belos
Raspberry Pi TV Hat DVB-T2 Gateway (Tvheadend with FFmpeg and realtime hardware video stream transcoding)
Tue Nov 20, 2018 4:23 pm
This is a very-very short installation manual that gives 100% working result.
Hardware: Raspberry Pi 3 Model B and Raspberry Pi TV Hat.
1. Install Raspbian Jessie (not Raspbian Stretch!) and update the system.
2. Install Tvheadend v4.3 (unstable) as described here:
https://tvheadend.org/projects/tvheaden ... tories#fn3
3. Configure Tvheadend, and test viewing your air TV channels using default MPEG-TS Pass-through "pass" stream profile.
4. Download and compile OpenMAX-enabled FFmpeg:
https://www.reddit.com/r/raspberry_pi/c ... ith_ffmpeg
4a. (not necessary!). Run the following command and make sure you can see the test picture. This means that hardware acceleration works properly:
"gst-launch-1.0 -v videotestsrc ! omxh264enc ! h264parce ! omx264dec ! glimagesink"
5. Create the new streaming profile in Tvheadend web interface (Configuration->Stream->Stream Profiles) using "MPEG-TS Spawn/ built-in" type with the command line:
"ffmpeg -i - -f mpegts -c:a copy -c:v h264_omx -b:v 368k pipe:1"
This will generate the stream with the bitrate about 500-600 kbit/s instead of several Mbit/s using GPU hardware transcoding.
During the transcoding CPU usage will not be higher than 40-60% comparing to 150% in case if you are using any other software transcoding. CPU temperature will not raise above 60-65°C.
Most probably this configuration will work on any Raspberry Pi (even on RPi Zero), of course, depending on the input signal complexity.
I also have Kodi on my RPi Zero connected to TV that is used as a client system for the described installation.
Hope this info will help someone. I´m open for any comments and questions.
Re: Raspberry Pi TV Hat DVB-T2 Gateway (Tvheadend with FFmpeg and realtime hardware video stream transcoding)
Tue Nov 20, 2018 6:23 pm
4. Run the following command and make sure you can see the test picture. This means that hardware acceleration works properly:
5. Create new streaming profile in Tvheadend web interface (Configuration->Stream->Stream Profiles) using "MPEG-TS Spawn/ built-in" type with the command line:
Raspbian Jessie is no longer supported and any user not aware will try this on the 3B+ / 3A+......
Retired disgracefully.....
belos
Wed Nov 21, 2018 8:35 am
Thanks, that´s right. But sometimes we have to use old, but proved solutions to achieve the desired result.
gkreidl
Wed Nov 21, 2018 9:36 am
My rtranscode V4 package offers a complete transcoding solution which works with different backends on both Jessie and Stretch. Transcoding on Jessie is more efficient though because the gst-omx module has implemented hardware scaling, which is missing in the Stretch version.
viewtopic.php?f=38&t=123876
Minimal Kiosk Browser (kweb)
fanoush
Wed Nov 21, 2018 12:47 pm
Just wondering what type of trancoding (resolution? codec types?) is this targeted for? Can this transcode HEVC/h265 to h264 in realtime on pi3b+? Or does it trancode mpeg-2 to h264? Can it do mpeg-2 in realtime without paid HW codec?
john564
Sun Jul 07, 2019 11:21 am
OMG...
should be
gst-launch-1.0 -v videotestsrc ! omxh264enc ! h264parse ! omxh264dec ! glimagesink
list parameters with gst-inspect-1.0
you have no idea how long time I spent to find out the 100% working guide was wrong
Sun Jul 07, 2019 11:57 am
OMG...
should be
I stated above the guide is for Jessie, not Stretch or Buster :shock:
6by9
Sun Jul 07, 2019 12:39 pm
It's not a jessie/stretch/buster complaint, but the typo with h264parce instead of h264parse.
belos
Sun Jul 07, 2019 2:53 pm
Actually, you can skip this gst-launch-1.0 command and go strait to number 5 :)
I am still on Jessie. If you want, you can try to repeat it on Buster and tell the community if it works or not. I can repeat it in August when I have physical access to the system.
Update as of 16.07.2019:
I confirm, that the above instruction also works on Raspbian Buster. It´s easy and free.
Just compile FFmpeg with options, install TVheadend 4.3, and use Spawn profile for the HW-accelerated stream transcoding.
john564
Sun Jul 21, 2019 12:11 pm
thanks, its beginning to come together now.
# Install tvheadend 4.3 unstable on Raspbian Buster
wget https://markclarkstone.co.uk/downloads/ ... _armhf.deb
sudo dpkg -i tvheadend_4.3-1801~g7f952c2ed~raspbianbuster_armhf.deb
sudo apt --fix-broken install
#test
sudo apt-get install gstreamer1.0-tools
# transcode setting for tvheadend
ffmpeg -i - -f mpegts -c:a copy -c:v h264_omx -b:v 600k -maxrate 600k -bufsize 1M pipe:1
belos
Mon Jul 22, 2019 10:10 am
#test
Please do not go through the #test section. It is not needed because it is not the test of ffmpeg functionality. This was my mistake.
john564
Fri Aug 16, 2019 9:43 pm
Some more transcoding options, to use with "MPEG-TS Spawn/build-in"
ffmpeg -i - -f mpegts -c:a copy -c:v h264_omx -threads 4 -crf 28 -b:v 600k -maxrate 900k -bufsize 1M pipe:1
gst-launch-1.0 fdsrc fd=0 \
! decodebin name=decoder decoder. \
! queue \
! avenc_ac3 \
! mpegtsmux name=mux \
! fdsink fd=1 decoder. \
! omxh264enc target-bitrate=600000 control-rate=variable \
! video/x-h264,stream-format=byte-stream,profile=high \
! mux.
belos
Sat Aug 17, 2019 8:29 pm
Thank you, John!
This gst-launch is a really good thing! Less CPU usage with better quality. I guess it can transcode Full HD content on my RP3 as good as SD content!
[Update]
But, unfortunately, after several minutes of operation, gst-launch-1.0 crashes and the session does not terminate.
Perhaps this converter is very sensitive to input errors compared to ffmpeg.
I'll try to enable debug messages and see what happens...
john564
Tue Aug 20, 2019 8:30 am
I don't have problem with it crashing when using gst-launch-1.0
EDIT: no problem with SD, HD seems to have issue
But I am using RPi4 and gave more memory to GPU at the start.
in
sudo raspi-config
--> 7 Advanced Options
--> A3 Memory Split
How much memory (MB) should the GPU have ?
--> 512
But I don't know how to find out how much memory and processor load the GPU is actually using
to fine tune it.
Any idea ?
also I often use a different profile, with no bitrate control, (but an annoying strange coloured line at the bottom)
! queue \
! avenc_ac3 \
! omxh264enc \
! mux.
Note: the site https://markclarkstone.co.uk is down at the moment
I saved a copy of his deb package to dropbox, just post here, incase its needed
# install
wget --no-check-cert  https://www.dropbox.com/s/zt5bcsc6126f4mp/tvheadend_4.3-1801_g7f952c2ed_raspbianbuster_armhf.deb
sudo dpkg -i tvheadend_4.3-1801_g7f952c2ed_raspbianbuster_armhf.deb
