rapidograf
what does mean UU in address chart (solved)
Thu Sep 04, 2014 6:44 pm
Hello .
i connected DS1624 , test bus and received following date on picture
address 0x3b with bytes UU . what is it ?
in all examples address for this chip always 0x46.
bigest and hugest same as tiny and micro
joan
Re: what does mean UU in address chart
Thu Sep 04, 2014 6:46 pm
It's allocated by a kernel driver for a Wolfson audio device. Ignore it.
Douglas6
Thu Sep 04, 2014 6:50 pm
As I understand it, it's basically the result of a kernel driver (the Wolfson audio add-on driver) that is 'reserving' that I2C address. It can safely be ignored, just don't try and put your own device at that address. This thread has instructions for removing the driver modules if you really want to.
Which doesn't explain why your DS1624 is not showing up. Make sure you've pulled all the address select lines high or low; don't leave them floating.
rapidograf
Thu Sep 04, 2014 6:55 pm
thank you.
and what i can do ? in my case
which address use .
UU what is this mean by short comments if it possible.
i use 3.3 voltage for DS1624 , may be need change to 5 volts
Douglas6
Thu Sep 04, 2014 7:15 pm
Check the datasheet. It shows an operating voltage range of 2.7V - 5.5V, so it should be fine with 3.3V. It has three address select pins, A0-A2. Connect them all to ground. That should show up in i2cdetect at address 0x48
0xFF
Thu Sep 04, 2014 8:57 pm
man i2cdetect
· "UU". Probing was skipped, because this address is currently in use
by a driver. This strongly suggests that there is a chip at this
address.
rapidograf
Sun Sep 28, 2014 7:05 pm
thank you a lot to all who gave to me advices.
i fixed problem .
Problem was in bad contact , no programming :lol:
