belalobo
Re: Realtek RTL8192EU ID 0BDA:818B
Tue Apr 18, 2017 12:28 am
Hi again! First of all thanks for the help!
Meanwhile i´ve tried with the new link but I get the message:
Checking for a new 8192eu wifi driver module for your current kernel.
A driver does not yet exist for this update.
so... I´m out of luck? help?
Thanks again
MrEngman
Tue Apr 18, 2017 1:23 am
belalobo wrote:Hi again! First of all thanks for the help!
Thanks again
The script is for Raspbian drivers. For the kali driver to download and install use commands
wget http://fars-robotics.net/8192eu-4.1.19-v7-kali.tar.gz
tar xzf 8192eu-4.1.19-v7-kali.tar.gz
./install.sh
MrEngman
belalobo
Tue Apr 18, 2017 2:26 am
Ok now I´m getting this error message:
install: cannot create regular file '/lib/modules/4.1.19-v7/kernel/drivers/net/wireless': No such file or directory
sudo depmod 4.1.19-v7
depmod: ERROR: could not open directory /lib/modules/4.1.19-v7: No such file or directory
depmod: FATAL: could not search modules: No such file or directory
MrEngman
Tue Apr 18, 2017 3:53 am
belalobo wrote:Ok now I´m getting this error message:
Looks like you are trying to install the wrong version of the driver. Please post the output from commands
uname -a
lsusb
so I can check which driver you need.
MrEngman
belalobo
Tue Apr 18, 2017 11:42 am
Ok so uname -a:
Linux kali 4.1.19 #1 PREEMPT Tue Mar 15 18:12:17 CDT 2016 armv6l GNU/Linux
lsusb:
Bus 001 Device 004: ID 2357:0107
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp. SMC9512/9514 USB Hub
MrEngman
Tue Apr 18, 2017 11:58 am
belalobo wrote:Ok so uname -a:
lsusb:
Try this instead
wget http://fars-robotics.net/8192eu-4.1.19-kali-rpi1.tar.gz
tar xzf 8192eu-4.1.19-kali-rpi1.tar.gz
./install.sh
MrEngman
belalobo
Tue Apr 18, 2017 12:01 pm
MrEngman I cannot thank you enough for the help, meanwhile with this new link I get a "ERROR 404: Not Found" message
MrEngman
Tue Apr 18, 2017 12:03 pm
belalobo wrote:MrEngman I cannot thank you enough for the help, meanwhile with this new link I get a "ERROR 404: Not Found" message
Sorry, try again. Should be available now.
MrEngman
belalobo
Tue Apr 18, 2017 12:48 pm
Ok now it worked!
Still I don´t get wlan0 displayed with ifconfig.
I have 2 sd cards one with raspian where I followed all the instructions here on the forum and it works perfectly whereas with the kali sd card at least now I got no errors but wlan0 does not show up still.
MrEngman
Tue Apr 18, 2017 1:34 pm
belalobo wrote:Ok now it worked!
I don't normally use Kali but I did set up an SD card quite a long time ago and seem to remember setting up the wifi wasn't easy and is different to setting it up on Raspbian, using network manager I think. I used a TP-Link WN725N wifi using the 8188eu driver.
I just installed the 8192eu driver you are now using and then changed the wifi module to one using the 8192eu driver. I now have a connection to the Pi using Kali using the 8192eu wifi so the driver you have works.
I think it is the wifi set up that is probably the problem now. When I changed the wifi to 8192eu it took quite a long time before it got connected.
It might be a good idea to look at the Kali web site or forum for info on setting up the wifi.
MrEngman
belalobo
Tue Apr 18, 2017 1:41 pm
Alright then! I will have a look.
Anyways thank you so much for all the help!
Greatly appreciated!
galleon_10
Sat Apr 22, 2017 7:57 am
MrEngman wrote:
nsticco wrote:Hello,
I would love some help with this as well:
$ uname -a
Linux raspberrypi 4.1.13-v7+ #826 SMP PREEMPT Fri Nov 13 20:19:03 GMT 2015 armv7l GNU/Linux
Thanks,
Nate
Try this
wget https://dl.dropboxusercontent.com/u/80256631/8192eu-4.1.13-v7-826.tar.gz
tar xzf 8192eu-4.1.13-v7-826.tar.gz
./install.sh
MrEngman
hi mrengman,
i know its an oldpost but the link for the driver is invalid. Can you please reshare it again. Thanks a lot.
MrEngman
Sat Apr 22, 2017 1:39 pm
$ uname -a
Thanks,
Nate
Try this
./install.sh
MrEngman
hi mrengman,
Try this
wget http://www.fars-robotics.net/8192eu-4.1.13-v7-826.tar.gz
./install.sh
Dropbox have made a major change to their web site and its really screwed things up. Really annoying to say the least so I have moved the drivers to a new site. I have a script to use the new site which will automatically determine the driver you need and download and install it.
Download and install the new version of the script with commands
sudo wget http://www.fars-robotics.net/install-wifi -O /usr/bin/install-wifi
sudo chmod +x /usr/bin/install-wifi
The command
sudo install-wifi -h
will show details on using it.
To install the driver on your current kernel you should just need to run command
sudo install-wifi
This will select the driver you need and automatically download and install it.
MrEngman
MrEngman
Sat Apr 22, 2017 1:44 pm
xronik wrote:MrEngman, how to enable LED indicator in dongle now ?
Thx.
Hi xronik,
The 8192eu wifi module I was using did not have an LED so I didn't realise the LED was not enabled. I have now updated the 8192eu drivers to enable the LED.
To get the LED working you will need to download and re-install the driver.
MrEngman
andybob
Sat May 06, 2017 1:43 am
Hi Mr. Engman,
Running the script from your new site yielded the following:
*** Raspberry Pi wifi driver installer by MrEngman.
*** Performing self-update
*** Relaunching after update
Your current kernel revision = 4.4.30-sc1+
Your current kernel build = #1
Checking for a wifi module to determine the driver to install.
Your wifi module is Bus 001 Device 004: ID 0bda:818b Realtek Semiconductor Corp.
And it uses the 8192eu driver.
I'm running DietPi v144.
Is an 8192eu driver for kernel 4.4.30 on the way or should I revert to an older version of DietPi ?
MrEngman
Sat May 06, 2017 11:20 am
andybob wrote:Hi Mr. Engman,
Hi andybob,
The drivers I compile are for Rasbian and the file names are based on the Raspbian kernel version and build so the script will not work for DietPi. I don't think the Raspbian drivers will work with DietPi but you can try and install one manually just to see if it does.
For Pi 2B or 3B use commands
wget http://fars-robotics.net/8192eu-4.4.30-v7-919.tar.gz
tar xzf 8192eu-4.4.30-v7-919.tar.gz
./install
For all other version of the Pi use commands
wget http://fars-robotics.net/8192eu-4.4.30-919.tar.gz
tar xzf 8192eu-4.4.30-919.tar.gz
./install
MrEngman
ishmael1856
Wed May 10, 2017 6:45 pm
Thanks for the great script and drivers! I've installed the mt7610 driver for the TP-Link Archer T2U, but I can't seem to get it to work for the 5GHz band (it works fine at 2.4GHz). Any ideas?
MrEngman
Wed May 10, 2017 8:02 pm
ishmael1856 wrote:Thanks for the great script and drivers! I've installed the mt7610 driver for the TP-Link Archer T2U, but I can't seem to get it to work for the 5GHz band (it works fine at 2.4GHz). Any ideas?
Not really the right place to post about the T2U and mt7610 driver, however ...
Just loaded the mt7610 driver on to a Pi 2B running Raspbian 4.9.27-v7+. Rebooted and it initially connected to an AP at 2.4GHz. Disabled that AP and rebooted and then it connected to one of my other APs at 5GHz without problems. I use MAC Address filtering so can limit which of my APs a wifi adapter can connect to. In this case the T2U is now only allowed to connect to my 5GHz AP and appears to connect OK.
Just to see what might happen I then re-enabled the 2.4GHz AP and rebooted the Pi and the T2U then connected to that AP again at 2.4GHz. Disabled the 2.4GHz AP and rebooted again and the T2U connected back to my 5GHz AP. A bit weird as the 2.4GHz AP is about 8M from the Pi and the 5GHz AP is about 1.5M from the Pi so I would of expected the T2U to always use the 5GHz AP. No idea why it behaves like this except it could be an issue with the driver, but what I've no clue.
MrEngman
ishmael1856
Wed May 10, 2017 9:57 pm
Thanks for the reply. It turns out I had set up my /etc/network/interfaces file incorrectly. Now it connects to 5GHz. Sorry for the noise.
Domminic
Wed May 17, 2017 1:08 pm
when I run this command tar xzf 8192eu-4.4.30-v7-919.tar.gz
I get the following. I downloaded the tar several times to make sure it wasn't just a corrupted download.
gzip: stdin: unexpected end of file
tar: Unexpected EOF in archive
tar: Error is not recoverable: exiting now
Any ideas gratefully received!
MrEngman
Wed May 17, 2017 2:53 pm
Domminic wrote:when I run this command tar xzf 8192eu-4.4.30-v7-919.tar.gz
No idea why you are having problems. I checked it out myself and didn't find any problem e.g.
[email protected]:~ $ mkdir temp
[email protected]:~ $ cd temp
[email protected]:~/temp $ wget http://fars-robotics.net/8192eu-4.4.30-v7-919.tar.gz
--2017-05-17 15:46:06--  http://fars-robotics.net/8192eu-4.4.30-v7-919.tar.gz
Resolving fars-robotics.net (fars-robotics.net)... 212.23.8.80
Connecting to fars-robotics.net (fars-robotics.net)|212.23.8.80|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 594443 (581K) [application/x-gzip]
Saving to: ‘8192eu-4.4.30-v7-919.tar.gz’
8192eu-4.4.30-v7-919.tar.gz               100%[======================================================================================>] 580.51K   740KB/s   in 0.8s
2017-05-17 15:46:07 (740 KB/s) - ‘8192eu-4.4.30-v7-919.tar.gz’ saved [594443/594443]
[email protected]:~/temp $ tar xzf 8192eu-4.4.30-v7-919.tar.gz
[email protected]:~/temp $ ls
8192eu-4.4.30-v7-919.tar.gz  8192eu.conf  8192eu.ko  install.sh
EDIT: Check the size of file 8192eu-4.4.30-v7-919.tar.gz you downloaded. Should be 594443 bytes.
MrEngman
Domminic
Thu May 18, 2017 8:03 am
Thanks for the reply. I will try again and see if I can find what I'm doing wrong!
Domminic
Mon May 22, 2017 3:39 pm
Thank you MrEngman. It was indeed a problem with incomplete tar file download. I was using my tethered mobile and wifi to download the file and it never quite completed the download. The current wifi module is so slow that the network dropped out before file transfer completion. In the end I used USB to get the file into my Pi B+ from the mobile.
lsusb returns 'Bus 001 Device 005: ID 0bda:818b Realtek Semiconductor Corp.' so I hope I have the right device!
It didn't help that it took me a while to realize I have a Pi B+ and not a P2 B+.
My next problem is that uname - a gives me 4.9.24+
I thought I could be clever and modify the install.sh file inside 8192eu-4.4.30-919.tar.gz to say 'kernel=4.9.24+' to install the driver correctly by but alas not! Is there anything else I can do except perhaps download an earlier Rasbian image? I can already hear foreheads hitting keyboards with despair but one has to start somewhere!
MrEngman
Mon May 22, 2017 5:47 pm
Domminic wrote:Thank you MrEngman. It was indeed a problem with incomplete tar file download. I was using my tethered mobile and wifi to download the file and it never quite completed the download. The current wifi module is so slow that the network dropped out before file transfer completion. In the end I used USB to get the file into my Pi B+ from the mobile.
First it would be a good idea to fix your internet connection so you can download without problems.
The simplest way to install my wifi drivers is to use my install-wifi script which determine the wifi adapter you use and the kernel version you have and then should automatically download and install the right version of the driver. You can download and install the script using commands
sudo wget http://fars-robotics.net/install-wifi -O /usr/bin/install-wifi
After it is installed to see info on how to use it use command
If it's a problem downloading the script then the driver file you need is 8192eu-4.9.24-991.tar.gz to work on a Pi B+ with Raspbian 4.9.24+. And generally you cannot change the install.sh file to install a driver on a different kernel version than the install.sh file says it will install on. To download and install it use commands
wget http://fars-robotics.net/8192eu-4.9.24-991.tar.gz
tar xzf 8192eu-4.9.24-991.tar.gz
./install.sh
Also if you update your kernel you will need to download an updated version of the driver.
MrEngman
Domminic
Tue May 23, 2017 10:54 am
Thank you for your help. I can see its a painfully long way to go before I get my boy scout badge in Beginners Linux!
I reformatted my SD card last night and started again. Of course your wifi installer had me up and running in no time.
Thank you.
Dominic
