Page 4 of 4
Re: PiZero Ethernet pHAT
Posted: Sat Jan 16, 2016 3:12 pm
by adun
Thanks to clear this up. :) So without adding a mux for the data line this would not work.
Back to SPI1 solution.... :(
PS:
Perhaps it would be easier to use SPI1 for the light control so no specific driver is needed.
Posted: Sat Jan 16, 2016 3:53 pm
by karrika
Actually no. The SPI1 solution is no longer interesting. There is no sensible use case in it as seen in my previous entry.
Posted: Tue Feb 02, 2016 1:47 pm
by adun
Here is the DT overlay I've made to enable
SPI0 with additional CS on GPIO 5,6
SPI ethernet and PWM audio. So no longer wiring pi is needed to set PWM on GPIO 12,13.
GPIO 5: SPI0_CE3 unused
GPIO 6: SPI0_CE2 unused
GPIO 7: SPI0_CE1 unused
GPIO 8: SPI0_CE0 ENC28J60 CS
GPIO 9: SPI0_MISO
GPIO 10: SPI0_MOSI
GPIO 11: SPI0_SCLK
GPIO 12: PWM
GPIO 13: PWM
GPIO 25: ENC28J60 Reset
Put the code below in a file called miscap-overlay.dts and compile it using:
sudo apt-get update
sudo apt-get install device-tree-compiler
dtc [email protected] -I dts -O dtb -o miscap-overlay.dtb miscap-overlay.dts
sudo cp miscap-overlay.dtb /boot/overlays
Then add "dtoverlay=miscap" to /boot/config.txt and reboot.
Overlay for MisCap pHAT for the Microchip ENC28J60 Ethernet Controller
and 2-channel PWM Audio on GPIO 12,13
Enables SPI0 using spi-bcm2835 driver with additional CE3 on GPIO 5 and CE2 on GPIO 6
/dts-v1/;
/plugin/;
compatible = "brcm,bcm2835", "brcm,bcm2836", "brcm,bcm2708", "brcm,bcm2709";
/* SPI0 */
[email protected] {
      target = <&gpio>;
      __overlay__ {
          spi0_pins: spi0_pins {
              brcm,pins = <7 8 9 10 11>;
              brcm,function = <4>; /* alt0 */
   [email protected] {
      target = <&spi0>;
      __overlay__ {
         #address-cells = <1>;
         #size-cells = <0>;
         pinctrl-0 = <&spi0_pins &spi0_cs_pins>;
         status = "okay";
         cs-gpios = <0>, <0>, <&gpio 6 1>, <&gpio 5 1>;
         /*The first two <0>s request that native CS's 0 and 1 are used
         (even though the driver will convert them to GPIO CS's),
         and GPIO's 6 and 5 are used as active-low chip selects 2 and 3. */
         [email protected]{
              compatible = "spidev";
              reg = <0>;	/* CE0 */
              #size-cells = <0>;
              spi-max-frequency = <500000>;
          [email protected]{
              reg = <1>;	/* CE1 */
              #size-cells = <0>;
         [email protected]{
            reg = <2>;   /* CE2 */
            #size-cells = <0>;
         [email protected]{
            reg = <3>;   /* CE3 */
            #size-cells = <0>;
/*reserve the extra GPIO 5 and 6 so no other drivers can claim them + mark them as outputs */
   [email protected] {
      target = <&gpio>;
      __overlay__ {
         spi0_cs_pins: spi0_cs_pins {
            brcm,pins = <5 6>;
            brcm,function = <1>; /* out */
/* enc28j60 enthernet */
   [email protected] {
      target = <&spi0>;
      __overlay__ {
         /* needed to avoid dtc warning */
         #size-cells = <0>;
         status = "okay";
         [email protected]{
            status = "disabled";
         eth1: [email protected]{
            compatible = "microchip,enc28j60";
            pinctrl-names = "default";
            pinctrl-0 = <&eth1_pins>;
            interrupt-parent = <&gpio>;
            interrupts = <25 0x2>; /* falling edge */
            spi-max-frequency = <12000000>;
            status = "okay";
   [email protected] {
      target = <&gpio>;
      __overlay__ {
         eth1_pins: eth1_pins {
            brcm,pins = <25>;
            brcm,function = <0>; /* in */
            brcm,pull = <0>; /* none */
/* PWM */
  [email protected] {
      target = <&gpio>;
      __overlay__ {
         pwm_pins: pwm_pins {
            brcm,pins = <12 13>;
            brcm,function = <4 4>; /* Alt0 */
   [email protected] {
      target = <&pwm>;
      __overlay__ {
         pinctrl-0 = <&pwm_pins>;
         status = "okay";
Posted: Tue Feb 02, 2016 2:56 pm
by karrika
Thank you! I was just starting to Google what needs to be done for the audio bits. I have to download this and test it out. There is an eeprom on the board so I should be able to insert this code onto the chip. When the PiZero DeviceTree is fully operational the setup should be automatic.
About the future models I believe it may be a good idea to just expose the different CE0-CE2 signals and keep the bus at SPI0. Added 5V->3.3V could be good. Diode protections to audio pins.
And move the ENC module a little towards the 40 pin header.
Anything else?
Posted: Tue Feb 02, 2016 3:15 pm
by adun
Yes I think also those changes are good. We must only consider if we keep the ethernet on those pins or move it to other GPIOs for CE and/or reset. That would make it compatible with other SPI HATs , SPI display or SD1 SDIO devices etc. The miscap overlay could then easily be changed...
For the audio here are the B+ schematics where they use a driving buffer : https://learn.adafruit.com/introducing- ... io-outputs
PS:
I updated my overlay above: Now the overlay should enable SPI by itself and for testing purpose I added additional chip select (GPIO-CS) where we can move the enc28j60 CS if needed.
GPIO 5: SPI0_CE3
GPIO 6: SPI0_CE2
For miscap SPI0 with additional CS could be exposed.
Posted: Fri Apr 08, 2016 7:01 pm
by karrika
I just made my first eeprom test on Miscap. Only good news :D
The overlay created by adun can be added into the eeprom. This means that a stock Jessie image needs NO EDITING at all. No need for anything in /boot/config.txt.
Just power it on and Ethernet works over enc28j60. The audio is also automatically mapped to Miscap headphone socket.
I will post the code and instructions of how to update existing Miscap's during the weekend.
HAT's are amazing creatures. Miscap is actually HAT complient except for the form factor.
It is also nice to see that PiZero works together with HAT's just like the other Pi's.
Re: Miscap - PiZero Ethernet pHAT
Posted: Sat Apr 09, 2016 1:07 pm
by karrika
There is now a tutorial and instructions of how to program the eeprom on Miscap. Enjoy http://discohat.com/miscap/
Posted: Sat Apr 09, 2016 9:03 pm
by adun
Nice to hear that everything is working ;)
The tutorial you made is very good, also for general information how HAT eeprom works.
If the additional SPI0 CS are no longer needed for the final version, I can remove them from the code as those were just for testing.
Posted: Sun Apr 10, 2016 9:47 pm
by DougieLawson
The only thing I couldn't work out was whether
dtparam=i2c_vc=on
can be removed from /boot/config.txt after the pHAT eeprom stuff is written.
I've currently got that left in and GPIO12 & 13 have the right status.
Posted: Sun Apr 10, 2016 11:00 pm
by adun
dtparam=i2c_vc=on
is to get acces to i2c0 from userspace. This means that i2c0 is now controlled by ARM no longer by the GPU (firmware) as it usually is.
You can safely remove this line after the code is written to the eeprom.
The firmware loads the stuff from the eeprom during boot by muxing i2c0 to GPIO 0,1.
After that GPIO 0,1 are set as inputs.
But as the PiZero has no CSI/DSI there is no need that the GPU controlls i2c0. So if you let dtparam=i2c_vc=on you gain a second i2c bus.
Posted: Sun Apr 10, 2016 11:08 pm
by DougieLawson
I did another reboot, my MAX7219 needed to move to SPI1 so I rewrote the eeprom (because when I read it back there was a byte missing), took the i2c_vc stuff out and it's still working.
Looks like I met a bug in the eepflash.sh stuff (and I can't be bothered to look deeper because it's working right now).
Posted: Fri Aug 19, 2016 6:42 am
by karrika
Stop the press - latest news.
The audio channels of Miscap are sometimes swapped.
If you use Miscap with a RPi2 or RPi3 everything is ok.
If you use it on a RPi1 or PiZero then the left and right channels are swapped.
There was also an error in setting up the audio pins for the latest firmware.
The correct way is:
    /* Audio */
    [email protected] {
      target = <&audio_pins>;
      __overlay__ {
The previous blob was connecting pwm outputs to the pins that happened to do the same thing. But this is the correct way. You need to have a very recent firmware for this to work.
I am still hoping for the talented guys behind the fimware to invent a patch by which the left and right channels would go to the same pins on all models.
