DollarAkshay
How does a 4 pin Infrared Object Sensor work ?
Wed Feb 17, 2016 4:16 pm
Can someone tell me how this IR sensor works ? I would be glad if you could point me to a tutorial or a blog that uses this exact component. I really need your help.
High Resolution Images of the Back and front here : http://imgur.com/a/YLewm
NOTE : This sensor has 4 pints (5V, GND, OUT, OUT) and all the blogs that i have seen online either have 3 pins or a white hemisphere on the module.
DollarAkshay
Re: How does a 4 pin Infrared Object Sensor work ?
Mon Mar 07, 2016 7:51 am
Please Help someone ?
BMS Doug
Mon Mar 07, 2016 9:08 am
You can see the labeling of the components:
  • IR TX would be Infra-Red Transmitter.
  • IR Rx will be Infra-red Receiver.
  • Output LED will turn on whenever the outputs would be on.
  • Calibration (R3) variable resistor will determine sensitivity.
  • IC will cause the outputs to be on when the IR detects a nearby object.
This page should help, his circuit is fundamentally identical.
I found his page by Googling the search terms: "IR object detection circuit diagram".
Doug.
tenochtitlanuk
Mon Mar 07, 2016 10:04 am
I think you are confusing two different TYPES of circuit.
What you have is a 'retro-reflective' device, which transmits a near-IR signal and detects its reflection from a nearby object.
The 3-pin ones with a white dome are passive detectors of heat radiation further into the IR from warm objects nearby.
They are NOT interchangeable.
boyoh
Tue Mar 08, 2016 8:44 pm
The IR object sensor , as two IR LEDs 1 Transmitter TX led. 1 Receiver RX
1 led showing object signal received. A IR signal is transmitted , this signal
Is reflected back off the object and processed as a out put signal
The 4 connections ( 5v+ / gnd) ( OUT) (OUT )
Some multi meter testing might might tell what the OUT signals are
Test between GND and each OUT terminal ( intern) ON & OFF
Make not of reading ( volts) There is a possibility of using a Opto Isolator
To inter face withe the Pi
BoyOh ( Selby, North Yorkshire.UK)
Some Times Right Some Times Wrong
