Christoph1985
gpio_slew and gpio_hysteresis?
Tue May 19, 2015 10:09 am
can somebody please explain, what slew and hysteresis are for?
These are parameters you can find in the eeprom settings.
In which cases will I need this settings?
gpio_drive sets the maximal current for all usable GPIO pins? (for ex. 16 mA per pin?)
Thanks in advance
MarkHaysHarris777
Re: gpio_slew and gpio_hysteresis?
Tue May 19, 2015 11:44 am
Read the datasheet for your particular sensor. If you can read the datasheet as pdf all the better; you can 'find' "hysteresis" throughout the document.
You might also want to try googling for 'hysteresis' and read-up!
marcus
:ugeek:
Burngate
Tue May 19, 2015 3:55 pm
Hysteresis (for a digital input): a change from 0 to 1 occurs at a higher input voltage than a change from 1 to 0. There's never an input voltage that's undetermined.
Without hysteresis, there can be an input voltage that may produce either 0 or 1
Slew rate (for an output): in the real world it takes time for a pin to change from one state to another. In between, it's neither one nor t'other.
Because all real circuits have capacitance (and inductance, resistance, etc.) and to change a pin's voltage requires the capacitance to charge, large currents can flow.
Among other things, that can cause interference on adjacent wires. Limiting the rate at which the voltage changes reduces those problems, at the expense of more time before it's valid.
boyoh
Tue May 19, 2015 5:00 pm
Christoph1985 wrote:Hello,
Thanks in advance
Slew rate is when signal may be slow in changing
from one state to a nother
The speed that signal changes can be speeded
up by using a circuit called a Schmitt trigger,
You could call it a snap action ( Hysteresis.)
It is as if a rising signal is kicking It's self
up It's backside, A blunt way of putting It,
BoyOh ( Selby, North Yorkshire.UK)
Some Times Right Some Times Wrong
jdb
Mon May 25, 2015 4:26 pm
Burngate wrote:Hysteresis (for a digital input): a change from 0 to 1 occurs at a higher input voltage than a change from 1 to 0. There's never an input voltage that's undetermined.
Fun anecdote time: logic (CMOS) inputs without hysteresis act as quite high-gain RF amplifiers if you let their inputs wander to VDD/2. On a particularly ancient and badly-designed board that I had the displeasure of repairing quite a few times, leakage currents and a dodgy terminal connection conspired to make a 4000 series hex inverter bounce up and down at about 18MHz. The output traces were coupling to the input traces at that frequency.
For the case of GPIO pins, hysteresis acts in exactly the same way as hysteresis on the input of 74HC series logic chips. The output toggles at different input voltage levels depending on the state of the output.
The slew rate option *limits* slew rate. Because the GPIOs can operate in the 10s of MHz region, slew rate limiting helps to prevent supply "bounce" when simultaneously switching multiple outputs. It reduces the maximum frequency possible from a single pin but improves the speeds of bus-style interfaces.
Rockets are loud.
https://astro-pi.org
stevovee
Tue Aug 02, 2016 6:18 pm
How/where do you change the GPIO_SLEW to limit it? I have read in a bunch of different places that setting this to 0 will limit the slew but can't find any clear information on how/where to set this. Any help would be apprecated.
stevovee
Thu Aug 04, 2016 7:46 pm
Is this something that you change in the config.txt file or through code in a script?
joan
Thu Aug 04, 2016 7:57 pm
You clear bit 4 of the pad control register.
E.g. in https://github.com/joan2937/pigpio/blob/master/pigpio.c gpioSetPad you would use the constant 0x08 rather than 0x18 to set slew rate limited.
blownelco
Mon Nov 21, 2016 12:23 pm
I'm trying to change the slew rate of my raspberry pi 3.
I have gathering some code in C, it's reading the default values and changes to slew rate off.
If i'm toggle an io, nothing changes, raise time stays about 28ns.
Any clue why it doesn't work?
#include <stdio.h>
#include <stdlib.h>
#include <fcntl.h>
#include <sys/mman.h>
#include <unistd.h>
#define BCM2708_PERI_BASE 0x3F000000
#define PADS_GPIO_BASE (BCM2708_PERI_BASE + 0x100000 )
#define PADS_GPIO_00_27 0x002C
#define PADS_GPIO_28_45 0x0030
#define PADS_GPIO_46_53 0x0034
#define GETPAD32(offset) ( *(unsigned *) ((char *) (pads)+offset))
#define BLOCK_SIZE (4*1024)
volatile unsigned *pads ;
void initialize(void) {
int mem_fd = open("/dev/mem",O_RDWR|O_SYNC);
char *pads_map;
if ( mem_fd <= 0 ) {
perror("Opening/dev/mem");
exit(1);
pads_map = (char *)mmap(
NULL, /*Any address */
BLOCK_SIZE, /*Map length */
PROT_READ|PROT_WRITE,
MAP_SHARED,
mem_fd, /*File to map */
PADS_GPIO_BASE /*Offset to registers */
//if ((long)pads_map == −1L ) {
// perror("mmap failed.");
//xit(1);
close(mem_fd);
pads = (volatile unsigned *)pads_map;
int main(int argc,char **argv) {
int x;
union {
struct {
unsigned drive : 3;
unsigned hyst : 1;
unsigned slew : 1;
unsigned reserved : 13;
unsigned passwrd : 8;
} s;
unsigned w;
} word;
initialize();
printf ("reg=%x/n",PADS_GPIO_BASE);
for ( x=PADS_GPIO_00_27; x<=PADS_GPIO_46_53; x += 4 ) {
word.w = GETPAD32(x) ;
printf("%08X : %08X %x %x %x\n" ,
x+0x7E10000, word.w,
word.s.slew, word.s. hyst, word.s.drive) ;
printf("Writing register");
word.w = 0x5A00000C;
GETPAD32(PADS_GPIO_00_27)= word.w;
GETPAD32(PADS_GPIO_28_45)= word.w;
GETPAD32(PADS_GPIO_46_53)= word.w;
return 0;
weinert
Mon May 28, 2018 9:32 am
Is there an "official" way to turn input hysteresis on/off with pigpoi C/IF?
With "official" I mean using the downloaded version in the Pis and made known to the cross platform development stations (Eclipse Windows or Ubuntu) without modifying pigpio source code.
Albrecht
albrecht-weinert.de
