Kunkka
Re: Realtek RTL8192EU ID 0BDA:818B
Fri Jan 29, 2016 10:51 am
MrEngman wrote:
Kunkka wrote:Hi MrEngman
Could you pls compile one for this
Linux kali 4.0.0-kali1-amd64 #1 SMP Debian 4.0.4-1+kali2 (2015-06-03) x86_64 GNU/Linux
Sorry, I can not, I only compile for raspberry pi raspbian. Why don't you compile it on your own system?
MrEngman
... it's too complicated to me. I'm not farmiliar with unix yet :(
would u kindly walk me through some step?
djones
Mon Feb 01, 2016 8:02 pm
MrEngman wrote:
nsticco wrote:Hello,
I would love some help with this as well:
$ uname -a
Linux raspberrypi 4.1.13-v7+ #826 SMP PREEMPT Fri Nov 13 20:19:03 GMT 2015 armv7l GNU/Linux
Thanks,
Nate
Try this
wget https://dl.dropboxusercontent.com/u/80256631/8192eu-4.1.13-v7-826.tar.gz
tar xzf 8192eu-4.1.13-v7-826.tar.gz
./install.sh
MrEngman
Great! Thanks, you saved my day.
I tried for 20hours to get a solution and you did it in one minute - thanks :mrgreen:
zgoda
Thu Feb 11, 2016 1:34 pm
I'm trying to compile this module on my own. After few failed attempts now I am able to compile the module but I'm getting:
$ sudo modprobe 8192eu
modprobe: ERROR: could not insert '8192eu': Exec format error
and line in dmesg:
[11060.493887] 8192eu: disagrees about version of symbol module_layout
Which is not surprising because I see vermagic mismatch:
vermagic:       4.1.17-v7 SMP mod_unload modversions ARMv7
in modinfo vs uname:
$ uname -r
4.1.17-v7+
I'm stuck here, any help?
The same source compiles cleanly and loads without any problems on x86_64 (Ubuntu 14.04, kernel 3.13.0-77-generic).
Casey800
Fri Feb 12, 2016 11:22 pm
@MrEngman. So, with your help my wifi 8192eu-4.1.13-826 worked perfectly. Stupidly i did an upgrade and now I'm stuck with 4.1.17+ build 838. Not working anymore. Tried to install with a changed install.sh. No. Patched the driver as I found 4.1.13 somewhere. No. So can you please compile a new version ? Or supply the source with the compile instructions ?
btmurph
Mon Feb 22, 2016 12:07 am
I'm in the same boat as Casey, however I'm kernel 4.1.18-v7+ #845. As with Casey, either the compiled driver or instructions on how to compile my own (even better) would be greatly appreciated!
MrEngman
Mon Feb 22, 2016 7:37 am
I've managed to update the 8192eu drivers I compile so they are now available for 4.1.17(-v7)+ and 4.1.18(-v7)+.
Using my standard naming format you can download and install using
wget https://dl.dropboxusercontent.com/u/80256631/8192eu-kernel-build.tar.gz
tar xzf 8192eu-kernel-build.tar.gz
./install.sh
replacing kernel and build with the values from the command uname -a.
As an example for a Pi 2 B using raspbian 4.1.18-v7+ #845 use commands
wget https://dl.dropboxusercontent.com/u/80256631/8192eu-4.1.18-v7-845.tar.gz
tar xzf 8192eu-4.1.18-v7-845.tar.gz
./install.sh
For the Pi A/A+/B/B+ the kernel version will not have -v7 like
wget https://dl.dropboxusercontent.com/u/80256631/8192eu-4.1.18-845.tar.gz
tar xzf 8192eu-4.1.18-845.tar.gz
./install.sh
MrEngman
btmurph
Mon Feb 22, 2016 11:55 pm
MrEngman, thank you SO much! That worked famously :-)
Brian
Casey800
Mon Feb 22, 2016 11:56 pm
@MrEngman: your driver for 4.1.17 build 838 works A-OK !! Thanks a lot for your service. :D
cannonfodder728
Tue Feb 23, 2016 1:38 am
Yup works like a charm, thanks
Learntofly
Thu Feb 25, 2016 3:41 pm
Many many thanks Sir,
For posterity, my pi zero is showing the following as a result of "uname -a"
Linux XXHOSTNAMEXX 4.1.18+ #845 Thu Feb 18 19:37:13 GMT 2016 armv6l GNU/Linux
The "githash" from /boot/.firmware_revision is:
68febe187617906637e0ac71b0c8b8f581f10078
I believe (although I am no expert) that this would allow someone, in conjunction with the rpi-update tool to downgrade / upgrade to this *EXACT* kernel that is compatible with your driver.
I dont know is this changed for the pi2b, but ive previously had a headache trying to find the githash to downgrade, hopefully this may help someone if you were unable to compile a driver due to being abroad /away etc...
I claim credit for nothing, merely postng a has that may help somone next week or the week after :)
Regards,
LTF
MrEngman wrote:I've managed to update the 8192eu drivers I compile so they are now available for 4.1.17(-v7)+ and 4.1.18(-v7)+.
./install.sh
./install.sh
./install.sh
MrEngman
udarkman
Sat Feb 27, 2016 9:33 am
Hi MrEngman
I have the same problem. Can you compile it for:
root@raspberrypi:~# uname -a
Linux raspberrypi 4.1.17-v7+ #838 SMP Tue Feb 9 13:15:09 GMT 2016 armv7l GNU/Linux
Raspberry pi 2
Jessie
MrEngman
Sat Feb 27, 2016 3:57 pm
udarkman wrote:Hi MrEngman
Raspberry pi 2
Jessie
Use the info in the previous post to download and install the driver you need.
From uname -a you see kernel = 4.1.17-v7 and build = 838 so to download and install use commands
wget https://dl.dropboxusercontent.com/u/80256631/8192eu-4.1.17-v7-838.tar.gz
tar xzf 8192eu-4.1.17-v7-838.tar.gz
./install.sh
MrEngman
liltek
Wed Mar 02, 2016 9:18 am
I would also greatly appreciate some help with this matter. I am using a RPi 2, Running Raspbian (NOOBS). I have looked almost everywhere for the driver for my wifi module, hoping that someone may have found a solution to it and possibly already compiled, as I am quite new to most of this myself.
~$ uname -r
3.18.11-v7+
Once again,
If there's any way you can help, I would really appreciate it.
Thank you,
Brad
MrEngman
Wed Mar 02, 2016 5:55 pm
liltek wrote:I would also greatly appreciate some help with this matter. I am using a RPi 2, Running Raspbian (NOOBS). I have looked almost everywhere for the driver for my wifi module, hoping that someone may have found a solution to it and possibly already compiled, as I am quite new to most of this myself.
~$ uname -r
3.18.11-v7+
Once again,
Thank you,
Brad
Presumably you are using a 8192eu wifi module so you can find how to determine the driver to download looking here viewtopic.php?p=910778#p910778.
Check uname -a and use the kernel and build number you find to make the correct filename to download and install.
MrEngman
BaasChristo
Mon Mar 07, 2016 3:37 pm
MrEngman
You are the MAN!
Thank you very much for this - worked first time :)
Now my hair can grow back...
Where must I send the whisky to?
Regards
Chris
cokemina
Wed Mar 09, 2016 7:28 pm
Thanks !!!.
Worked 100% on a Raspberry pi 2 / B ,
my wifi hardware: TNB ADWF300 usb wifi dongle
my raspbian version is:
Linux 4.1.18-v7+ #846 SMP Thu Feb 25 14:22:53 GMT 2016 armv7l GNU/Linux
greetings from Barcelona !
tsisport
Sat Mar 12, 2016 3:44 pm
I am new to Linux and get this error when doing ./install.sh
please could you advise
root@RaspiNAS:/home/pi/Downloads/install_folder# ./install.sh
Realtek Wi-Fi driver Auto installation script
Novembor, 21 2011 v1.1.0
Decompress the driver source tar ball:
rtl8192EU_linux_v4.2.2_7585.20130524
Authentication requested [root] for make clean:
cd hal/OUTSRC/ ; rm -fr */*.mod.c */*.mod */*.o */.*.cmd */*.ko
cd hal/OUTSRC/ ; rm -fr *.mod.c *.mod *.o .*.cmd *.ko
cd hal/led ; rm -fr *.mod.c *.mod *.o .*.cmd *.ko
cd hal ; rm -fr */*/*.mod.c */*/*.mod */*/*.o */*/.*.cmd */*/*.ko
cd hal ; rm -fr */*.mod.c */*.mod */*.o */.*.cmd */*.ko
cd hal ; rm -fr *.mod.c *.mod *.o .*.cmd *.ko
cd core/efuse ; rm -fr *.mod.c *.mod *.o .*.cmd *.ko
cd core ; rm -fr *.mod.c *.mod *.o .*.cmd *.ko
cd os_dep/linux ; rm -fr *.mod.c *.mod *.o .*.cmd *.ko
cd os_dep ; rm -fr *.mod.c *.mod *.o .*.cmd *.ko
rm -fr Module.symvers ; rm -fr Module.markers ; rm -fr modules.order
rm -fr *.mod.c *.mod *.o .*.cmd *.ko *~
rm -fr .tmp_versions
Authentication requested [root] for make driver:
make ARCH=armv6l CROSS_COMPILE= -C /lib/modules/4.1.13+/build M=/home/pi/Downloads/install_folder/driver/rtl8192EU_linux_v4.2.2_7585.20130524 modules
make[1]: *** /lib/modules/4.1.13+/build: No such file or directory. Stop.
Makefile:1043: recipe for target 'modules' failed
make: *** [modules] Error 2
Compile make driver error: 2
Please check error Mesg
MrEngman
Sun Mar 13, 2016 8:58 am
tsisport wrote:I am new to Linux and get this error when doing ./install.sh
You need to create a link to your linux source directory like
sudo ln -s /home/pi/src/linux /lib/modules/4.1.13+/build
You will need to change /home/pi/src/linux to point to the directory where your linux source is.
If you are using raspbian OS you can download and install the driver I compile using the following viewtopic.php?p=910778#p910778 setting the filename to download using info from command uname -a to set the kernel version and build number in the file to download.
MrEngman
tsisport
Sun Mar 13, 2016 11:55 am
Thank you Mr E for you help, I have done as you advised and downloaded and installed but, the wifi connection continually drops in and out on my raspberry pi.
Regards Steve
MrEngman
Sun Mar 13, 2016 5:19 pm
tsisport wrote:Thank you Mr E for you help, I have done as you advised and downloaded and installed but, the wifi connection continually drops in and out on my raspberry pi.
Regards Steve
Sound like the sort of problem you could get with power supply issues. What type of Pi are you using? Do you see the red PWR led flashing at all?
Could possibly be a bad connection in your USB socket. May be changing the USB connector you are using could help.
MrEngman
ArcAiN6
Sat Apr 02, 2016 12:48 am
I'm having the same issues with this device.. I can't compile because /lib/modules/4.1.19v7-aufs/build doesn't exist.
uname -a produces this:
Linux raspberrypi 4.1.19v7-aufs #1 SMP Sun Mar 13 12:48:13 CET 2016 armv7l GNU/Linux
Which is different than earlier dropbox download items..
Any help would be appreciated, as i would love to get this working so i can untether my CNC machine from my desktop :D
MrEngman
Sat Apr 02, 2016 1:10 am
ArcAiN6 wrote:I'm having the same issues with this device.. I can't compile because /lib/modules/4.1.19v7-aufs/build doesn't exist.
/lib/modules/4.1.19v7-aufs/build is a symlink to the linux source you need to compile you driver with. You can create it using command
sudo ln -s /home/pi/src/linux /lib/modules/$(uname -r)/build
replacing directory /home/pi/src/linux to point to where you have your linux source directory.
MrEngman
ArcAiN6
Sat Apr 02, 2016 2:20 am
i was kind of hoping for less of a canned response..
I've been searching for over 4 hours to try to resolve this, and everything i've seen doesn't bode well.. This is the one forum thread i've found where someone has managed to build the drivers, but again, no real explination on how. Everywhere else seems to be that very response you gave, but no real explination on where to get the source, how much space i'll need etc. the other common response is to link to forum threads that seem to go no where..
It's like a viscous circle trying to figure out a few things..
1) What sources do i need
2) What is the easiest method to get them
3) How much storage space will i need
4) After seeing this issue has been around for years for this particular wifi module, why hasn't it been addressed at the OS level?
i get that this is a minimalistic OS, but the fact that this module has been plaguing users for years, one would think, by now, someone in the development team would have addressed it.. be it optional kernel downloads, or something a little less clunky than a git repo.
Sorry for venting, but i just seem to be going in ever frustrating circles here.. spinning my gears, going nowhere fast.
ArcAiN6
Sat Apr 02, 2016 2:58 pm
Turns out the issue i was having was due to bootberry's weird custom kernel...
used DD to write the raspbian image to USB drive
then reformatted TF-Card and copied boot partition from usb to tf card, and edited comandline.txt and edited the root= section to point to sda2.. booted everything up just fine, once that was done, my new uname -a response is:
Linux raspberrypi 4.1.19-v7+ #858 SMP Tue Mar 15 15:56:00 GMT 2016 armv7l GNU/Linux
Once i had the different kernel, applying the installer.sh went off without a hitch, and wifi is now working like a dream.
Thanks so much for building these installers.. But it would be really helpful to everyone if you could create a tutorial on how exactly to go about doing this for ourselves.
:D
John_Moses
Fri Apr 15, 2016 6:50 pm
Hello guys,
I am totally new to the Pi and am struggling right now with my wifi.
I need the 8192EU drivers, uname -a brought up:
Mr. Engman, could you provide me the right driver?
