Serial via the GPIO
Posted: Fri Jul 20, 2012 3:14 pm
by jhereg
I want to use my PIs to connect to some of the Cisco devices on my network at home. From what I've been readingI should be able to take an adapter that works w/ TTL and go to RS232. A couple of devices I've found on Ebay are
http://www.ebay.com/itm/150760914459?ss ... 081wt_1314
http://www.ebay.com/itm/290698076539?ss ... 735wt_1314
Any warnings or better suggestions? My understanding is I should be able to plug those in, configure the serial port and then telnet across it. Am I on the right path with those?
Re: Serial via the GPIO
Posted: Fri Jul 20, 2012 8:31 pm
by Gert van Loo
I have never heard of a converter that does not need power.
Neither of those pages tell me if it is 5V or 3V3.
The adapter must produce 3V3 signals only.
Posted: Fri Jul 20, 2012 8:42 pm
by jhereg
Gert van Loo wrote:I have never heard of a converter that does not need power.
That's why I was asking. It appears they both have a connector for power, ground, TXD, and RXD. One of them is showing a MAX 3232 chip which is what I *THOUGHT* was mentioned as the proper chip to use, but I'm not an electronic guy. I can make it work once I connect it but I prefer not to let the magic smoke out. :shock: Does anyone know of a premade solution that would give me a serial port on a PI?
Posted: Sat Jul 21, 2012 7:45 pm
by Gert van Loo
Do you need a DB9 connector?
We are using TTL directly to USB from FTDI.
(You PC does not see that it is USB, your PC sees it as a standard COM port so you
can use it will all existing serial software).
FTDI nowadays even have a "Raspberry-Pi" version which has all the instructions how
to connect it to your board.
Posted: Sat Jul 21, 2012 7:52 pm
by jhereg
I've got a less than favorable opinion of USB -> Serial adapters when used for long term use. They seem to flake out. I've got several of them. I know I could use them. I was hoping to take advantage of the GPIO and get a real serial port.
Posted: Sat Jul 21, 2012 8:08 pm
by mahjongg
This adapter is probably "powered" with power extracted from an RS232 handshake line, an old trick really, but in the past it was done with just a few transistors, I have built several of those, even built a 300 Baud modem powered by the RS232 port.
Its easy enough to measure if the output is 3V3 or 5V, but if its 5V just use two resistors (2K2 and 3K3) do divide it to 3V. The 3V3 GPIO TxD output will directly drive a MAX(3)232 chip.
Posted: Sat Jul 28, 2012 2:13 pm
by raven_squire
Hello, I orederd this from e-bay
http://www.ebay.co.uk/itm/Pi-RS232-cabl ... 4aba4b7218
Item number: 320953086488
I dont understand alot about electronics eg 3.3v/5v and I wanted a complete solution. Do you think I will have any issues?
Steve
Posted: Mon Jul 30, 2012 12:48 pm
by TonyD
jhereg wrote:I want to use my PIs to connect to some of the Cisco devices on my network at home. From what I've been readingI should be able to take an adapter that works w/ TTL and go to RS232.
If you want to connect directly to the RPi Expansion Header I've made a small MAX3232 board which plugs directly onto it, see below. The schematic is on my blog as well if you want to build your own.
Posted: Tue Jul 31, 2012 2:51 pm
by wjousts
jhereg wrote:Does anyone know of a premade solution that would give me a serial port on a PI?
I have the same question. I want to use the RPi to interface with a proprietary device we have and provide a web interface to it (allowing us to ditch the Windows laptop and connect directly through the web from any web enabled device).
I can possibly try assembling something myself (this link looks interesting: http://codeandlife.com/2012/07/01/raspb ... ax3232cpe/) for a prototype, but ultimately I'd like something pre-assembled once I've worked everything out.
I saw an interesting suggestion on using this: http://www.suntekstore.com/goods-140026 ... oard_.html from here http://www.trainelectronics.com/RaspberryPi/, which is at least minimum assembly required.
Finally, from what I understand, there are actually two serial ports. I only need Tx and Rx (and Gnd, of course), but I do need to be able to configure the speed, parity, etc.
Posted: Wed Aug 01, 2012 12:45 am
by AndrewS
Another pre-assembled alternative along very similar lines http://www.tronisoft.com/prod.php?id=4205
Posted: Wed Aug 08, 2012 10:48 am
by doghousedean
just one thing you don't 'telnet' across the serial link, the cisco device will output directly to the console port, it will give you a prompt if you have login enabled or just let you in.
Posted: Wed Aug 08, 2012 1:57 pm
by jhereg
doghousedean wrote:just one thing you don't 'telnet' across the serial link, the cisco device will output directly to the console port, it will give you a prompt if you have login enabled or just let you in.
Yep. That was a bad way to phrase it. I normally use putty which is what I use for ssh and telnet. I suppose I should double check my post better before I hit submit. :lol:
Posted: Thu Jan 17, 2013 11:53 pm
by jfornango
I was considering using my Pi as a small-form terminal for configuring Ciscos. I figure it beats lugging a laptop out to client sites all the time. Anyway, I was trying to decide what the best software to use under Raspian would be. Like any good geek, I started by searching the forums, which brought me here.
In the course of reading this thread, a question came to mind. It's more for Gert (our resident Pi expert), but if anyone knows, feel free to speak up.
With all this discussion of building expansion boards for a serial interface, why not just run a DB-9 to the expansion header directly? (kinda thought that was what the UART was for)
Personally, my TrendNet USB serial port has served me well for years. I need to see if they have LINUX drivers for it.
Oh, so back to my original question, what would be the best program to use to get from a Pi to the Console port on a SUP?
Posted: Fri Jan 18, 2013 10:50 am
by TonyD
The UART on the Pi is a 3.3v interface while RS232 is nominally +/-12V interface, so connecting a DB9 connector and cable direct to your Pi and then hooking it to a RS232 port would be bad for your Pi.
Posted: Fri Jan 18, 2013 12:57 pm
by Gert van Loo
TonyD wrote:The UART on the Pi is a 3.3v interface while RS232 is nominally +/-12V interface, so connecting a DB9 connector and cable direct to your Pi and then hooking it to a RS232 port would be bad for your Pi.
Indeed. You might think "I just clip it to 0..3V" but that is not enough.
Most RS232 inputs need more then a 3V3 swing at their input. Even a 0-5V swing rarely work.
So I am afraid you really need a R232 converter.
Posted: Fri Jan 18, 2013 3:13 pm
by jfornango
Well... duh! :roll:
Wow.. haven't worked at the circuit level in almost 20 years. It's amazing the things you can forget.
I (and my Pi) thank both of you fine gentlemen for saving us from an inpromptu barbeque. :lol:
Posted: Sun Jan 20, 2013 9:12 pm
by TonyD
Glad to help :-)
