
And see if that works.
Batteries not included, Some assembly required.
domesday
Sat Aug 18, 2012 3:44 pm
:? Gertboard ?
DexOS
Sat Aug 18, 2012 4:17 pm
domesday wrote::? Gertboard ?
Yes, i think he posted it in the wrong part of the forum.
Gert van Loo
Sat Aug 18, 2012 8:35 pm
Maybe it is a subtle request for an SD card interface on the next version of the Gertboard :-)
E_user
Mon Sep 03, 2012 5:51 pm
DexOS wrote:A very simple way to test it, format it fat32 if that works, get DexBasic zip from here: http://www.dex-os.com/DexBasic/DexBasic.htm
Thank you, I will try it.
E_user
Mon Sep 03, 2012 5:52 pm
Gert van Loo wrote:Maybe it is a subtle request for an SD card interface on the next version of the Gertboard :-)
Good notice :)
