3corey2
my screen is white...
Fri Feb 27, 2015 9:40 pm
i added a screen, one that directly connects to the board (3.2inch) and it just came up white. my pi works, i pluged it in to the tv via hdmi to check but my tiny screen just turns on plain white. soooooo... do i need software or something? what are the 3 buttons on it for? its touch screen... so idk.
ras pi 2, gotta love it.
DirkS
Re: my screen is white...
Fri Feb 27, 2015 10:40 pm
Impossible to say without knowing what screen it is exactly...
If it's connected to the GPIO header you will need a driver for it.
Do you more info? A link?
klricks
Sat Feb 28, 2015 4:18 am
You need to contact the seller to get a working OS image -OR- a driver AND detailed step by step instructions on how to install them.
Make sure the seller has updated the OS or driver to work with the RPi2B.
3corey2
Wed Mar 04, 2015 3:32 pm
http://www.circuitbasics.com/setup-lcd- ... pberry-pi/
so im using the waveshare 32b, this tutorial walks throught the exact setup,
EXEPT they are using a b+ and not a pi2 like me...
so what edits to the tutorial should help me set up MY pi?
and im losing connection alot making it impossible to update the software...
any help there?
ANYONE!
DirkS
Wed Mar 04, 2015 3:55 pm
Had a look through these instructions and I haven't seen anything that *stops* it from working on a Pi2B.
Some things (like commenting out blacklisted items) may not be relevant anymore, but that should not make a difference.
Wed Mar 04, 2015 4:29 pm
3corey2 wrote:http://www.circuitbasics.com/setup-lcd- ... pberry-pi/
any help there?
ANYONE!
Did you try the Notro Drivers/Firmware on a fully dist-upgrade updated Raspbian :?:
https://github.com/notro/fbtft/wiki
RPi 4B 4GB (SSD Boot)..
DirkS
Wed Mar 04, 2015 4:33 pm
any help there?
ANYONE!
That's actually part of the tutorial the OP linked to.
3corey2
Wed Mar 04, 2015 6:23 pm
i read in the comments something about skipping a step, ill try that later today... :( this is taking waaayy longer than it should.
DrJonSmith
Thu Mar 05, 2015 5:10 am
This is what I did for my 3.2" screen:
http://diyhacking.com/raspberry-pi-touc ... -tutorial/
Also if using a Mac use applepi baker to put the image file on sd card.
DirkS
Thu Mar 05, 2015 8:58 am
DrJonSmith wrote:This is what I did for my 3.2" screen:
Is the .img you used Pi2B compatible?
