rhe8502
Contact: Twitter
Displayotron 3000 - toggle backlight on/off with joystick
Tue Sep 10, 2019 10:00 pm
I'm wondering if there is a way to check the backlight status on a Pimoroni DisplayOtron 3000 (e.g., if the backlight is currently on, or off), so that when I push the joystick button the backlight is either toggled on or off.
I tried to do the following, but it doesn't work.
# Set Joystick options
@nav.on(nav.BUTTON)
def handle_button(pin):
    if backlight.off():
         backlight.rgb(50, 255, 50)
    else:
        backlight.off()
The only way I managed to accomplish this is if I introduce a variable called "status" and change to either True or False. It works, but it doesn't seem to be an elegant solution.
@nav.on(nav.BUTTON)
    global status
    if status:
        backlight.off()
        status=False
    else:
        status=True
pcmanbob
Re: Displayotron 3000 - toggle backlight on/off with joystick
Wed Sep 11, 2019 10:36 am
Hi.
You might get an answer if you ask on Pimoroni's support forum, after all its their product.
https://forums.pimoroni.com/c/support
scotty101
Wed Sep 11, 2019 11:08 am
The problem is that the code library for the displayotron, does not allow you to read the current status of the backlight.
The line
if backlight.off():
Will turn the LED off and execute the code inside the if branch if backlight.off() returns true but the off function doesn't return anything so the if branch will never execute.
The solution you've come up with is probably what you are stuck with unless you modify the code library to keep track of what the status of the backlight is.
Electronic and Computer Engineer
Pi Interests: Home Automation, IOT, Python and Tkinter
rhe8502
Contact: Twitter
Wed Sep 11, 2019 11:59 am
Hi.
Thanks pcmanbob. I did post it on the Pimoroni support forum as well, but haven't received any feedback on it yet.
https://forums.pimoroni.com/t/displayot ... tick/11597
rhe8502
Contact: Twitter
Wed Sep 11, 2019 12:05 pm
The line
if backlight.off():
Thanks scotty101. Yes, that's what I was trying to find out. Would be nice to be able to query the status. Not the end of the world though, the workaround works well enough for my simple use case.
Will have a look at the code library later as well.
