Turn off PCD8544 Display
Posted: Thu Jun 18, 2015 1:49 pm
by thuranga
has anyone a solution to turn off the PCD8544 display by software?
Greetings
thuranga
Re: Turn off PCD8544 Display
Posted: Thu Jun 18, 2015 9:26 pm
by FTrevorGowen
thuranga wrote:Hi,
Greetings
thuranga
After checking the datasheet, writing the "FUNCTION SET" command byte with the P(ower) D(own) bit set, ie. 0x24 to it should do that**. (Write 0x20 to wake it up in horizontal addressing mode).
Trev.
** NB: that applies to the display only. If you also require the backlight to be turned off/on that depends on the physical interface. FWIW, see some examples here:
http://www.cpmspectrepi.webspace.virgin ... Lvspi.html
http://www.cpmspectrepi.webspace.virgin ... lcdV2.html
http://www.cpmspectrepi.webspace.virgin ... dCacc.html
Posted: Mon Jun 22, 2015 11:03 am
by thuranga
Thanks for your answer! I will check it out :)
