gilleszo
Re: Realtek RTL8192EU ID 0BDA:818B
Mon Jul 31, 2017 11:49 am
unfortunately i have an issue to install Realtek RTL8192EU!
I've no error message during the installation process,
but i cannot see my wifi card... :cry:
what i'v done:
[email protected]:/tmp $ tar xzf 8192eu-4.9.24-991.tar.gz
[email protected]:/tmp $ ls
8192eu.conf  8192eu.ko  install.sh
[email protected]:/tmp $ ls -al
total 1828
drwxrwxrwt  7 root root    4096 Jul  5 11:50 .
drwxr-xr-x 21 root root    4096 Jul  5 11:45 ..
-rw-r--r--  1 pi   pi        67 Jul  2 04:13 8192eu.conf
-rw-r--r--  1 pi   pi   1831963 Jul  2 04:13 8192eu.ko
drwxrwxrwt  2 root root    4096 Jul  5 11:45 .font-unix
drwxrwxrwt  2 root root    4096 Jul  5 11:45 .ICE-unix
-rwxr-xr-x  1 pi   pi       655 Jul  2 04:13 install.sh
drwxrwxrwt  2 root root    4096 Jul  5 11:45 .Test-unix
drwxrwxrwt  2 root root    4096 Jul  5 11:45 .X11-unix
drwxrwxrwt  2 root root    4096 Jul  5 11:45 .XIM-unix
[email protected]:/tmp $ nano install.sh
[email protected]:/tmp $ ./install.sh
sudo install -p -m 644 8192eu.ko /lib/modules/4.9.35-v7+/kernel/drivers/net/wireless
sudo depmod 4.9.35-v7+
Reboot to run the driver.
If you have already configured your wifi it should start up and connect to your
wireless network.
If you have not configured your wifi you will need to do that to enable the wifi.
[email protected]:/tmp $ ifconfig
[email protected]:~ $ lsusb
Bus 001 Device 004: ID 0bda:818b Realtek Semiconductor
[email protected]:~ $ uname -a
Linux raspberrypi 4.9.35-v7+ #1014 SMP Fri Jun 30 14:47:43 BST 2017 armv7l GNU/Linux
Could you please tell if this issue can be solved ? :)
MrEngman
Mon Jul 31, 2017 5:30 pm
what i'v done:
total 1828
wireless network.
Install the correct version of the driver. uname -a shows 4.9.35-v7+ #1014. So download file 8192eu-4.9.35-v7-1014.tar.gz.
Try this
wget http://fars-robotics.net/8192eu-4.9.35-v7-1014.tar.gz
tar xzf 8192eu-4.9.35-v7-1014.tar.gz
./install.sh
gilleszo
Mon Jul 31, 2017 5:33 pm
what i'v done:
total 1828
wireless network.
Try this
./install.sh
Thank's for your quick answer, i will test it tomorrow and will let you know :)
gilleszo
Tue Aug 01, 2017 7:02 am
Try this [code]wget http://fars-robotics.net/8192eu-4.9.35-v7-1014.tar.gz
./install.sh
Many thank's it's working :),
you made my day :p
dineshaggarwal
Tue Aug 01, 2017 6:51 pm
./install.sh
I am always getting 404 error. I tried it with dl.dropboxusercontent.com.... also. But getting same error. Version information is correct. Please help!!
MrEngman
Tue Aug 01, 2017 7:18 pm
./install.sh
Not sure why you should be getting the 404 error. A typo in the command you used would be a possibility.
I just copied the URL link from your post and then downloaded it using wget and the copy of your link and it downloaded OK to one of my Pi's
The dropbox link will not work.
dineshaggarwal
Tue Aug 01, 2017 7:23 pm
Hello Friends, Please disregard my last post. It is working now. Thanks
tecnoArcangel
Wed Aug 02, 2017 2:49 am
Hello friends, I have this problem. Im trying to install the driver for my wifi adapter AWUS036ACH, it have the RTL8812AU chipset but I been trying make it work.
When I install realtek-rtl88xxau-dkms shows the following message
Reading package lists... Done
Building dependency tree
The following NEW packages will be installed:
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/1522 kB of archives.
After this operation, 14.8 MB of additional disk space will be used.
Selecting previously unselected package realtek-rtl88xxau-dkms.
(Reading database ... 143493 files and directories currently installed.)
Preparing to unpack .../realtek-rtl88xxau-dkms_4.3.21~20170330-0kali1_all.deb ...
Unpacking realtek-rtl88xxau-dkms (4.3.21~20170330-0kali1) ...
Setting up realtek-rtl88xxau-dkms (4.3.21~20170330-0kali1) ...
Loading new realtek-rtl88xxau-4.3.21~20170330 DKMS files...
It is likely that 4.4.50-v7 belongs to a chroot's host
Building for 4.4.50-v7
Building initial module for 4.4.50-v7
Error! Bad return status for module build on kernel: 4.4.50-v7 (armv7l)
Consult /var/lib/dkms/realtek-rtl88xxau/4.3.21~20170330/build/make.log for more information.
Im using Kali Linux 2017.1
This is my info
[email protected]:~# uname -a
Linux kali 4.4.50-v7 #1 SMP Fri Apr 21 01:18:29 CDT 2017 armv7l GNU/Linux
[email protected]:~# lsusb
Bus 001 Device 007: ID 0bda:8812 Realtek Semiconductor Corp. RTL8812AU 802.11a/b/g/n/ac WLAN Adapter
[email protected]:~# cat /proc/version
Linux version 4.4.50-v7 ([email protected]) (gcc version 4.8.3 20140401 (prerelease) (crosstool-NG linaro-1.13.1-4.8-2014.04 - Linaro GCC 4.8-2014.04) ) #1 SMP Fri Apr 21 01:18:29 CDT 2017
[email protected]:~# gcc --version
gcc (Debian 6.3.0-18) 6.3.0 20170516
Copyright (C) 2016 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Here I did what this post said
[email protected]:~# sudo wget http://fars-robotics.net/install-wifi -O /usr/bin/install-wifi
--2017-08-02 02:08:38--  http://fars-robotics.net/install-wifi
Resolving fars-robotics.net (fars-robotics.net)... 212.23.8.80
Connecting to fars-robotics.net (fars-robotics.net)|212.23.8.80|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 16141 (16K) [text/plain]
Saving to: ‘/usr/bin/install-wifi’
/usr/bin/install-wi 100%[===================>]  15.76K  53.4KB/s    in 0.3s
2017-08-02 02:08:39 (53.4 KB/s) - ‘/usr/bin/install-wifi’ saved [16141/16141]
[email protected]:~# sudo chmod +x /usr/bin/install-wifi
[email protected]:~# sudo install-wifi -h
 *** Raspberry Pi wifi driver installer by MrEngman.
 *** Performing self-update
/usr/bin/install-wifi: line 19: curl: command not found
 !!! Failed to download update for install-wifi!
 !!! Make sure you have ca-certificates installed and that the time is set correctly
Please help me, I have two weeks trying :(
Karmus
Mon Aug 07, 2017 6:36 am
Although not the Raspberry, I have issues with compiling for the platform aarch64, even though I have installed headers. It cannot find the correct folders in build/arch, and when I change the architecture to arm64, it shows some other errors.
[email protected]:/home/osmc# uname -a
Linux osmc 3.14.29-28-osmc #1 SMP Tue Aug 1 00:00:14 UTC 2017 aarch64 GNU/Linux
I know you probably don't have time to debug this, nevertheless, I just wanted to reach out to an expert on this particular chipset. Tremendously many people have issues with this driver. I would really want to look for an alternative in stead of messing around with old code.
MrEngman
Mon Aug 07, 2017 11:13 am
Never used DKMS so no idea what the problem may be. What is reported in the make.log? Might help.
This is my info
The scripts I have and drivers I've compiled are for Raspbian so probably will not work with Kali. The error you get when trying to run my script shows command curl is not installed. However, even if you install curl to get the script working It will report the is no driver available for 4.4.50-v7 #1.
MrEngman
Mon Aug 07, 2017 11:18 am
Perhaps if you report exactly what the error is regarding the folders it might be possible to figure out a solution.
Mind you as you are not using a Raspberry might be better looking at the aarch64 forums or whatever.
mlazar
Sat Aug 12, 2017 7:39 pm
I need 8192eu.ko module for an old kernel 3.18.11-v7+ #781. But wget http://www.fars-robotics.net/8192eu-3.1 ... 781.tar.gz give me "ERROR 404: Not Found". :( I tried also https://dl.dropboxusercontent.com/u/802 ... 781.tar.gz and http://www.fars-robotics.net/8192eu-20150406.tar.gz without success. Is this driver available?
Thank You.
MrEngman
Sun Aug 13, 2017 5:07 am
Should be available now. Try this
wget http://www.fars-robotics.net/8192eu-3.18.11-v7-781.tar.gz
tar xzf 8192eu-3.18.11-v7-781.tar.gz
./install.sh
leobel96
Sun Aug 13, 2017 7:35 pm
Hello to all,
I have just bought a tenda U1 WI-FI dongle that is based on the realtek RTL8192EU. The dongle works perfectly on my Windows pc but I have found problems with my Raspberry Pi 2 with the last version of OctoPi (an OS based on Raspbian Lite). With uname I obtain:
I have tried installing the drivers as suggested:
But, after rebooting more and more times and after have tried different versions of the drivers, I continue to obtain this result running the lsusb command:
The dongle led doesn't switch on and without an Ethernet cable or another dongle it's impossible to connect the Raspberry to internet.
What could be the problem? The procedure should be the same of a normal raspbian OS.
Thank you!
MrEngman
Mon Aug 14, 2017 2:40 pm
I'm currently abroad away from home, but when at home I run a couple of Pis with two wifi dongles one of which uses the 8192eu driver and I don't have any problems.
I have a Pi 3B with me and have just connected a wifi using the 8192eu driver and it is working OK.
Could it be an issue with your wifi configuration? If both wifi dongles are connected directly to the Pi could it be a power supply issue. Do you see any obvious errors in dmesg.
What do the following commands show
lsmod
cat /etc/network/interfaces
sudo cat /etc/wpa_supplicant/wpa_supplicant.con
leobel96
Mon Aug 14, 2017 2:53 pm
In the end I found another wifi adapter at home and decided to use or. It worked succesfully when I plugged it in. Thank you for your reply anyway
ewaldc
Wed Aug 16, 2017 1:21 pm
Flawless installation on 4.9.35+ #1014. Many thanks for the pre-compiled driver and creating such an easy installation process !
While I am experienced in writing kernel code and compiling kernels, this saved me at least one hour of work.
One (minor) suggestion maybe for the installation script: "/etc/modprobe.d/8192eu.conf" is installed with pi as owner/group.
No big deal given the way the pi user is used in Raspbian, but to make it perfect:
sudo chown root:root /etc/modprobe.d/8192eu.conf
Ewald
ewaldc
Thu Aug 17, 2017 11:57 am
I was forced to upgrade due to a rpi kernel bug.
Is there a version for 4.9.43+ #1026?
Thanks in advance,
Ewald.
MrEngman
Thu Aug 17, 2017 1:19 pm
Yes
ewaldc
Sat Aug 19, 2017 12:33 pm
Thank you. Perfect installation on both v6L and v7 versions 4.9.43+ #1026.
My problem is solved on this kernel so I will stay on it for a while and not disturb you with requests for new versions.
Ewald
eleroux22
Sat Oct 07, 2017 7:20 pm
Any drivers available for Linux kali Kernel 4.4.50?
MrEngman
Sun Oct 08, 2017 6:51 am
Sorry, no.
mushis
Sat Oct 21, 2017 2:21 pm
I would love some help with this as well:
EDIT: I just found out the update script, testing it now!
$ uname -a
Linux raspberrypi 4.9.41-v7+ #1023 SMP Tue Aug 8 16:00:15 BST 2017 armv7l GNU/Linux
Thanks,
mushi
mushis
Tue Oct 24, 2017 3:54 pm
yes, the script worked like a charm!
Mr. EngMan you're a life saver!
Can you do me a favor? can you tell me the direct download link to the driver, so I download and make a backup ?? thanks!
AndersM
Sun Nov 05, 2017 4:57 pm
The script worked like a charm!
Mr. Engman you're a life saver!
