nigelibrown
Heber x10i Wheezy drivers now available.
Fri Jul 20, 2012 10:02 am
Just to let you know the latest drivers are available for the latest Raspbian Wheezy for Heber's x10i I/Oboard http://www.heber.co.uk/gaming-amusement/xline/buy-x10i/
More information available on website and forum.
http://www.heberforum.co.uk/forum/forum ... spberry-Pi
Installing x10i driver on rasbian (wheezy) fresh install.
Tips:
1. At your own risk use sudo -s, and you will be able to forget the sudo at the
start of each line.
1. Download the drivers from Heber website.
download "Development Kit(Raspberry Pi (Squeeze/Wheezy))" and select save from this
link.
http://www.heber.co.uk/support/download ... 0isoftware
2. Move and decompress the xline devkit, using the teminal.
cd ~/Downloads/
sudo cp -r ~/Downloads/xlinedevkit_arm.tar.gz /usr/src/
cd /usr/src/
sudo tar -xzvf xlinedevkit_arm.tar.gz
sudo rm xlinedevkit_arm.tar.gz
3. copy the xline driver.
cd /usr/src/xlinedevkit_arm/driver/
sudo mkdir /lib/modules/3.1.9+/extra
sudo cp xline.ko /lib/modules/3.1.9+/extra/.
sudo depmod
4. Installing the shared library...
cd /usr/src/xlinedevkit_arm/lib/
sudo cp -a fflyusb.so /usr/lib/.
sudo ln -s /usr/lib/fflyusb.so /usr/lib/libfflyusb.so
sudo cp -a libxlinecapi.so /usr/lib/.
5. Create x10i device permissions.
cd /etc/udev/rules.d
sudo touch 50-udev.rules
sudo chmod 666 50-udev.rules
sudo pico 50-udev.rules
*edit and add the following line to the newly created rules file:
KERNEL=="Xline_?",SUBSYSTEM=="Xline",MODE="666"
*save ^O RETURN
*exit ^X
*connect the x10i board.
6. Load the x10i kernel module.
sudo modprobe xline
7. Build and run C++ samples
cd /usr/src/xlinedevkit_arm/samples/
sudo make -f makefile.linux clean binaries
./fadedemo
8. Build and run the C examples.
cd /usr/src/xlinedevkit_arm/samplesc/
./fadedemo
