nicksoph
Moving Power In Connector
Thu Apr 30, 2015 9:05 pm
Hi
I have a need to be able to feed power to a Raspberry Pi 2 from a socket that is on the same end as the USB/network ports.
The intention is to have a custom case with an insulated microUSB socket sitting on the rear side of the PCB beneath the network port, with cables from this new microUSB port soldered onto suitable points on the PCB to supply power to the R-pi.
Looking at the rear of the PCB there are two points directly beneath the microUSB on the rear of the board labled PP2 and PP5 (? poor eyesight) which Im hoping I can solder the additional microUSB power connectors to.
Would somebody advise me if this is a sensible option and if possible point me to schematics or images that would help?
Burngate
Re: Moving Power In Connector
Fri May 01, 2015 8:30 am
Hardware index : https://www.raspberrypi.org/documentati ... /README.md
Schematics index : https://www.raspberrypi.org/documentati ... /README.md
Partial B+ schematic : https://www.raspberrypi.org/documentati ... matics.pdf
The Pi 2B is similar to the B+
PP2 is connected to the 5v input, and PP5 to ground.
Your idea is certainly possible.
Sensible, however, like beauty, is in the eye of the beholder :)
nicksoph
Fri May 01, 2015 9:03 am
Thanks Burngate your reply (looks to me as though it) answered my questions (both technical and philosophical) perfectly.
One more question related to power which would remove the need for me to try and understand the schematics:
Would applying power to PP2 connected to the 5v input, and PP5 to ground, bypass the fuse (F1) ?
Burngate
Fri May 01, 2015 9:21 am
I don't know about you, but my eyesight isn't as good as it used to be.
But what I find helps a lot is http://www.maplin.co.uk/p/22w-fluoresce ... lamp-a29ff
Using that, it looks like PP2 is before the fuse, so you should be ok.
nicksoph
Fri May 01, 2015 9:52 am
Thanks Burngate - that is what I wanted to hear.
Really appreciate your help.
Many thanks.
nick
klricks
Sun May 03, 2015 1:57 pm
PP1 and PP2 is 5V before the fuse.
PP3 is ground but instead it would be better to connect ground to the solder point at the corners of any of the port shields, USB or RJ45 etc. Doing that is easier and the connection will be more robust.
nicksoph
Sun May 03, 2015 9:47 pm
Thanks for the advice klricks - I will do as you suggest.
nicksoph
Sat May 16, 2015 10:52 am
Just wanted to report back that this worked and to say thanks to you both.
