AdamK
Composite input via camera input
Thu Nov 19, 2015 8:08 am
Hello
I'm looking if there are any addon boards that allow to capture composite signal using camera interface. I know, there are off-the-shelf IC chips that do required conversion, but I do not have skills required to do it myself, so, I'm looking for out-of-the-box solution for RPi. Is there any?
Re: Composite input via camera input
Thu Nov 19, 2015 3:49 pm
AdamK wrote:Hello
So you have a Digital Camera with Composite Output ?
If so search for STK1160 USB Capture Card: http://www.linuxtv.org/wiki/index.php/S ... re_devices
RPi 4B 4GB (SSD Boot)..
AdamK
Thu Nov 19, 2015 10:25 pm
I'm not intrested in solution that uses USB - I need the bandwidth for Ethernet.
mikronauts
Thu Nov 19, 2015 10:39 pm
Then you are out of luck.
No such "camera/CSI/video" board exists. It cannot even exist, as the interface is proprietary and undocumented.
Before you ask, GPIO is also out - to slow for such a digitizer.
AdamK wrote:I'm not intrested in solution that uses USB - I need the bandwidth for Ethernet.
AdamK
Fri Nov 20, 2015 6:56 am
mikronauts wrote:Then you are out of luck.
This thread claims something else: viewtopic.php?f=63&t=20159
ghans
Fri Nov 20, 2015 7:34 am
The fact that the mentioned thread never came to an meaningful conclusion says it all.
ghans
6by9
Fri Nov 20, 2015 8:35 am
It looks like the analog devices adv7281 does do composite, s, or component video to csi2. There's no support for it though on Pi, so interfacing to it would be up to you.
You can get access to the raw csi2 peripheral - see the camera forum thread "Raw sensor access/Csi2 peripheral". It's not trivial though, and no guarantees that the incoming data is in a format that is particularly useful (these chips tend to produce yuyv, and very little on the Gpu will deal with that natively).
I very much doubt anyone will have produced an appropriate board to do what you want - you'll have to get your own made, if you can get a supply of the chips in small quantities.
atestani
Sun Jul 24, 2016 1:14 am
If you are still looking for the video capture addon, check this out:
viewtopic.php?f=43&t=154013
