MrEngman
Re: Realtek RTL8192EU ID 0BDA:818B
Thu Jul 21, 2016 4:51 pm
barkos wrote:Hi
I'm trying to instal this driver on my raspi b+. The kernel i have its 4.4.11+ #888 arm6l.
I tested the script install-wifi but it can't acces dropbox to check. Where can find it? any help.
Try this
wget www.fars-robotics.net/8192eu-4.4.11-888.tar.gz
tar xzf 8192eu-4.4.11-888.tar.gz
./install.sh
MrEngman
Colateral
Thu Jul 21, 2016 5:42 pm
MrEngman wrote:
Colateral wrote:HI,
My PI0 and PI3 release is 4.4.13-V7+. Do you have the RTL8192EU driver for it or something similar?
I downloaded the driver for 4.4.9-v7 but doesn't work.
Many Thanks,
Cata
The 4.4.9-v7 driver should work, it does for me. This is provided you are using the Raspbian image, Jessie or Wheezy.
For 4.4.13-v7+ try
wget https://dl.dropboxusercontent.com/u/80256631/8192eu-4.4.13-v7-894.tar.gz
tar xzf 8192eu-4.4.13-v7-894.tar.gz
./install.sh
MrEngman
Thanks. I did it again and it is working. You are the best.
I tried also the same on PI0 4.4.13+ (same OS) and there is not working. For this one what driver it is suitable? Here the 8192 eu adapter is plugged in uSB hub with lan (from Realtek too)
pi@pi0_220:~ $ uname -a
Linux pi0_220 4.4.13+ #894 Mon Jun 13 12:43:26 BST 2016 armv6l GNU/Linux
pi@pi0_220:~ $ lsusb
Bus 001 Device 005: ID 0bda:818b Realtek Semiconductor Corp.
Bus 001 Device 003: ID 0bda:8153 Realtek Semiconductor Corp.
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
MrEngman
Thu Jul 21, 2016 7:15 pm
Colateral wrote:Thanks. I did it again and it is working. You are the best.
The driver should work on the Pi Zero. I have a wifi module using that driver on my Pi Zero and it is working OK. I am currently connected to the Pi Zero using SSH from my W7 laptop via the wifi.
MrEngman
Colateral
Fri Jul 22, 2016 9:36 am
MrEngman
First I did
apt-get update apt-get upgrade and   apt-get dist-upgrade
... so everything is up to date.
I downloaded on PI0 the above package and I changed install.sh for 4.4.13+ (from 4.4.13-v7+).Then I executed the script.
I rebooted the PI and unfortunately I don't have WLAN1.
Bus 001 Device 004: ID 0bda:818b Realtek Semiconductor Corp.
Bus 001 Device 003: ID 148f:5370 Ralink Technology, Corp. RT5370 Wireless Adapter
Bus 001 Device 002: ID 05e3:0606 Genesys Logic, Inc. USB 2.0 Hub / D-Link DUB-H4 USB 2.0 Hub
pi@pi0_220:~ $ ifconfig
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
wlan0     Link encap:Ethernet  HWaddr 00:0f:60:0b:84:77
          inet addr:192.168.20.220  Bcast:192.168.20.255  Mask:255.255.255.0
          inet6 addr: fe80::20f:60ff:fe0b:8477/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:235 errors:0 dropped:0 overruns:0 frame:0
          TX packets:286 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:30519 (29.8 KiB)  TX bytes:40116 (39.1 KiB)
pi@iOla_pi0_220:~ $ ls -ltr /lib/modules/4.4.13+/kernel/drivers/net/wireless
total 1084
drwxr-xr-x 4 root root   4096 Jun  6 16:25 brcm80211
drwxr-xr-x 3 root root   4096 Jun  6 16:25 mediatek
drwxr-xr-x 4 root root   4096 Jun  6 16:25 realtek
drwxr-xr-x 2 root root   4096 Jun  6 16:26 b43
drwxr-xr-x 2 root root   4096 Jun  6 16:26 zd1211rw
drwxr-xr-x 2 root root   4096 Jun  6 16:26 rt2x00
drwxr-xr-x 2 root root   4096 Jun  6 16:26 p54
drwxr-xr-x 2 root root   4096 Jun  6 16:26 mwifiex
drwxr-xr-x 2 root root   4096 Jun  6 16:26 libertas_tf
drwxr-xr-x 2 root root   4096 Jun  6 16:26 hostap
drwxr-xr-x 2 root root   4096 Jun  6 16:26 b43legacy
drwxr-xr-x 6 root root   4096 Jun  6 16:26 ath
-rw-r--r-- 1 root root  32112 Jun 22 07:04 zd1201.ko
-rw-r--r-- 1 root root  46860 Jun 22 07:04 rndis_wlan.ko
-rw-r--r-- 1 root root  62688 Jun 22 07:04 mac80211_hwsim.ko
-rw-r--r-- 1 root root  54452 Jun 22 07:04 at76c50x-usb.ko
-rw-r--r-- 1 root root 851792 Jul  1 16:48 8192eu.ko
MrEngman
Fri Jul 22, 2016 11:41 am
Colateral wrote:
First I did
total 1084
For the Pi Zero you need to download a different filename(no "-v7") as it uses a different kernel release.
Try this
wget https://dl.dropboxusercontent.com/u/80256631/8192eu-4.4.13-894.tar.gz
tar xzf 8192eu-4.4.13-894.tar.gz
./install.sh
Notice that the filename to download has no "-v7".
There is a script which will automatically select and download the correct driver for several different types of wifi modules including the 8192eu version. You can download and install it using commands
wget https://dl.dropboxusercontent.com/u/80256631/install-wifi.tar.gz
tar xzf install-wifi.tar.gz
Then run command ./install-wifi -h for details on how you can use it.
MrEngman
barkos
Fri Jul 22, 2016 12:46 pm
Many thanks Its work.
thanks
MrEngman
Fri Jul 22, 2016 1:31 pm
barkos wrote:Many thanks Its work.
thanks
That's good to hear. Glad to be able to help.
MrEngman
Colateral
Sun Jul 24, 2016 9:59 am
MrEngman wrote:
Colateral wrote:
First I did
total 1084
Try this
./install.sh
MrEngman
Many thanks ... 8192eu-4.4.13-894.tar.gz is working with PI0 4.4.13+.
You re the best.
iancheckley
Wed Aug 03, 2016 1:05 pm
MrEngman, could you please provide me 8192eu driver for:
uname -a
Linux black-pearl 4.4.10-hypriotos-v7+ #1 SMP PREEMPT Fri May 20 14:49:10 UTC 2016 armv7l GNU/Linux
lsusb
Bus 001 Device 009: ID 2001:3319 D-Link Corp.
Bus 001 Device 005: ID 0bda:0109 Realtek Semiconductor Corp.
Thanks ian C.
dounzi
Mon Aug 08, 2016 9:15 pm
hi mr engman,
thank you in advance for your job.
everybody look happy on this post.
unfortunately,
i think i miss something
i do an:
uname -a
i get:
Linux raspbweb 4.4.16-v7+ #899 SMP Thu Jul 28 12:40:33 BST 2016 armv7l GNU/Linux
then itry to download the file you propose:
 sudo wget https://dl.dropboxusercontent.com/u/80256631/8192eu-4.4.16-899.tar.gz
then:
tar xzf 8192eu-4.4.16-899.tar.gz
and:
./install.sh
finally i reboot my pi
but my dongle isn't recognized..
if i missed something please let me know
thank you for your time
dounzi
MrEngman
Tue Aug 09, 2016 10:06 am
dounzi wrote:hi mr engman,
unfortunately,
i do an:
uname -a
i get:
then:
and:
./install.sh
dounzi
What is the output of command lsusb just to see what your wifi is.
MrEngman
iancheckley
Tue Aug 09, 2016 11:59 am
MrEngman, did you see this request?
iancheckley wrote:MrEngman, could you please provide me 8192eu driver for:
uname -a
lsusb
Thanks ian C.
MrEngman
Tue Aug 09, 2016 1:55 pm
iancheckley wrote:MrEngman, did you see this request?
uname -a
lsusb
Thanks ian C.
Yes I did. Sorry I didn't respond earlier but I've serious problems with my network domain server and have issues accessing the internet.
Can you tell me where to get the hypriotos SD card image, and the source if possible, so I can then try and compile a driver?
MrEngman
iancheckley
Thu Aug 11, 2016 12:07 am
MrEngman, did not expect you would need to have hypriot image to compile driver - you can download here http://blog.hypriot.com/downloads/ - git https://github.com/hypriot/image-builder-rpi
THANKS
iancheckley
Mon Aug 29, 2016 4:36 am
uname -a
lsusb
Thanks ian C.
MrEngman
Mr Engman, I have gone ahead and compiled the driver using instructions here (https://gibbalog.blogspot.com.au/2015/1 ... ry-pi.html) but unfortunately when I execute "modprobe 8192eu" I get the error:
"modprobe: ERROR: could not insert '8192eu': Exec format error"
I have tried "modprobe --force 8192eu", but still get the same error.
Do you perhaps know what I need to do to not get this error?
THANKS for your help
FOUND the issue I was running kernel 4.4.15 but had downloaded source for 4.4.13
catflix
Wed Sep 14, 2016 1:45 pm
Just want to say a big big thank you to MrEngman. Just acquired a wifi dongle with the REaltek chip and reading the first page, especially where you explained how to get the correct version for the kernal had me up and running in just a couple of minutes.
Much love and many thanks :)
gurt
Mon Oct 03, 2016 7:12 am
MrEngman if you could please help me
Checking for a new 8192eu wifi driver module for your current kernel.
A driver does not yet exist for this update.
my uname -a is
uname -a
Linux kali 4.1.19-v7 #1 SMP Tue Mar 15 15:10:00 CDT 2016 armv7l GNU/Linux
i updated and upgraded and the kernel will not change to a more recent version.
I got this kali linux arm img from
https://www.offensive-security.com/kali ... rm-images/
or you can use to download directly:
https://images.offensive-security.com/a ... pi2.img.xz
any help would be greatly appreciated
MrEngman
Mon Oct 03, 2016 10:56 pm
gurt wrote:MrEngman if you could please help me
my uname -a is
uname -a
Hi Gurt,
The drivers I usually compile are for Raspbian which is why it did not work for you using kali.
However, I've managed to compile the driver for kali and you should be able to download and install it using a terminal window and commands
wget https://dl.dropboxusercontent.com/u/80256631/8192eu-4.1.19-v7-kali.tar.gz
tar xzf 8192eu-4.1.19-v7-kali.tar.gz
./install.sh
Whether it will do what you and kali want it to do I don't know as I normally only use my drivers for connecting to APs. I have the 8192eu running on kali 4.1.19-v7 #1 but it is just connected to my home wireless network.
MrEngman
gurt
Fri Oct 07, 2016 2:04 am
my uname -a is
uname -a
Hi Gurt,
./install.sh
MrEngman
is there a way for this driver to not overwrite the on board wifi on raspberry pi3 b. In other words is there a way to have the usb wifi card be wlan1 not wlan0? keeping the native wlan0 the onboard wifi? im not sure if i just didnt install it properly or if this is the only way?
MrEngman
Fri Oct 07, 2016 2:59 am
gurt wrote: is there a way for this driver to not overwrite the on board wifi on raspberry pi3 b. In other words is there a way to have the usb wifi card be wlan1 not wlan0? keeping the native wlan0 the onboard wifi? im not sure if i just didnt install it properly or if this is the only way?
Hi Gurt,
Sorry my fault. Installing the 8192eu disables the built in wifi driver but you can enable it again.
Installing the 8192eu wifi driver also installs a file /etc/modprobe.d/8192eu.conf which disables power management for the 8192eu driver to stop it disconnecting from the wifi network.
This file also includes a line that disables the built in driver on the Pi 3 B. To re-enable the build in wifi edit the file /etc/modprobe.d/8192eu.conf and comment out the line blacklist brcmfmac by adding the # character to the start of the line like #blacklist brcmfmac. This will then allow the built in wifi to work. Reboot the Pi and you should find both wifi's working.
The names they will be assigned will depend on the order they are loaded which may or may not be what you want. It should be possible to apply the names you want to each wifi adapter using udev using file /etc/udev/rules.d/70-persistent-net.rules to assign the names. That is if kali includes udev. Google should help here.
MrEngman
melson
Wed Oct 12, 2016 2:24 pm
Hello MrEngman,
I have a Tenda U1 with RTL8192EU chip.. I've been trying to make it work for RPI3.
this is the firmware i've been using.
Linux raspberrypi 4.4.21-v7+ #911 SMP Thu Sep 15 14:22:38 BST 2016 armv7l GNU/Linux
Thank you in advance for helping me. :D
MrEngman
Wed Oct 12, 2016 6:08 pm
melson wrote:Hello MrEngman,
Can you post the output of command lsusb so I can see the USB ID the Tenda U1 uses?
I have a script which will determine the driver you need and will automatically download and install it if it recognises the wifi module you use. You can download and install the script using commands
MrEngman
melson
Thu Oct 13, 2016 4:12 pm
this is result for lsusb
i installed your driver.
it works like a charm..
i want to use RPi3 as a tally light (for Atem switcher) and communicator (using mumble).
and you gave me the solution my last problem.
Thank you very much!..
jadames
Fri Oct 28, 2016 3:59 am
@ MrEngman
This worked for me perfectly too. Can you teach this man to fish so that I can become self-sufficient? I would love to learn your magic.
anonmd
Mon Oct 31, 2016 4:08 pm
uname -a return
Linux raspberrypi 4.4.22v7-aufs #0 SMP Fri Sep 30 12:46:47 CEST 2016 armv7l GNU/Linux
but get error 404 :
wget https://dl.dropboxusercontent.com/u/802 ... s-0.tar.gz
and :
wget https://dl.dropboxusercontent.com/u/802 ... ufs.tar.gz.
