MrEngman
Re: Realtek RTL8192EU ID 0BDA:818B
Sat Apr 16, 2016 1:02 pm
John_Moses wrote:Hello guys,
I am totally new to the Pi and am struggling right now with my wifi.
I need the 8192EU drivers, uname -a brought up:
Linux raspberrypi 4.1.19-v7+ #858 SMP Tue Mar 15 15:56:00 GMT 2016 armv7l GNU/Linux
Mr. Engman, could you provide me the right driver?
Try this
wget https://dl.dropboxusercontent.com/u/80256631/8192eu-4.1.19-v7-858.tar.gz
tar xzf 8192eu-4.1.19-v7-858.tar.gz
./install.sh
And take a look here.
MrEngman
John_Moses
Mon Apr 18, 2016 11:07 am
Thanks a lot! It works :D
MrEngman
Mon Apr 18, 2016 11:14 am
John_Moses wrote:Thanks a lot! It works :D
Glad to be able to help, have fun with your Pi.
MrEngman
g3kz
Wed May 11, 2016 2:05 pm
i need the driver for the adapter RTL8188CUS
#uname -a
Linux kali 4.1.19 #1 PREEMPT Tue Mar 15 18:12:17 CDT 2016 armv6l GNU/Linux
thanks and kind regards
Sailoog
Sat May 14, 2016 7:05 pm
Hi MrEngman,
I have been using your files successfully for long time but now something goes wrong. When I apply your patch the device is no more recognised by the system.
Raspberry 3 (I can only see built-in wifi wlan0 but not wlan1).
Device: RTL8192EU
uname -a
Linux raspberrypi 4.4.9-v7+ #884 SMP Fri May 6 17:28:59 BST 2016 armv7l GNU/Linux
Downloaded a executed:
wget https://dl.dropboxusercontent.com/u/80256631/8192eu-4.4.9-v7-884.tar.gz
tar xzf 8192eu-4.4.9-v7-884.tar.gz
./install.sh
Is someone else experimenting this issue?
Thanks!
MrEngman
Sun May 15, 2016 3:38 pm
Sailoog wrote:Hi MrEngman,
Device: RTL8192EU
uname -a
./install.sh
Thanks!
The wifi you are seeing working is almost certainly the 8192eu wifi.
If you install my drivers on a Pi 3 B then it will disable the built in Broadcom wifi. To get the built in wifi working as well you need to edit the file /etc/modprobe.d/8192eu.conf and comment out or delete the line blacklist ... like
#blacklist brcmfmac
options 8192eu rtw_power_mgnt=0 rtw_enusbss=0
Then reboot and you should find both wlan0 and wlan1.
MrEngman
Sailoog
Mon May 16, 2016 12:02 pm
Device: RTL8192EU
uname -a
./install.sh
Thanks!
#blacklist brcmfmac
MrEngman
Hey that worked!!!! Same for 8188eu
Thanks!
What will we do when you get tired of making compilations? :)
cannonfodder728
Sat May 28, 2016 6:16 pm
lsmod lists the module as 8192eu, however ls /sys/class/net/wlan0/device/driver/module/drivers/ lists the module as rtl8192eu which causes problems when trying to script automated unloading and loading of the driver incase of raspbian usb bus resets or other issues. Can someone fix this?
MrEngman
Sat May 28, 2016 7:12 pm
cannonfodder728 wrote:lsmod lists the module as 8192eu, however ls /sys/class/net/wlan0/device/driver/module/drivers/ lists the module as rtl8192eu which causes problems when trying to script automated unloading and loading of the driver incase of raspbian usb bus resets or other issues. Can someone fix this?
Very common for Realtek drivers. Perhaps you should adjust your script although why you should need to know the driver name I can't think why.
If the wifi goes down it should be sufficient to try to bring it back up, which doesn't need the driver name. Maybe look at this
MrEngman
ruzwakh
Sun Jun 26, 2016 8:30 pm
hello, i have linux kernel 4.1.19 v7 and raspberry pi 3. how can i download realtek driver 8188cus on it, i can not find it anywhere please help me
MrEngman
Sun Jun 26, 2016 10:33 pm
ruzwakh wrote:hello, i have linux kernel 4.1.19 v7 and raspberry pi 3. how can i download realtek driver 8188cus on it, i can not find it anywhere please help me
You should not need to download the 8188cus driver as I would expect that driver to be included in the kernel image. The driver for 8188cus wifi is 8192cu or rtl8192cu depending on the OS used.
If you connect your 8188cus wifi to the Pi 3 and use command lsmod I would expect it to show 8192cu or rtl8192cu if the driver is included and your wifi is recognised. You will then just need to configure your wifi to get it working.
MrEngman
ruzwakh
Mon Jun 27, 2016 12:40 am
thank you for your reply and i want to ask one more question how can i configure my wireless after i download driver?
ruzwakh
Mon Jun 27, 2016 12:55 am
i also couldnt find 8192 driver for my kernel
MrEngman
Mon Jun 27, 2016 1:02 am
ruzwakh wrote:i also couldnt find 8192 driver for my kernel
What image are you using?
You can check for the 8192cu driver using command
sudo find /lib -name "*8192*.ko"
Tell me what the result of this command is.
MrEngman
ruzwakh
Mon Jun 27, 2016 1:12 am
i am using raspberry 2/3 version 2.1.2 after i write this command i get /lib/modules/4.1.19-v7/kernel/drivers/net/wireless/rtl18192cu/8192cu.ko
joerod
Mon Jun 27, 2016 1:15 am
I'm having a hard time with this USB wifi adapter as well, I'm trying to get it to work with a Raspberry B+ (4.1.7-v7+), are there any pre-compiled drivers that I can easily install?
MrEngman
Mon Jun 27, 2016 1:46 am
ruzwakh wrote:i am using raspberry 2/3 version 2.1.2 after i write this command i get /lib/modules/4.1.19-v7/kernel/drivers/net/wireless/rtl18192cu/8192cu.ko
So the 8192cu driver is in your kernel image. 2.1.2 sounds like it may be Kali. If it is perhaps you should go to the Kali web site and ask your questions there.
MrEngman
MrEngman
Mon Jun 27, 2016 3:26 am
joerod wrote:I'm having a hard time with this USB wifi adapter as well, I'm trying to get it to work with a Raspberry B+ (4.1.7-v7+), are there any pre-compiled drivers that I can easily install?
What OS are you using. There are drivers available that I have compiled for Raspbian.
You say you are using a Pi B+ with kernel 4.1.7-v7+. That is not right. A Pi B+ will use kernel 4.1.7+. with NO "-v7". What is the output of command uname -a.
MrEngman
joerod
Mon Jun 27, 2016 11:07 pm
MrEngman
Here it is directly from the Raspberry
pi@zwave ~ $ uname -a
Linux zwave 4.1.7-v7+ #817 SMP PREEMPT Sat Sep 19 15:32:00 BST 2015 armv7l GNU/Linux
MrEngman
Tue Jun 28, 2016 12:52 am
MrEngman
OK you are using raspbian. I have a number of different drivers I have compiled that can be downloaded.
You did not say which wifi you are using so can you post the output of command lsusb when you have the wifi connected to your Pi.
Sorry, but I just need to ask as the post is about wifi using the 8192eu driver but there have been quite a few posts about using other drivers so I just need to be sure which one you use. The last few posts have been about the wifi using the 8188cus/8192cu driver which is included in the kernel image and as you say
it's not clear which one you have. If you do have wifi which uses the 8192cu driver then you do not need to download a driver as it is included in the raspbian image. You just need to configure your wifi to get it to work.
MrEngman
joerod
Tue Jun 28, 2016 3:41 am
I'm pretty sure my adapter is a RTL8192EU
Here is a link to the adapter I'm trying to use https://amzn.com/B017DAJ50K
MrEngman
Tue Jun 28, 2016 11:51 am
joerod wrote:I'm pretty sure my adapter is a RTL8192EU
OK, Try these commands to download and install the 8912eu driver.
wget https://dl.dropboxusercontent.com/u/80256631/8192eu-4.1.7-v7-817.tar.gz
tar xzf 8192eu-4.1.7-v7-817.tar.gz
./install.sh
The ./install.sh command will install the driver. After installing the driver you should reboot with the wifi module connected to the Pi. Run command lsmod to check the driver is loaded. If you do not see 8192eu listed please post the output from command lsusb to check the USB ID of the wifi adapter and make sure it is included in the current version of the driver I have compiled.
MrEngman
barkos
Thu Jul 21, 2016 3:50 pm
Hi
I'm trying to instal this driver on my raspi b+. The kernel i have its 4.4.11+ #888 arm6l.
I tested the script install-wifi but it can't acces dropbox to check. Where can find it? any help.
Colateral
Thu Jul 21, 2016 3:59 pm
HI,
My PI0 and PI3 release is 4.4.13-V7+. Do you have the RTL8192EU driver for it or something similar?
I downloaded the driver for 4.4.9-v7 but doesn't work.
Many Thanks,
Cata
MrEngman
Thu Jul 21, 2016 4:38 pm
Colateral wrote:HI,
Many Thanks,
Cata
The 4.4.9-v7 driver should work, it does for me. This is provided you are using the Raspbian image, Jessie or Wheezy.
For 4.4.13-v7+ try
wget https://dl.dropboxusercontent.com/u/80256631/8192eu-4.4.13-v7-894.tar.gz
tar xzf 8192eu-4.4.13-v7-894.tar.gz
./install.sh
MrEngman
