iinnovations
HAT Mechanical Spec
Sun Mar 01, 2015 2:22 am
Hey all,
I want to double check on the mechanical spec. As it is written, the CSI port is 20mm from the bottom of the board. It's quite in the way, especially with respect to real estate for connectors exiting on the same side as the USB connector. For my board, I moved the CSI connector down about 10mm, which allows me to put three connectors on this side, but still lines up east-west with the CSI cable and easy feed through the slot. See image below.
What I want to check is if the mechanical spec is so rigid that I cannot call my board a HAT. If not, I can call it 'HAT-like', I suppose. Right?
Thanks,
C
CuPID Controls :: Open Source browser-based sensor and device control
interfaceinnovations.org/cupidcontrols.html
cupidcontrols.com
Fat D
Re: HAT Mechanical Spec
Sun Mar 01, 2015 8:52 am
The cutouts for the FPC cables (CSI and DSI) are an optional recommendation, you could do away with them completely if you wanted.
Source: second-to-last FAQ point on https://github.com/raspberrypi/hats
iinnovations
Sun Mar 01, 2015 9:37 am
Beauty. Thanks. My google-fu was weak on this one.
C
cupidcontrols.com
