DarkCmder
Raspberry Pi 3 Compatibility With RedBear IoT pHAT
Mon Jun 05, 2017 1:03 pm
G'day Forum Members,
I bought the RedBear IoT pHAT (https://redbear.cc/product/iot-phat.html) to use with a Raspberry Pi 3 (RPi3). I wanted to use the combination for a side project, where I route a mobile phones traffic through the RedBear IoT pHAT WLAN (my access point) and forward it out of the RPi3´s onboard WLAN that is connected to an open access point.
Setup
I am currently running Raspbian Jessie with Pixel April 2017:
cat /proc/version
Linux version 4.9.24-v7+ ([email protected]) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #993 SMP Wed Apr 26 18:01:23 BST 2017
My RedBear IoT pHAT has the latest firmware:
more /proc/device-tree/hat/product
IoT pHAT w/eep_v0.4
Background
I note on RedBear's GitHub page (https://github.com/redbear/IoT_pHAT) they do NOT/NOT specifically mention the RPi3, but they say:
The IoT pHAT will also work on other 40-pin RPi boards such as RPi Model A+ and RPi 2
I came across this post on the raspberrypi forums (viewtopic.php?f=63&t=180624&p=1148351&h ... 3#p1148351) where 'summersab' said s/he reached out to RedBear and reported this as their response:
Unfortunately, we do not support using our IoT pHAT together with the built-in WiFi of Pi3 or Zero W. We are using the same RF chipset as them.
Looking through RedBear's IoT pHAT forum threads I originally found this post (http://discuss.redbear.cc/t/iot-phat-with-rpi3/1762) which suggested that the onboard WLAN will be deactivated. It's not deactivated as such, but there is a clash with the devices as reported by dmesg:
dmesg | grep brcmfmac
[ 4.422477] usbcore: registered new interface driver brcmfmac
[ 4.700169] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: May 27 2016 00:13:38 version 7.45.41.26 (r640327) FWID 01-df77e4a7
[ 4.719978] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
[ 5.533067] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
[ 8.972004] brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
[ 8.972020] brcmfmac: brcmf_add_if: ignore IF event
[ 8.976716] brcmfmac: power management disabled
[ 9.493332] brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
[ 9.493350] brcmfmac: brcmf_add_if: ignore IF event
Observations/Troubleshooting
When the IoT pHAT is connected, it would appear that it is always the device that comes up everytime. This is confirmed through checking the MAC address.
Noting each WLAN has a different MAC address, I thought I would try assigning them different interface addresses using udev rules:
vi /etc/udev/rules.d/70-persistent-net.rules
ACTION=="add", SUBSYSTEM=="net", DRIVER=="brcmfmac", ATTR{address}=="b8:27:eb:XX:XX:XX", NAME="wlan0"
ACTION=="add", SUBSYSTEM=="net", DRIVER=="brcmfmac", ATTR{address}=="44:2c:05:XX:XX:XX", NAME="wlan1"
I believe it pretty much does the same as udev, but I also tried using systemd settings:
vi /etc/systemd/network/25-wireless.link
[MATCH]
MACAddress=b8:27:eb:XX:XX:XX
Driver=brcmfmac
[LINK]
Name=wlan0
[MATCH]
MACAddress=44:2c:05:XX:XX:XX
Driver=brcmfmac
[LINK]
Name=wlan1
However this did not bring both up.
I also used udevadm to do a compare of their entries for uniqueness:
udevadm info --attribute-walk -p /sys/class/net/wlan0
Onboard wlan
Udevadm info starts with the device specified by the devpath and then
walks up the chain of parent devices. It prints for every device
found, all possible attributes in the udev rules key format.
A rule to match, can be composed by the attributes of the device
and the attributes from one single parent device.
  looking at device '/devices/platform/soc/3f300000.mmc/mmc_host/mmc1/mmc1:0001/mmc1:0001:1/net/wlan0':
    KERNEL=="wlan0"
    SUBSYSTEM=="net"
    DRIVER==""
    ATTR{addr_assign_type}=="0"
    ATTR{addr_len}=="6"
    ATTR{broadcast}=="ff:ff:ff:ff:ff:ff"
    ATTR{carrier}=="0"
    ATTR{carrier_changes}=="1"
    ATTR{dev_id}=="0x0"
    ATTR{dev_port}=="0"
    ATTR{dormant}=="0"
    ATTR{flags}=="0x1003"
    ATTR{gro_flush_timeout}=="0"
    ATTR{ifalias}==""
    ATTR{ifindex}=="3"
    ATTR{iflink}=="3"
    ATTR{link_mode}=="1"
    ATTR{mtu}=="1500"
    ATTR{netdev_group}=="0"
    ATTR{operstate}=="down"
    ATTR{proto_down}=="0"
    ATTR{tx_queue_len}=="1000"
    ATTR{type}=="1"
  looking at parent device '/devices/platform/soc/3f300000.mmc/mmc_host/mmc1/mmc1:0001/mmc1:0001:1':
    KERNELS=="mmc1:0001:1"
    SUBSYSTEMS=="sdio"
    DRIVERS=="brcmfmac_sdio"
    ATTRS{class}=="0x00"
    ATTRS{device}=="0xa9a6"
    ATTRS{vendor}=="0x02d0"
  looking at parent device '/devices/platform/soc/3f300000.mmc/mmc_host/mmc1/mmc1:0001':
    KERNELS=="mmc1:0001"
    SUBSYSTEMS=="mmc"
    DRIVERS==""
    ATTRS{type}=="SDIO"
  looking at parent device '/devices/platform/soc/3f300000.mmc/mmc_host/mmc1':
    KERNELS=="mmc1"
    SUBSYSTEMS=="mmc_host"
    DRIVERS==""
  looking at parent device '/devices/platform/soc/3f300000.mmc':
    KERNELS=="3f300000.mmc"
    SUBSYSTEMS=="platform"
    DRIVERS=="mmc-bcm2835"
    ATTRS{driver_override}=="(null)"
  looking at parent device '/devices/platform/soc':
    KERNELS=="soc"
    DRIVERS==""
  looking at parent device '/devices/platform':
    KERNELS=="platform"
    SUBSYSTEMS==""
    DRIVERS==""
RedBear IoT pHAT
KERNEL=="wlan0"
SUBSYSTEM=="net"
DRIVER==""
ATTR{addr_len}=="6"
ATTR{carrier}=="1"
ATTR{carrier_changes}=="46"
ATTR{dev_id}=="0x0"
ATTR{dev_port}=="0"
ATTR{dormant}=="0"
ATTR{ifalias}==""
ATTR{ifindex}=="3"
ATTR{iflink}=="3"
ATTR{mtu}=="1500"
ATTR{operstate}=="up"
ATTR{type}=="1"
SUBSYSTEMS=="sdio"
SUBSYSTEMS=="mmc"
DRIVERS==""
ATTRS{type}=="SDIO"
KERNELS=="mmc1"
DRIVERS==""
KERNELS=="soc"
DRIVERS==""
KERNELS=="platform"
SUBSYSTEMS==""
DRIVERS==""
A work colleaugue suggested modifying my persistent rules to something other than wlan0 as it might be expecting wlan0. I updated it to wifi0 and wifi1 however still get the same effect with my dmesg error:
    4.495496] usbcore: registered new interface driver brcmfmac
[    4.757582] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: May 27 2016 00:13:38 version 7.45.41.26 (r640327) FWID 01-df77e4a7
[    4.778553] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
[    5.441063] brcmfmac_sdio mmc1:0001:1 wifi1: renamed from wlan0
[    5.548324] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
[    9.012857] brcmfmac: brcmf_add_if: ERROR: netdev:wifi1 already exists
[    9.012876] brcmfmac: brcmf_add_if: ignore IF event
[    9.017502] brcmfmac: power management disabled
[    9.455715] brcmfmac: brcmf_add_if: ERROR: netdev:wifi1 already exists
[    9.455733] brcmfmac: brcmf_add_if: ignore IF event
Is there anyone on the forum that might be able to suggest other things that I should be looking into. What I do not understand is why they would both utilise the same device path? I would have thought that these would be different.
Thank you for your time and asistance responding to my post.
Nb. I originally posted on the RedBear forums (http://discuss.redbear.cc/t/raspberrypi ... -wlan/2274) and at the time was using Ubuntu Mate.
jdimpson
Re: Raspberry Pi 3 Compatibility With RedBear IoT pHAT
Wed Oct 04, 2017 1:10 pm
I'd love to do the same thing. The external antenna option on the phat is nice. But you are well ahead of me. The only thing that occurs to me is to look at how device tree overlays work.
The dtoverlay is what lets Linux identify that the iot phat is present so it can load the driver. Based on the identical output of the udevadm output for both hardware configurations, maybe the default overlay config only accounts for one device at a time; maybe it can be modified to allow two?
https://www.raspberrypi.org/documentati ... ce-tree.md
Jeremy Impson
Return to “Add-ons”
Who is online
Users browsing this forum: No registered users and 6 guests
