markfree
PoE+ HAT Fan not working at lower state
Sun Aug 01, 2021 8:12 pm
I've got 2 Pi's with the new PoE+ Hat and both were working fine with the correct fan curve set by dtoverlay=rpi-poe-plus.
I've set it like this:
# PoE+ FAN TEMPERATURE CONTROL
dtparam=poe_fan_temp0=45000,dtparam=poe_fan_temp0_hyst=3000
dtparam=poe_fan_temp1=50000,dtparam=poe_fan_temp1_hyst=3000
dtparam=poe_fan_temp2=62000,dtparam=poe_fan_temp2_hyst=4000
dtparam=poe_fan_temp3=70000,dtparam=poe_fan_temp3_hyst=5000
After the latest firmware update, I noticed that fan_temp0 and fan_temp1 are probably not working anymore.
$ uname -r
5.10.52-v8+
The fan only spins up when the temperature reaches 62ºC.
Now, my Pi's are running hotter and the fan only spins at a higher rpm.
When the fan is not spinning it shows state "2" and when it is spinning it shows state 3.
$ cat /sys/class/thermal/cooling_device0/cur_state
2
When I check vcgencmd's config, there's no "rpi-poe-plus"
Any ideas on why that is happening with both HAT's?
markfree
Re: PoE+ HAT Fan not working at lower state
Sun Aug 01, 2021 10:33 pm
If I set rpi-poe-plus as the overlay readme suggests,
dtoverlay=rpi-poe-plus,poe_fan_temp0=45000,poe_fan_temp0_hyst=3000,poe_fan_temp1=50000,poe_fan_temp1_hyst=3000,poe_fan_temp2=62000,poe_fan_temp2_hyst=4000,poe_fan_temp3=70000,poe_fan_temp3_hyst=5000
It doesn't work. The fan spins up to match the default behavior, not the ones I set.
$ cat /sys/class/hwmon/hwmon0/device/trip_point_0_temp
55000
$ cat /sys/class/hwmon/hwmon0/device/trip_point_1_temp
50000
$ cat /sys/class/hwmon/hwmon0/device/trip_point_2_temp
45000
$ cat /sys/class/hwmon/hwmon0/device/trip_point_3_temp
45000
Now, if I set it like this:
dtparam=poe_fan_temp0=45000,poe_fan_temp0_hyst=3000
dtparam=poe_fan_temp1=50000,poe_fan_temp1_hyst=3000
dtparam=poe_fan_temp2=62000,poe_fan_temp2_hyst=4000
dtparam=poe_fan_temp3=70000,poe_fan_temp3_hyst=5000
The strange behavior is the same. It works for states 3 and 4, not 1 and 2.
70000
62000
50000
45000
It seems not to work at lower speeds anymore.
markfree
Tue Aug 03, 2021 8:54 pm
I've reinstalled the Raspberry Pi OS and the strange behavior is the same, no spin at states 1 and 2.
It all started out of the blue with both PoE+ HATs, right after I rebooted and the kernal was updated to version "5.10.52-v8+". Prior version "5.10.17-v8+" was working fine.
I'm lost now. Any ideas?
pimeup
Thu Aug 05, 2021 4:22 pm
i thought 1 & 2 were working before as well. But im experiencing this on raspi os and ubuntu pi (21.04 64 bit). Initially i started with ubuntu pi, but then figured i should give the native os a shot real quick. so i loaded up raspi os and updated everything including firmware and then it seemed to stop working for me as well. I thought it was working normally in ubuntu so i ended switching back over. But when i went to set those values in ubuntu it was doing the same thing, ignore 1&2 and turn on for 3&4
markfree
Sat Aug 14, 2021 3:23 pm
I've created an issue at GitHub's "raspberrypi/firmware" and, with the help of fellow "chri-kai-in", I was able to get the fan working again.
I had to change the fan default cooling levels to make it work again.
It is all described at the issue above.
I hope it helps.
