Printe
Connecting a HiFiBerry DAC+ Pro to a Raspi by soldering
Sun Jul 18, 2021 2:29 pm
Hello folks!
I got a Raspberry Pi 4 with 4GB RAM and a HiFiBerry DAC+ Pro. Actually I cannot attatch it directly to the Raspi because of the heat sink. So I got a ribbon cable that covers all the 40 pins. It's not the most flexible thing since the layout of my housing means that I would need to twist the cable like crazy.
I'm thinking about just soldering the needed pins to single cables to have a clean thing. But I can't find any information about which ones are used. Can anybody tell me which they are? Is there a connection scheme somewhere in the net? Can't find one...
Thank you in advance!
Marcus
Re: Connecting a HiFiBerry DAC+ Pro to a Raspi by soldering
Sun Jul 18, 2021 6:56 pm
Take off the heatsink would be the obvious suggestion.
Working in the Application's Team.
Sun Jul 18, 2021 7:00 pm
Hello folks!
Marcus
Why the Heatsink ?? it is not feasible to overheat a Raspberry Pi SBC:
https://www.raspberrypi.org/documentati ... agement.md
I am a volunteer, take what I advise as advice not the utopian holy grail.
Printe
Sun Jul 18, 2021 10:42 pm
Thank you @gordon77 this helps! :-)
Imperf3kt
Contact: Twitter
Sun Jul 18, 2021 10:52 pm
But it is possible for the Pi to throttle, limiting performance to a level potentially inadequate for the OPs use.
... That said, they mentioned the Pi was inside a case. Without a fan and vents, that Heatsink is next to useless.
55:55:44:44:4C
52:4C:52:42:41
Printe
Mon Jul 19, 2021 12:43 am
Thank you, that's actually the point. I'm not overclocking. It's simply that it gets to hot white using YouTube for instance.
The case is quite airy. It's more like a frame than a case. The heatsink is huge and potentially made to carry a fan. But I'll try it without first.
Mon Jul 19, 2021 3:05 am
...but *to hot* is not a measurement but a feeling, you need to provide evidence it is throttling and therefore need this *cooling*
Printe
Mon Jul 19, 2021 8:46 am
Well, you're right. It's throttling. I tracked the temperature and came to the conclusion that it needs cooling to avoid throttling.
6by9
Mon Jul 19, 2021 9:05 am
Use a tall header (eg https://www.ebay.co.uk/itm/170578495165) and some standoffs to raise the DAC board above the Pi and heatsink.
I'm using those all the time now to attach devices in a manner that can be easily swapped between without disturbing the wiring.
aBUGSworstnightmare
Thu Jul 22, 2021 6:25 am
+1
I.e. https://www.berrybase.de/raspberry-pi/r ... PI-CGST-62
They are working fine with the armour cases. Pictured is a Pi4 with armor case and a custom HAT(grey connector on Bottom side). For this setup the distance between the PCB and the heatsink is around 7mm (= max component height). There is no component on the Top side of this HAT.
