benspring100
Deleted
Wed May 27, 2015 1:27 pm
Deleted
Lob0426
Re: Tontec 3.5" Screen - Only displaying white screen
Wed May 27, 2015 4:59 pm
Did you add the code to config.txt?
sudo nano /boot/config.txt
dtpram=spi=on
dtoverlay=mz9486
Edit xorg file fbdev fb0 to fb1
Yours may be slightly different below
sudo nano /usr/share/X11/org.conf.d/99-fab turbo.conf
"fbdev" "/dev/fb1"
Edit cmdline.txt
sudo nano /boot/cmdline.txt
fbcon=map:10
Richard
Motorola Lapdock with Pi2B
http://rich1.dyndns.tv/
benspring100
Wed May 27, 2015 5:03 pm
Lob0426 wrote:Did you add the code to config.txt?
dtpram=spi=on
dtoverlay=mz9486
"fbdev" "/dev/fb1"
Edit cmdline.txt
fbcon=map:10
Richard
Yes, I have done all of this - Is this with the MZ350i drivers/files?
Lob0426
Wed May 27, 2015 6:47 pm
I have the Tontec 3.5 MZ61581 display.
The drivers were included in the latest Raspbian updates.
Have you tried the latest update and upgrade. You may also try rpi-update to get the very latest kernel.
benspring100
Wed May 27, 2015 6:49 pm
Lob0426 wrote:I have the Tontec 3.5 MZ61581 display.
Yeah, I did both - Still just displays a white screen - never changes. Did this happen to yours?
benspring100
Wed May 27, 2015 6:53 pm
Could anyone help me over skype at all? Also this will work when it boots into the command line? As I havn't tried it on the startx GUI stuff.
benspring100
Wed May 27, 2015 6:56 pm
EDIT: Just tried doing "sudo raspi-config" and set it to boot to the GUI, nothing happend - Its still just a white screen
benspring100
Wed May 27, 2015 7:10 pm
Deleted
Lob0426
Thu May 28, 2015 1:14 am
I found this for your screen about getting a white screen. Hope it helps. Searched under Tontec mz9486. Look at the post from ttmz.
https://github.com/notro/fbtft/issues/222
benspring100
Thu May 28, 2015 12:51 pm
Lob0426 wrote:I found this for your screen about getting a white screen. Hope it helps. Searched under Tontec mz9486. Look at the post from ttmz.
Okay, in ttmz's post it says "copy the above code to fb_r61581.c to replace the ili9486.c" when he says replace the ili9486 - DOes he mean I need to delete that file? Also the bits in his code that are greyed - What does that mean? Its got a grey background - Does that mean I need to change that some place else?
Lob0426
Fri May 29, 2015 5:47 pm
I have not looked at that file. I would say that you are to look for the corresponding sections, denoted by the background color change, and replace those sections.
Create a new file by copying the ili9486.c file. Rename the copied file as fb_r62581.c. Then make the changes. When your done you can delete the old file. I would save a copy of it somewhere else just in case!
benspring100
Fri May 29, 2015 6:00 pm
Lob0426 wrote:I have not looked at that file. I would say that you are to look for the corresponding sections, denoted by the background color change, and replace those sections.
Thank you! Do you have Skype at all?
Lob0426
Fri May 29, 2015 7:03 pm
No I do not.
rudiratlos
Re: Deleted
Mon May 20, 2019 12:37 pm
with new version of raspian, the boot process get stuck.
removing fbcon=map:10 from /boot/cmdline.txt every thing went fine.
