GavynSykes
Microstack GPS problem
Thu Apr 07, 2016 6:17 pm
Hi guys.
I bought a Raspberry Pi 3 Model B, a microstack baseboard and a microstack GPS.
I followed the instructions written in the official documentation but I can't connect to the GPS.
Basically, the GPS led flashes so it means it has find a gps fix, but I can't see any data from the PI.
For example, if I try "cat /dev/ttyAMA0" i get always nothing. I already used raspi-config to disable kernel serial and to enable i2c and spi.
Also if I try "stty -F /dev/ttyAMA0 ispeed 4800 && cat </dev/ttyAMA0" I get an error.
Anyone has any advice, please?
Or maybe these modules are not compatible with Pi 3?
Thanks a lot!
Marco
izzycm
Re: Microstack GPS problem
Thu Apr 21, 2016 8:30 pm
Im having this same issue, I'll be looking into it for the next few days, if I find something i'll let you know
GavynSykes
Thu Apr 21, 2016 9:31 pm
thanks a lot!
i can't go any further...
Douglas6
Thu Apr 21, 2016 10:27 pm
Have you tried ttyS0 instead of ttyAMA0?
GavynSykes
Fri Apr 22, 2016 11:43 am
Yes.
I tried also with a different board, a Raspberry Pi GPS HAT. The behaviour is the same: I got a gps fix from the led on the board, but I'm not able to communicate with the board in any way.
Maybe it's something related to the version 3 of the Pi? But the last gps board supports Pi 3.
I tried to reinstall raspbian, tried different configurations, I don't have any clue on how to resolve this issue...
Stingray13
Thu Jun 23, 2016 5:54 pm
I'm having the same problem!
Have tried numerous scripts, patches and tricks! None have worked!
Are we missing something here???
GavynSykes
Tue Jun 28, 2016 8:46 am
I finally found a solution:
On the Pi 3, there are more steps to use serial, you have to disable the BT.
Edit config file:
sudo nano /boot/config.txt
Add this at the bottom:
dtoverlay=pi3-disable-bt-overlay
Then run this:
sudo systemctl disable hciuart
