Maarten M
Gertbot - Bug when switching from DCC to DC-Brush mode
Mon Apr 06, 2015 9:21 pm
Using the version 2.3 software on a Gertbot with a RPi B+, after I switch from DCC mode to DC-brushed, the duty cycle always remains at 50% and cannot be changed using the PWM duty cycle command.
After power-cycling the board, the PWM command acts as intended again.
I assume the duty cycle remains under control of a DCC function.
Is this a known bug, and is there a workaround available? For example a reset command to the Gertbot board.
Kind regards,
Maarten M.
Gert van Loo
Re: Gertbot - Bug when switching from DCC to DC-Brush mode
Tue Apr 07, 2015 7:50 pm
I can confirm this behavior.
I have found and fixed the bug. I am working on a new release which will have the bug fix in it.
Excepted to roll out in about a week.
Maarten M
Wed Apr 08, 2015 11:30 am
I will wait for the update.
Many thanks
Gert van Loo
Sun Apr 26, 2015 10:33 pm
Update is out: revision 2.6.
It should fix the issue.
