I bought a cheap LCD to play around with, but I'm not sure what model it is.
The only markings on it I can see are:
3.5 inch RPi LCD V3.0 HVGA 480X320. There is a XPT2046, 74HC04D, 74HC4040D, and 2 74HC4094D chips on the back. Is there a way to determine which driver I need to use in software?
I was following this guide:
http://www.circuitbasics.com/setup-lcd- ... pberry-pi/
and looking through this driver:
https://github.com/notro/fbtft/blob/mas ... t_device.c
There are ~50 LCD models to choose from in that driver.
I got it from here
http://www.ebay.ca/itm/221822335725?_tr ... EBIDX%3AIT
The seller provided an image that got the LCD to work. Still would be nice to understand how to do it on a virgin OS.
https://mega.nz/#!HhJwGLTb!5rc8PPTlUQe2 ... d1hef08AWU
This is the interface to the LCD
http://i.imgur.com/uoTmf5m.png
identifying TFT LCD
Re: identifying TFT LCD
I was following the same guide for a different touch screen without success.
Were you able to display images properly in the screen?
I bought a very similar looking board from taobao.com
The seller provided a raspbian .img file which I download but I cannot get the screen to work (white screen, occasionally flickering).
I did dig out some info through
I am not 100% convinced that the distribution given works with the LCD (the item I bought is dis-continued but the seller provided another item that has identical specifications - 3.5" IPS 15fps 480x320 resolution - but I suspect it has a slightly, or altogether different, controller.
The distribution has built the TFT support into the kernel so I cannot check what has been loaded via
My questions are:
[*]Is there any way I can extract some information of what driver has been used, or tried to use, for the TFT via that half working distribution? As far as I know, a GPIO/ SPI connection will not gather connected hardware information...
[*]How can I load up a number of, if not all, the drivers written by https://github.com/notro/fbtft and try it until it works?
dmesg
[ 3.246933] ads7846 spi0.1: touchscreen, irq 187
[ 3.264671] input: ADS7843 Touchscreen as /devices/platform/bcm2708_spi.0/spi_master/spi0/spi0.1/input/input0
lsmod
The Notro Drivers are included in a fully updated Raspbian OS https://github.com/notro/fbtft/wikicsvke wrote:I bought a very similar looking board from taobao.com
I did dig out some info throughCode: Select all
dmesg
I am not 100% convinced that the distribution given works with the LCD (the item I bought is dis-continued but the seller provided another item that has identical specifications - 3.5" IPS 15fps 480x320 resolution - but I suspect it has a slightly, or altogether different, controller.Code: Select all
[ 3.246933] ads7846 spi0.1: touchscreen, irq 187 [ 3.264671] input: ADS7843 Touchscreen as /devices/platform/bcm2708_spi.0/spi_master/spi0/spi0.1/input/input0
The distribution has built the TFT support into the kernel so I cannot check what has been loaded viaMy questions are:Code: Select all
lsmod
The information is out there....you just have to let it in.
My other Linux machines are a ChromeBox & Intel CoreDuo Desktop
added a link to the image provided by the seller to my first post.
I bought a display off Amazon described as [ SainSmart 3.5" inch TFT LCD 240x320 RGB Pixels Touch Screen Display Monitor For Raspberry Pi for Model B & B+] and sold by: Sain Store. What I received is the 320x480 display you described. I am also trying to verify the model before I try to set it up.
same problem here .
only thing i know about display model is : it contains a text on its back : 3.5 inch RPi LCD V3.0 HVGA 480x320
tried notro drivers...
tried waveshare drivers ...
enabled Raspbian SPI module from raspi-config...
but still cant get display to working. just white screen appears.
what should i do ?
thanks for help
what should i do ?
thanks for help
Contact seller and ask them how to get it working. If they can't, get your money back.arminkz wrote:what should i do ?
thanks for help
see my post here
viewtopic.php?f=45&t=136558
I just got the same unit working on my PI B
What I would like to do is be able to "diff" a clean image and the modified image to find out exactly which drivers were used, what files have been modified for their use to be able to create a standalone install package that be used on a clean install.
I've also used the "image" but the accompanying documentation is almost worthless and doing a dist-upgrade seems to totally bork it
I have actually analysed the settings used on the image linked to above.TheQuestor wrote:What I would like to do is be able to "diff" a clean image and the modified image to find out exactly which drivers were used, what files have been modified for their use to be able to create a standalone install package that be used on a clean install.
They use an old method (notro's flexfb) that is not supported anymore and also not necessary.
I checked the settings they use and have come to the conclusion that they are the same as those used for the Waveshare screens.
That's why I suggested trying the Waveshare overlays at https://github.com/swkim01/waveshare-dtoverlays
Using the device tree overlays makes configuration much easier and there is less chance of breaking them when updating the system
It is simple and easy. Go through the link below maybe it can help you.
http://adityaanand.blog.com/2016/05/22/ ... -lcd-v3-0/
I also have the exactly same screen can someone tell where i can get the drivers
Yes It Works , it is the only tutorial i found Thanks Aditya Anandadityaanand wrote:It is simple and easy. Go through the link below maybe it can help you.
I have this same TFT and the blog link indicated above no longer works.
Does anyone have the instructions to making this TFT work on Pi3?
Thanks!
Thanks!
Is this working on RPi 3?http://webcache.googleusercontent.com/s ... clnk&gl=us
Quote cmhealth
Had this screen for awhile and never actually got it to work right. Is there a way to make it work with kodi, or MATE?
Help Me With the Issues Pleasethat spells "HMWIP" also, you have a good monitor to see this REALLLLLY?
The url wont work.
I finally found the full information :
http://ozzmaker.com/piscreen-quick-star ... 20PiScreen
and installation instructions :
http://ozzmaker.com/piscreen-driver-ins ... uctions-2/
Although, after following the installation instructions, the screen I have behaves weirdly: there seems to be a symmetry between the point where I click on the screen and the real place of the pointer. Depending on the argument of the rotate instruction in
the symmetry is vertical or horizontal. I haven't figured out yet how to fix this and have the pointer exactly where I touch on the touchscreen. Hope this helps...
dtoverlay=piscreen,speed=16000000,rotate=90
It was working but was a bit too slow so, I Increased the speed After setting Everything back to normal the screen is not working properly. The display is fine , but the touch is not responding. Please help! Did I BROKE it ?
I would also wants to design LCD (mono LCD and colored LCD) for Pi, such LCDs like: www.truevision-tech.com/graphic.html
